Question about Mtd 22" Yard Machine Push Mower
I have a yard machine 5.75hp self-propelled mower won't start
I have a yard machine 5.75hp self-propelled mower with a B&S engine.Model#2H802-3306-83 the H could be a 4 it was hard to read.Have replaced the fuel line and the mower still won't pull start.If you spray a starting solution it will run until thats gone.I cleaned out the screw with the small holes that attaches to the fuel bowl.Any other suggestions on what to do would be much appreciated.
  • Mtd Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on Jun 02, 2010
What is the sprkplug gap for a 6.5 briggs &statton
Contact MTD if your manual doesn't cover this, or buy a shop manual. Or go to the Briggs & Stratton website.
May 20, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Won start bad start-stop cable
remove the holding clamp, the end of the cable is in an S shape tilt and pull then replace oh, take off the cover too
Aug 03, 2013 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Brand new mtd self propelled mower. Gas and oil in machine pried the bulb. still will not start why?
Try tapping on the carburetor float bowl with a screwdriver handle or something like that. I have seen where the needle valve sticks from manufacturing and needs some very gentle persuasion to break loose and allow fuel in
Mar 19, 2013 | Mtd 22" Yard Machine Push Mower
What type of oil do you use for 6.5 hp yardman lawn mower mtd 160cc 21 inch self propelled
The manual will call for 30 weight, but 10w30 works just fine. Be careful to not overfill the crankcase. Your machine will take 16 - 18 oz's when the crankcase is empty.
Tim
Oct 06, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Stripped screw needs to be removed
hello. You will probably have to drill out these screws enough to use a tool called a screw extractor. That said take a look at this excellent link http://www.ehow.com/how_2078426_remove-stripped-screw.html
Joe
May 09, 2010 | Mtd 22" Yard Machine Push Mower
We have a self propelled Yard Machines push mower. My husband tried to start it for the first time this year. After much effort, it would turn over, but not stay running. Any suggestions?
drain all gas add fresh gas ,pull and clean sparkplug or replace. also check float in carborator might be stuck if this does not work check compression.good luck
May 08, 2010 | Mtd 22" Yard Machine Push Mower
How to tight my drivimg belt in my push mower honda
The model shown 11A-034F200 is not a self propel mower. Now if you have a self propel mower, most of the time, the only way is either replace the belt or there may be a spring. I will not be able to tell you further without the proper model number.
Good Day.
Oct 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Self-propelled feature does not work at all! Any suggestions?
You might have a broken belt to the self propelled or a broken spring or whatever engages the self propel. Take off the cover and see if anything is broken or missing. Have someone engage the self propel while you are watching and see what is going on.
roundo4
Aug 12, 2009 | Toro Lawn Mower With Toro Power Tools
SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Mar 13, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd 22" Yard Machine Push Mower Logo
193 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
