Question about Nikon COOLPIX L18 Digital Camera
The lens was open and it dropped now it wont open or close, is this something i can fix myself? or should i bring it in?
  • 57 Answers
SOURCE: Lens
hi, Nikon L series is so delicate that repairing is hardly possible so you have to take it to nikon shop where it can be replaced by new one. I dont think anyone can help you either than Nikon. good luck...
Posted on Aug 04, 2006
SOURCE: Dropped the Camera, Lens is stuck open
I already tried posting this but I think it falied. Just in case, here it is again!
I just now fixed my own Nikon S220 (very similar to 210) which suffered the same fate as yours. However, I laid my camera down on a cushioned foot-rest (you could use a couch cushion or pillow on a table) with the lens facing UP, pressed down on both sides of lens front gently yet firmly, and BAM, the lens went back in all the way. I turned the power back on and the camera is good as new (except for the small dent from the fall of course).
I suggest you try this before spending $100 on repairs and/or buying a new camera!
Posted on Sep 23, 2009
  • 11967 Answers
SOURCE: I have a coolpix p90 and dropped it. Now the lens
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 20, 2010
  • 304 Answers
SOURCE: I dropped my Nikon Coolpix
Hi, Unfortunately there's no way to fix that yourself. With damage like that it's 50/50 that even a professional could fix it and you'd be look at a large bill. I'd honestly suggest getting a new camera over having it repaired.
Posted on Jul 20, 2011
  • 102366 Answers
SOURCE: Lens error want to take the faceplate off and fix myself
Try the procedures in this tip.
Posted on Aug 26, 2012
Lens will not close, is there a way to fix this problem myself?
You could try gently twisting the outer lens ring when you press the on button to see if you can free the lens.
It's not an exact science and if the camera had been dropped on the lens then this would not be an option but, if it has just stopped then maybe it might work.
Other than that the camera will have to be opened up and the lens reset.
Jan 18, 2010 | Fuji FinePix F650 Digital Camera
The camera was dropped with the lens open. Now it
Bad news - there is no DIY fix for lens damage. The drop likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. If you attempt to fix it yourself you are likely to worsen the damage, so the camera will need professional repair.
Oct 19, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Dropped my canon powershot sd400, now it won't work fine
Hi there, there is two possibilities. The first one is to check the lens barrier covers at the front of the lens are opening correctly. If the front cap is dented in any way it may prevent them from opening fully when switching the camera on. If this is the case, you may be able to manually assist the cover by gently pushing them open with something soft like a cotton tip. This wont fix the problem but may temporarily allow you to use the camera. The other possibility, is that the shutter assembly inside of the lens has been damaged. If you gently shake the camera you may be able to see something shifting across the image on the screen or even when looking through the front of the lens itself. If this is the case you would need to have a service centre replace the lens for you. The same applies for the front barrier however that repair would be much cheaper. Best of luck!
Apr 14, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
18-55mm lens won't zoom
DON'T TRY TO FIX THIS YOURSELF! You will only add to the damage. If your lens is in warranty, contact Nikon for instructions to get it repaired. If it is out of warranty, I would either pay Nikon for the repair or take it to a camera repair man.
Dec 27, 2008 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
Lens problem
Dear Customer,
When you say the lens barrel is bent, do you mean that the camera won't turn on ?, or the lens barrel is just bent and it looks outlandish. However if it's not turning on follow these steps:
1) Try to gently re-position the barrel, and make it more stortionate.
2) try to recharge ( or get new batteries ), and see if the lens will withdraw.
Unfornately, when you drop a camera, many warranties are voided, and you have to pay to have it fixed, but i doubt it would be that much money to fix.
Please rate this solution.. Thank You..
Jul 11, 2008 | Casio Exilim EX-S500 Digital Camera
Lens Stuck
YOU CANNOT REPAIR THIS SOPHISTICATED CAMERA YOURSELF!!
I guess pushing the lens inside may have made the problem worse.
I follow a rule- if you drop an electronic equipment and a problem occurs- it usually takes a professional repair!
For all you kamow there is a minor problem in the camera, like something stuck inside or something like that. and most certainly you will aggravate the problem by trying to do it yourself..
do post when you get it repaired, for all of us to know what goes wrong when lens gets stuck..
take care
Jun 17, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sanyo VPC-E760 Lens not closing
THis is really easy to fix. just pull the lense out so it is alligned. it might seem like your breaking the lens but its just jammed.
Feb 17, 2008 | Cameras
Lens is stuck
Hello Gruntny, in order to repair this Camera you will have to replace the OPTICS UNIT (ED13A). Please contact your nearest Sony Service. Best regards, Arpad
Dec 21, 2006 | Sony Cyber-shot DSC-W50 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
94 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
