Question about Maytag Neptune MDG5500AW Gas Dryer
My Neptune gas dryer is working fine other than the heat. Sometimes it heats, sometimes it doesn't...very random. Fuse or thermostat?
  • Maytag Master
  • 43,501 Answers
Hi, If you have a gas dryerMy Neptune gas dryer is working fine other than - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If My Neptune gas dryer is working fine other than - 2_bing.gifef="http://www.fixya.com/support/t4726170-load_takes_more_one_cycle_dry#">dryer is electric2_bing.gifMy Neptune gas dryer is working fine other than - 2_bing.gifere could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gifMy Neptune gas dryer is working fine other than - 2_bing.gifef="http://www.fixya.com/support/t4734648-dlg5932w_not_drying_completely_hear_gas#">Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 04, 2010
DOESNT HEAT AND I SMELL GAS
Hello - From what you are describing, if the dryer only heats up sometimes but provides a gas odor, it could possibly be a defective gas supply or igniter. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the fuse for the dryer. Turn on the dryer and select a normal cycle. If it proves to be ineffective and if the issue continues I suggest contacting a professional to move forward accurately. Keep in mind since it is such a complex unit, the technician will likely verify that it doesn't have a defective sensor, control board or high limit thermostat.
Oct 13, 2012 | Frigidaire GLGR341AS Gas Dryer
I have a kenmore elite model #110.95088400 that doesn't heat when drying. I checked the thermal fuse and it goes to continuity. I checked the hi limit thermostat and it was continuity, the thermistor...
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Dryers
Maytag mdg6700aww dryer clicks to start the igniter. Sometimes the burner ignites, other it doesn't and I can smell raw natural gas from the vent. Not drying. Help
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Maytag Neptune MDG6700A Gas Dryer
Dryer not heating. check the thermostat, the heating coils and the fuse, all check out fine. What could be the issue?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 31, 2011 | Roper Dryers
Works fine,not heating
heatman101
Jan 19, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Not getting any heat on any setting. My Neptune dryer is now 6 years old. Is it possible a fuse has blown? Thank you.
heatman101
Oct 06, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Unit will not dry clothes....vent is clear; no breaker problem; not over loaded; was working fine. unit is 6 years old.Will sometimes heat up at the start of the cycle but does not stay heated.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Lower dryer tumbler will not heat up, upper dryer part works fine
heatman101
Sep 05, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Its a gas neptune with dryer top. It quit heating so I reset it to factory defaults using the technical manual and the heat came back on but only for one cycle, Top heat works fine. Bottom control panel...
heatman101
Jul 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer will not heat
heatman101
Jul 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
162 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
