Question about Samsung Televison & Video
Samsung LCD 100 hertz feature - problems with jerky picture
When the feature is turned on, the 100 hertz feature with my Samsung 40" LCD sometimes causes picture to be jerky for periods, (i.e. smooth, then jerky intermittently). Only resolved by switching 100 hertz off in TV menu. This is worse when using downloaded movies from Apple TV (lower resolution), DVD's are mostly OK, but occasionally happens. Is this due to problems decoding highly compressed formats? Or just trying to display lower resolution pictures?
SOURCE: SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
got mine working better unplugged the sound and wiggled the plastic coated wire above the large fan works but freezes maybe once in a day some days never have the sound running through the receiver (surround) I shut it off and it comes back on when it does freeze figure loose connection
Posted on Jan 06, 2008
SOURCE: Loss of Picture
You can use this firmware too:
http://www.samsung.com/us/support/download/supportDown.do?group=mp3audiovideo&type=hometheater&subtype=hometheatersystems&model_nm=HT-X40T&language=&cate_type=all&dType=D&mType=FM&vType=L&prd_ia_cd=03030100&disp_nm=HT-X40T
Posted on Jan 17, 2008
  • 395 Answers
SOURCE: Samsung lcd tv le40r8
if the unit is under warranty call samsung for the nearest authorized repair place. the problem is a bad main board.
Posted on Feb 24, 2008
SOURCE: Samsung LE32R7 Picture Flashing
I have a 37"Samsung LCD and having just spoken to the Sky engineer (also a friend) he says it is a national problem between Sky+ and Samsung. I have the same problem when on playback but not on real time? If you had your box changed to an Amstrad what sort did you have the problem with?
Posted on Apr 21, 2008
SOURCE: Samsung lcd tv le32r8 (Picture - Movie setting)
The TV is probably in Shop mode, when your TV is initially turned on you can choose between Shop mode or Home Mode.
In Shop mode the TV automaticly returns to the standard setting after a while, they do this so customers can "play" with it.
Press down de Volume button and then hold down the Menu button for five seconds on the side panel of the tv.
Posted on Jun 12, 2008
I have a samsung tv model #LN-S4051D. Problems: Turn on the Power button (red light blinks at power button with clicking noises every 30 sec. or so) without pictures. Please help. Thanks
This is a comon problem with the Samsung LCD HDTV on the Power Board.
You can repair or replace faulty parts on PS board.
When checking the capacitors, If they are slightly rounded on the top where the X is, the cap is defective. See the Youtube below.
Because the Samsung LNS4051D would not turn on and the power
LED would blink 4 times and the relay would click and this
would repeat again and again. I replaced power supply board
parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors,
three had their tops bulged up slightly that I missed on
initial visual inspection. After seeing the reports of
problems with these caps on
http://www.fixya.com/support/t1336881-will_not_turn_or_off ,
I replaced them with Radio Shack part 272-1032, 1000 uf, 35v.
They are slightly bigger, but fit OK. TV is working fine now.
Cost was 4 x $1.59 = $6.36 plus the time. I saved between
$100 to 300 in the process of either replacing the board or
getting the unit serviced. If you are not comfortable
replacing components which means using a soldering iron, you
can replace the power circuit board, available from
www.Samsung.PartStore.com.
Some UTube showing the problem and fix -
http://www.youtube.com/watch?v=tK7zFBBU6p4&feature=related
http://www.youtube.com/watch?v=Mm51C_RDIZE&feature=related
http://www.youtube.com/watch?v=BNHHrgX_6cs&NR=1
Jun 23, 2010 | Samsung LN-S4051D 40 in. LCD Television
I have a samsung 40" flat screen mod. LN-S4051D. i went to turn it on and nothing. all it does is click as though it's turning on but nothing happens.
This is a comon problem, clicking and won't come on. Problems with the Samsung LCD HDTV on the Power Board capacitors.
Jun 20, 2010 | Samsung LN-S4051D 40 in. LCD Television
How do i increase the number of hertz that my tv work at?
That is telling you that the broadcast signal is at 60 htz.
Jun 04, 2010 | Samsung LN40B630 40 in. LCD TV
SAMSUNG 40" LCD LE40M86BDX CLICKING BUT NOT SWITCHING ON
You may want to repair or replace board -
Faulty parts on PS board , bad press for Samsung.
Feb 02, 2010 | Samsung LN-S4051D 40 in. LCD Television
Colorful vertical lines on screen
more likely to be bad LCD panel (very expensive), but you can try replacing the LCD controller first (around $80~100).
Dec 01, 2009 | Samsung LNT4066F 40 in. LCD Television
Samsung 40 inch LCD takes longer and longer to turn on, 5 minutes now, screen black with light under name on; once on line defects appear on screen. Sometimes when turns on only random lines instead of...
common problem you have a bad cap or 2 in your power board this board is the one where tour ac cord plug into these can like caps will be puffed up on top the values are written on the sides on the device replace them and your good to go
Nov 18, 2009 | Samsung 40 in. Flat-Panel LCD HDTV
Samsung LN40B530 40" 1080p LCD HDTV Picture rotated
how to rotate my samsung flat screen monitor turning up side down
Sep 08, 2009 | Samsung LN40B530 40 in. LCD HDTV
Image problem
Its only 3 month old, so its still under warranty. Yes, its a major problem.
Jul 21, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Samsun 710v not optimum mode problem
you must chang your Mainboard for LCD to fix it
Oct 03, 2007 | Samsung 710V 17" LCD Monitor
Televison & Video Logo
462 people viewed this question
Jerry Greenberg
Jerry Greenberg
