Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My 2003 LT2000 sears riding mower spits gas out the exhaust when first started. If started with a warm engine there's no problem. Only with a cold engine. Any ideas?
boscia
  • 163 Answers
SOURCE: Replacement of gas tank on a Sears GT3000 riding mower
if theres no leak yet you can easily patch it with an epoxy puddy, available at your local auto parts store. i've used it myself on gas tanks, radiators, boats and its never failed me yet
Posted on Nov 30, 2008
panilling9
  • 284 Answers
SOURCE: gas coming out of exhaust is it the carburetor and why
carb. float stuck open
Need to remove carb. replace float needle valve and possibly the needle valve seat,
change your oil also
saturated with fuel
Posted on May 25, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
SOURCE: murray riding mower 12.5 hp briggs & stratton
Where could I buy a new gas tank for my Murray 12.5 riding mower? Has a Briggs & Stratton Engine?
Posted on Apr 07, 2010
suzukiracing
  • 200 Answers
SOURCE: engine hesitates and dies when hot, restarts fine, then dies agai
Check the fuel pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Posted on Jul 20, 2010
Spitting raw gas on cold start outthe rightside of exhaust
Your float needle in the carburetor is allowing fuel to get past it... is this a riding mower you are talking about?... If so, then yes, remove your carburetor and adjust the float height so the needle closes off once the fuel in the bowl reaches I he limit where the float reacts and thus pushes that needle up to close off...
Oct 14, 2015 | Husqvarna LGT2654 54 inch 26 HP Kohler...
Why does the engine quit running after it gets hot?
You might want to try this one but pricey thing, replace the carburetor! I have a 2008 Sears DTY 3000 25 HP two cylinder Briggs and Stratton Engine, I struggled for a year and half if it quitting when it gets hot. I replaced everything, Gas Cap, ignition module, fuel lines , filters , spark plugs, gas tank, exhaust / exhaust manifold and it all did not help. Due to the acidic (Alcohol added to the fuel) gas two the rubber inner control gaskets disintegrated causing "vapor lock" when the engine got warm/hot. Replace the Carb and then put additive into the fuel.
Oct 13, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
17.5 intek engine will not start, engine has fire and gas. craftsman LT2000 42 in deck lown mower
Is the flwheel key ok? Or you may problem like me. Pull
valve cover and see if both pushrods move.
Jul 19, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How can I replace a lost ignition key for a Craftsman LT2000 riding mower
the model number is under the seat on a sticker most riding lawn mowers use the same key the older models used one the looks the same on t=both sides and was short the newer style is longer and has cuts on one side only most any lawn mower shops will have them
Jun 14, 2012 | Craftsman Garden
Where is the fuse line on a Sears Craftsman LT2000
The fuse line is red wire from start solenoid to B terminal on ignition switch .Mine just behind bottom engine .
Mar 11, 2012 | Garden
24 hp Briggs Stratton sears riding mower engine wont start unless you use start fluid cleaned filter have flow to engine
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Feb 12, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
I need the part numbers for the intake and exhaust valves on a craftsman lt2000 model number 917.273373
If you will call Sears, or the motor manufacturer, either can provide this information for you. Either can probably sell you the parts and other parts you will need to do this job.
May 26, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When the mower is started it spits out gas fron
i have a honda riding lawn mower but it will runn for a bit then quites
Mar 26, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Sears Craftman LT2000 does not start
bad safety switch one under seat ,clutch pedal,blade engage leaver
Sep 01, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
416 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
