Question about Coleman Garden
Coleman Clean Machine 1210.
I have a Coleman Clean Machine 1210 pressure washer. Although I have it hooked up to the faucet and the motor runs, no water comes out. When I first pressed the trigger, a black substance (oil) came out. Advice?
picatudo
  • 239 Answers
SOURCE: NO PRESSURE FOR BLACK AND DECKER PW1400
the pump went bad
Posted on Dec 28, 2008
SOURCE: need instruction book for coleman powermate clean 1500
The hose connection I believe is for hooking a hose up and running it into a bottle of cleaner. The cleaner is mixed with the water when it is sprayed, The knob on the bottom adjusts the strenght of the solution. Most washers have the same setup.
Posted on May 26, 2009
  • 623 Answers
SOURCE: POWER CRAFT BY Karcher bought Aldi on 31Mar 05.2100Watts 130 bar.
You did winterize the machine? Leaving water in a powerwasher will freeze and damage the pump. It's a common happening, because people don't think of it or are not told by the maker.
Posted on Apr 30, 2010
  • 1388 Answers
SOURCE: pressure washer does not spray consistent flow of pressure
Pressure washers have a pressure regulator/unloader that bypasses the water back into the intake when you let go of the trigger with motor running. If you let the machine run for long preiods in bypass the system could be damaged due to heating of the water being bypassed. The water is in a closed loop. The as the unloader wears it will tend to want to bypass which is what is happening in your case. Dirt trapped at the tip will cause this also. Install clean tip to solve problem. If clean tip did not help then try lowering the pressure by turning pressure regulator counterclock wise. If problem is gone then parts are failing but keep using pump. Good luck.
Posted on Jul 11, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Coleman #1210 Clean Machine AND need a
Hi Lance and welcome to FixYa. I am Kelly.
Most of the Coleman pressure washer parts can be found here:
http://www.arkansas-ope.com/Coleman_PW_Parts.html
I do believe the nozzles and wand your looking for are on the linked page above.
If the link is not to your satisfaction I can find a few more sites with Coleman Parts. Just respond here and I will dig again. The link provided just happens to be the most reliable.
Here is the number for Coleman so you can call them directly to get what you need:
1-800-445-1805
1-308-237-2181
Fax 1-308-234-4187
Thanks for choosing FixYa,
Kelly
Posted on Jan 26, 2011
you may have a strainer in the wand simply unscrew the wand and look for the clogged strainer it protects the nozzle from getting any dirt
Jul 30, 2013 | Garden
Can't get nozzle to work. not building up enough pressure.
Make sure the injector is turned on. Clean the nozzle or the strainer if either are clogged or blocked. There may also be dried chemicals in the injector; dissolve them by running warm water through the injection tube.
Check to see that the faucet is open if the engine is running but the pump is not building maximum pressure. If the unit has been stored in freezing temperatures, you'll need to thaw it out completely, including the gun, wand and hose. There may also be air in the pump. Allow the engine to run with the gun open and the wand removed until a steady stream of water is released. In addition, make sure the adjustable pressure knob is set to the maximum position,
Clean the nozzle if the engine is overloaded, as the nozzle may be partially blocked. Reduce excessive pressure by using the pressure adjustment knob.
Jun 11, 2011 | Coleman Garden
I have a Coleman #1210 Clean Machine AND need a Flat spray nozel.\r\n Lance lanceanderson12@earthlink.net
1-800-445-1805
1-308-237-2181
Fax 1-308-234-4187
Kelly
Jan 26, 2011 | Coleman Garden
Water system in my Coleman pop up not working
Make sure you have a water regulator connected to the water source before connecting it to your RV or the pressure could blow out your plumbing. The force of the water coming from the faucet can be too much for any RV and a regulator can be purchased from RV dealers, camping world, and even some Wal Marts carry them.
Jun 22, 2009 | Coleman Campers Grill
Coleman 1210 power washer no water comes out of gun
I've never used it before what plugs in where, the 1210 powermate, Pictures would help
Jun 01, 2009 | Coleman Pressure Washer PW0881800
Need instruction book for coleman powermate clean 1500
Apr 09, 2009 | Garden
Garden Logo
440 people viewed this question
Top Coleman Garden Experts
John Trevino
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
