I just purchased a dynex vga pc monitor replacement cable from best buy and plugged both ends in. one to my laptop and the other to my tv. don't know how to get the imagine on the tv. i am looking to use my tv as a monitor for my laptop
  • 78 Answers
Right click on your desktop and select display properties.click on the Settings tab, then on Identify - when another monitor is recognized, you can enable it in that window.
Unless you're using a mac. If you are, get back to me :)
Posted on Apr 09, 2008
SOURCE:
How can I hook my dell latitude e6400 lap top up to old sony Trinitron with one vga cable connected to laptop has rca and s-video also on same cable only one side thoe
If I understand your configuration correctly, you have a VGA cable that plugs into your laptop and you want the other end to connect to your TV? They make a VGA to S-video converter box that you can buy to make the connection http://www.bestbuy.com/site/agptek-vga-rca-s-video-to-vga-converter-box-adapter-switch-for-pc-lcd-monitor/1308798590.p?id=mp1308798590&skuId=1308798590
Sep 23, 2013 | Dell Latitude E6400 Notebook
How do i connect my laptop to my dynex tv?
This depends on your hardware. If you have HDMI port on your laptop and on your TV it is the best and easyest option for your case. Just plug-in the hdmi cable, go to your computer Control Panel->Display and configure the second monitor as extended. Your TV must be monitor number 2 and you should use recommended settings for the picture resolution.
From your TV go to input source list and select the HDMI port.
Now you should see your desktop background without the taskbar and icons. So you can drag and drop the application you want to see on your Dynex TV(secondary monitor) and that's it. This method will bring video and audio just with one cable. Of course you can use VGA port on the Tv, but the quality of the picture will drop and you must have separate cable for the sound.
May 28, 2012 | HP Computers & Internet
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
I want to change my 15 pin vga cable to my monitor
There are two types of cable set up with VGA monitors. The newer ones have a cable that is detachable at both ends. In other words the cable can be unplugged from the monitor and the computer. These, of course are easily changed. They can be purchased at places like Best Buys,
CompUSA, TigerDirect.com. Below is a listing on Ebay for a replacement for about 8 dollars including shipping.
SVGA-VGA-HD15-/280624443642?pt=LH_DefaultDomain_0&hash=item41568530fa">
http://cgi.ebay.com/Male-to-Male-15ft-PC-Monitor-Cable-Cord-SVGA-VGA-HD15-/280624443642?pt=LH_DefaultDomain_0&hash=item41568530fa
If you have the type of cable that is permanantly mounted to the back of the monitor, then you would have an extensive operation to replace the cable and it would likely be more expensive than the monitor was in the first place to replace it.
Hope this helps,
Best Regards,
Mark
Feb 03, 2011 | Computers & Internet
I recently purchased a ASUS K60 Notebook from best buy. I am using Windows 7. I am trying to hook it up to my 42" inch LCD tv via a VGA cable. My problem is that when I do all I am getting is my Desktop...
Since you are using a laptop to connect to an extended monitor, follow these steps:
  1. Make sure that both the laptop and TV are on.
  2. Connect the VGA cable from the laptop to the TV.
  3. Then hold down the FN key and the function key with the TV/Monitor icon like the one below to switch to dual monitor display mode.
Jun 09, 2010 | ASUS K60IRBBBR05 Notebook
Trying to set up my dell inspiron pc laptop to my vizio tv with a dynex vga pc monitor cable and not having any luck
Sometimes you have to change the display settings to allow you to use the external VGA plug
1. Go to Control Panel
2. Go to Display
3. Click the settings tab
4. there should be a dropdown tab
5 then you choose the 2nd screen
Try this link as well http://www.microsoft.com/windowsxp/using/setup/hwandprograms/monitors.mspx
Mar 30, 2010 | Dell Inspiron 1545 Notebook
How should i connect a monitor to dell inspiron 1300 laptop
Hi
Please follow these steps
1) Purchase a VGA cable (these can be purchased from any good PC shop)
2) Plug one end into the VGA connector on your laptop usually will have 15 pins sticking ut on the back of your laptop
3) Plug the other end into the Monitor
4) On your laptop press the fn key and F8 key (or the F key which has a picture of 2 monitors above it) - this will transfer the display from the laptop to the external monitor
5) enjoy :)
Please leave feedback/vote if my answer was helpful
Feb 12, 2010 | Dell Inspiron 1300 Notebook
Vga
just buy a Monitor like cable buy a generic one or branded u will find it in all big stores in PC section it is a 15 pin Monitor like cable just join both ends and all set , select the input source of LCD TV to PC if it is not auto bye
Feb 19, 2009 | Dell Inspiron B130 Notebook
Computers & Internet Logo
87 people viewed this question
Ekse
Alun Cox
