Question about Astar LTV-40HBG 40 in. LCD HDTV
Tv will turn on(green on light showing) but no picture. was giving us problem for 1 day with 'invalid input' flashing then blue screen all connections are tight.
    President:
  • 1,099 Answers
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope it help
Posted on Jun 01, 2010
Olevia 242 TV.... No picture or sound!!!
A blue screen usually is present if no signal is connected to the set---hook a DVD up to one of the rear inputs--select that input and see if have picture and sound.
If that works connect cable or antenna to set and select that input
NO signal is like no gas in car---it will not run.
Mar 22, 2012 | Televison & Video
Sony KP-65XBR
This is the sony support page. Try this out. Click here
Jan 12, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Samsung DLP TV; Green Lines
If you get green vertical bars or green dots in the picture but not in the menu screen (Digital board symptom)
Feb 28, 2010 | Samsung DLP HL-P5663W 56" TV
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
One of our TV's was being accessed by someone in the neiborhood. I found in the manual how to change the remote code. After doing this the TV is locked on one channel. I did reboot. The remote is working...
Hi! I will be more than glad to assist you in this concern. Lets Isolate the problem, press 1st the sat button once on the remote that is giving you a problem. the sat button should light up and check if you could pull up the guide or can change the channels. if there is still no response, bring with you the remote conrtol that is giving you a problem on tv1, turn on the tv and it should show a picture, go to the fron tpanel of the receiver and press the power button once to turn off the green light, once its off, the tv will go into a black or snowy screen, press the up button on the front panel of the receiver until it shows the system information. look for the primary and secondary remote address, ex, primary remote address is 1 on the white box and 1 on the green box, secondary remote address is 2 on the white box and 2 on the blue box, how to reprogram the remote, press and hold the sat button on the remote that is giving you a problem and wait until all lights lit up, once it lit up release it and press any number from 1 to 15, but lets choose 9, then press the pound button (#) that is under number 9, once you press pound button, the sat button should flash 3 times, then after it flash, press the record button, that is under the cancel or view tv button., you will notice that the secondary remote address was change from 2 to 9. to save the setting, get the remote1, select done on the screen and it will show a black or snowy screen. to check the remote 2 if it works, press the sat button once and the the big red power butto, the blue light should turn on if there is no blue light but there is, the blue light will turn off, then before you go to the tv2 location make sure that blue light is on and then check on the tv2 location if you could change the channels now. just incase that the problem is still there, check the remote antena on the back of the receiver, make sure that its on the upright position to broadcast the uhf signal properly.. that should fix the problem. if just incase the problem still exist, call 1800-333-3474 ask for a replacement of the remote..pls feel free to get in touch..if you have any query
Jul 04, 2009 | DISH Network 322 DTV Receiver
TV INPUT ON BACK OF TV, GIVE AN ERROR
I recomend that before doing anything else, unplug your TV (from power) for at least 5 minutes and then plug it back in. See if this solves the problem.
Feb 24, 2009 | Sharp LC-42D64U 42 in. LCD HDTV
Mitsubishi wd 52525 Problems, but no blinking lights.
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
Astar LTV-40HBG 40 in. LCD HDTV Logo
96 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
