Question about Cameras
Will the 2gb polaroid SD card work in my nikon D60. It is not listed in my user's manual as a approved card
  • bryant207 Apr 18, 2008
    The polaroid card worked fine.but I went ahead and purchased the new HC 4gb Ridata lighting series that worked a lot better for the Nikon D60. Although the older 4gb Ridata would not work it would not format correctly.
    President:
  • 423 Answers
I can't think of any reason why it won't. There are no compatability issues that I'm aware of with this card. The problem is that not every card can be tested (time, availability etc.), so only commonly available cards are tested. In the Canadian market, I've never even seen a Polaroid brand SD card.
Posted on Apr 09, 2008
Memory card
The D60 was released BEFORE HD SD cards came out. The 4 gig card MAY BE TOO BIG. HSD I think is the Nomenclature you may need a normal SD card. I think 2GB is as big as you can go but don't quote me.
Nov 21, 2017 | Nikon D60 Digital Camera
Nikon L110 won't accept SD 16 GB card.
Attached is a list of approved memory cards for your camera:
http://support.nikonusa.com/app/answers/detail/a_id/16781/~/approved-sd-cards---coolpix-l110
Jan 19, 2013 | Cameras
D60 has SD card full message but the SD card is brand new and formatted.
Have you tried using it in another device that reads/writes SD cards?
It's possible it is a counterfeit SD card. Some counterfeit cards don't work or are not the true capacity. If it it a name brand like SanDisk it will have a serial number. The counterfeit ones typically don't have serial numbers.
Sep 02, 2012 | Nikon D60 Digital Camera
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Nikon D60 memory card problem. When i turn my
check your sd card, there's a tiny bar on the side that you can "slide" to unlock...
Jul 10, 2009 | Nikon D60 Digital Camera
Polaroid i733 card error
The i733 works with SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it won't work. You need to go with SD cards, 2GB and smaller.
Jun 13, 2009 | Polaroid i733LP Digital Camera
Nikon coolpix 2100- out of memory- After installing 4gb CF card
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
May 24, 2009 | Nikon Coolpix 2100 Digital Camera
Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
Mar 11, 2009 | Nikon D60 Digital Camera
Nikon D60 Screen failure when SD Card inserted
You can try other SD card , or insert your SD card in other camera to check it out which part have problem first.
Jan 31, 2009 | Nikon D60 Digital Camera
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
Cameras Logo
80 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
