Question about Panasonic KX-T7456 Corded Phone
I have a KX-T7456. Set 3 CO buttons for speed dial with new names and extensions. Busy light does not come on when those 3 lines are in use. Works on all the other numbers.
  • bills89 Jun 01, 2010
    Sorry, I meant one-touch dialing, not speed dialing.
  • Panasonic Master
  • 2,460 Answers
It's not speed dial, it's DSS. Names come from the directory (sys prog 004). The button programs from personal programming PROG 99? button 1+ext+STORE.
Carl
Posted on Jun 01, 2010
  • Carl Navarro
    Carl Navarro Jun 02, 2010
    What does the phone look like? Doesn't it have 24 buttons that have lights on it? How are you programming the "one touch" dial and how do you expect it to light?
    Every Panasonic phone programs exactly the same. It is either programmed as a DSS buttton (1 before the extension), a CO button (0 before the trunk) or a one touch button (2 before the number sequence which could also have a "9" access code in it)
    There is little documentation on the 7456 in the U.S. systems and the buttons with lights all require 0,1 or 2, or there is a specific sequence for other features.
    What is the exact number you're trying to put under the button?
How do I store extensions in KX-T7453?
PROGRAM BUTTON
99
PRESS THE BUTTON YOU WANT TO STORE THE EXTENSION ON
EXTENSION NUMBER
AUTO DIAL/STORE BUTTON
Nov 05, 2014 | Panasonic KX-T7453 Corded Phone
How do i set ring on Flexible Buttons.....
Perhaps you are trying to set up speed dialing.
Right?
Jul 22, 2013 | Panasonic KX-DT343 White 24 Button 3-Line...
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    CO button light was stuck so to clear it i pressed Prog, then CO button, then 2 (clear) and then enter. Doing this cleared the light but it also cleared the extension associated with it. I have re-added...
    What was 2? Extensions are put in with a 1. The 2 is used for internal or speed dial calls (as in 29 plus a number gets you speed dial).
    If you assign a digital station that is not in service to a button, you will get a busy light.
    Carl
    Nov 23, 2010 | Panasonic KX-T7633 Corded Phone
    I have a Panasonic KX-T7456, calls to voicemail?
    This is a giant guess because you may have a different system. Try dialing 7105 165 # from the intercom and try having someone call you.
    If you have a Panasonic voice mail system, that's the code for call forward busy/no answer.
    Your voice mail user's guide and system manual has the complete instructions.
    Carl
    Jul 13, 2010 | Panasonic KX-T7456 Corded Phone
    I am tring to figure out how to program extensions on our kx-t7737 phone.
    A 773x phone has 24 buttons, 12 are lighted and 12 are Feature. If you want to reassign some of the lighted buttons as extension buttons on the phone, you can press PROGRAM 1 + ext no STORE and that will give you a busy indication whenever that extension is off hook.
    You can program the right side buttons to speed dial the extensions by just pressing PROGRAM ext no STORE. It will dial the extension when you press it if you have intercom dial tone.
    How the button behaves is dependent on which system the phone is attached to. In a TA, you have to start with dial tone on the intercom. In a TAW/TDA you don't.
    Carl
    Sep 28, 2009 | Panasonic KX-T7633 Corded Phone
    Panasonic KX-T7730- assigning speed dialing/one touch. I tried to press prog button and the one touch button..but it gives me an error message "not stored". How to solve this? I have 12 buttons to assign...
    It says "Not Stored" because you haven't stored anything in it. There are 12 buttons on the left side with lights and 12 buttons for feature dialing on the right. If you want to monitor extensions, the buttons on the left are the ones to use. If you want to store speed dial numbers and feature codes use the ones on the right.
    Left button programming. Press PROGRAM and the button. For extensions, dial 1+ext and STORE. For CO's, press 0+line number, for inside codes press 2+code, for outside number press 2+9+number, all followed by STORE.
    Right button programming. For inside codes dial the code, for outside number press 9+number followed by STORE.
    Note that you could also dial "8x" or "80x" in place of "9" for specific line access. Also, you can store extension speed dial numbers on the right, you just won't get a light indication when they're busy.
    Carl
    Jun 04, 2009 | Panasonic KX-T7730 Corded Phone
    One of the Co lines. CO 4 has a constant fast "busy" tone when off hook. Bad CO card?
    The red light will stay on until you clear the alarms. Those alarms can be for any reason, so the idea is to just ignore them and let a technician read them when he comes.
    If you don't have a Line 4, it will give you a fast busy because there's no dial tone. Just because it appears, and you can select it, ie green light and display saying Line 004, if it has no line connected to it, you will get a busy. Either get dial tone on the line, disable it, or take it off the set. The first is in program 400, the second is PROG press the button press TRANSFER twice and STORE.
    Carl
    May 26, 2009 | Panasonic KX-TDA50 Phone
    How do I undivert an extension?
    Oh, the old forward to two destinatons trick :-)
    If you're happy with the destination for C.O. Calls, you can set only the intercom call forward. There are *71xx codes that you dial. The 3rd digit is 0 for all calls, 1 for CO calls and 2 for itnercom calls.
    The 4th digit can be 0/2/3/4/5 where zero is cancel, 2 is all, 3 is busy, 4 is no answer and 5 is busy/NA. The next digits are the destination which may also include an access code (9) and then #.
    So, example to forward all intercom calls to voice mail (if 500) dial *7122 500 #. If the location for both calls is the same you can also reset everything by dialing *7100# then *7102 500 #.
    Carl
    Sep 11, 2008 | Panasonic KX-T7630 Corded Phone
    How do ichange the time on Panasonic KX-T7431??
    MUST BE DONE FROM EXT.101
    1.leave handset in the cradle
    2.Press "Program" button
    3.Dial *#1234 (star pound 1 2 3 4)
    4.Press Sp-phone button 3 times
    5.enter the correct hour on the dial (2 digits)
    6.press the button (in the lcd window to advance to minutes)
    7.enter the correct minutes
    8.press auto dial/store button
    9.pick up hand set/ hang up hand set.
    Oct 29, 2007 | Panasonic KX-T7456 Corded Phone
    Panasonic KX-T7456 Corded Phone Logo
    169 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
