Question about Home
Need ordering information fro model V2045 Bathroom Fan dome light
SOURCE: i need help hooking up my bathroom fan and light i
Right now a single switch turns on both light and fan.
You want to put in a double switch to control light and fan separately.
But the problem is there is not a separate wire to each the light and fan.
You need a separate wire to each, but the circuit wasn't wired that way.
Usually when the circuit is wired for separate control, there is a red wire that also goes to ceiling box.
Unless you run another wire to the ceiling box, it won't be possible to control light and fan separately.
Electrician can do this pretty easily if there is attic space above bathroom.
Posted on Oct 17, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Broan Bathroom light fan combo. The fan
Either the plug came out, the receptacle wiring came loose or the bulb is out,,,
http://www.fixya.com/support/r6871896-broan_bathroom_fan_care_cleaning
heatman101
Posted on Nov 17, 2010
SOURCE: My Broan Nutone Bathroom fan
NuTone 0696B000 is the Replacement Motor Assembly. Search that in Google and you can find a number of sites to purchase it from. We've replaced our fan motor 4 or 5 times over the years. It just gets too much use. Very simple to replace, you plug it in and it saves having to replace the entire unit because they don't make anything that fits that same space.
Posted on Apr 21, 2011
SOURCE: Hampton Bay 52 white ceiling fan model 5745 A
which remote control do I need for Hampton Bay model 5745A
Posted on Sep 23, 2011
  • 2119 Answers
SOURCE: Removal of icemaker fro Amana Model AFI2538AEB4 refrigerator.
Download owners manual here.
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Amana-Parts/Model-AFI2538AEB4/1268/0161000?pathTaken=modelSearch&prst=0&shdMod=AFI2538AEB4
AMANA Refrigerator Parts Model AFI2538AEB4
Posted on Aug 30, 2014
Tip
Broan Bathroom Fan Care and Cleaning
<p>One of the most common <b>bathroom fans</b> is the <b>Broan brand ventilation fan</b>. These fans come in many configurations and variations. Because of the environment that these fans are in and the placement of these fans they will get very dirty over a period of time and will need to be cleaned from time to time. <b>Cleaning bathroom fans </b>can be fairly easy if you have a few tips about how to do it.<br /> <p> <br> <p>To clean the fan the inside of the fan must be accessed first. To get to the inside of the fan the cover must be removed. Most of the covers simply will pull downward and away from the ceiling. There are a couple of springs, one on each side the snap the cover up and hold it in place. On some models there can be a screw that holds the cover. It will be visible right in the center of the cover. If no screw is visible then you can assume that it is a spring type cover. If there is a light in the cover you can remove the plug and the light will come right with the cover.<br> <p> <br> <p>After pulling the cover down simply squeeze the springs together slightly and the cover will come completely out and you can take it to your sink to wash it. Then take a vacuum or a damp rag and clean the inside of the fan compartment. If you look closely you will see that the fan assembly has a plug that can be pulled and the fan assembly can be removed by either removing a couple of screws or by placing a screw driver between the fan assembly and the side of the box and snapping out the fan assembly.<br> <p> <br> <p>Once you have the fan assembly out you can then use compressed air, like you use on your computer keyboard, or a damp cloth to clean the fan assembly. The compressed air works the best on the blower wheel and in some cases a small screw driver may be needed to remove caked on dust inside the fins of the fan.<br> <p> <br> <p>With you vacuum, you can now clean out the rest of the box and even into the vent hose a little bit. Be careful not to destroy the flapper, as that is what stops cold air from being pulled back into your home while the fan is off. Wipe down the box to complete the cleaning.<br> <p> <br> <p>The fan can now be reassembled by reversing everything and placing it all back as it was before you removed it. Be sure to remember to plug the fan motor back into the socket. The light may also need to be plugged in if you have a light in the cover.<br> <p> <br> <p>You will now have a nice clean fan again. <br> <p> <br> <p>If you want to <b>replace the fan</B> because it is broken worn out or noisy you can often <b>buy replacement bathroom fan parts</B> or even a new fan that will fit in the same box. Upgrades are available to fit existing boxes also. To find <b>bathroom fan upgrades</B> and replacements go to <a href="http://www.broan.com/">www.broan.com</A><br> <p> <br> <p>At <a href="http://www.broan.com/">www.broan.com</A> you can also <b>order <span> </SPAN>broan replacement parts</B>, <b>download broan manuals</B>, and get <b>installation tips for your broan fan</B>.
on Nov 17, 2010 | Home
Three lights and the bathroom fan stoped working on my 79 rockwood
you take the bad light bulbs up . then buy the same model lights .install them on the switch.
ceiling light
May 23, 2012 | Dryers
I have a Hampton Bay ceiling fan/lamp where the lamp dome is apparently very tight into the housing. I pressed up and turned in the direction noted to remove the dome. The dome houseing came down and is...
Most light domes twist on or off or have thumb screws to loosen and lower the dome.It sounds like you removed the light kit assembly instead of the dome.Try to put back by twisting in place the light kit assembly and look for screws,or hold back on trim and turn just glass dome do not use too much force .I checked web site but can't find your model.It is unusual to not be able to just remove glass dome.Look closely at how the glass dome is positioned. If no screws are visible either the glass part unscrews or the ring unscrews allowing glass dome to be removed.Good Luck.I have installed many ceiling fans the problem is if you didn't install it your at a disadvantage.GOOD LUCK.
Jan 04, 2011 | Heating & Cooling
I need help hooking up my bathroom fan and light i have three wires going to the bathroom fan and light white black and ground i want a swith to turn off the bathroom light one to run the light to the fan...
Oct 17, 2010 | Broan-NuTone Broan 68W White Decorator...
How do i hook up a two function swith i have white black and ground going to the fan and the light and anther white black and ground coming from my bathroom light i want to have a switch to turn my...
Ok you only have two switches, so you would use one switch for your bathroom light, and the other for both the fan and the light, the light will come on when you turn the fan on.Connect the incoming black (hot) wire to both switches. Then connect the black wire to the switch you want for your light. Connect the other black to the second switch that goes to your fan and light. Connect the three white wires together (neutral) Connect all ground wires together, and leave a pigtail to connect to the ground terminal on the light switch. If you want separate switches for light in the fan and fan, you will need another conductor and a three gang switch.
Oct 17, 2010 | Broan-NuTone Broan 68W Dual Rocker Switch
How to oil a broan bathroom fan motor
The fan motor is pre-oiled and sealed so it can not be oiled if fan motor is squeeling then motor replacement is the only option. You can get replacement motors which is usually cheaper than buying a whole new fan. Will need to know the model # of broan fan. I hope this information was helpful. Please rate the information given. Good Luck and have a great day. Jeff
Apr 02, 2010 | Home
The Fan in my Nutone bathroom light/fan is not working...
It is really easy to change the motor yourself. It is about a 15 minute job. You just need to find your model number and then you can buy the complete motor assembly. https://www.centralvacuumstores.com/model_number_help.php
Mar 28, 2009 | Broan-NuTone N-8663RP Combination Light...
Home Logo
104 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
