Question about Canon MX300 Office All-In-One Printer
The paper tray will not load the paper correctly, and nothing is able to print. please advise! thank you.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
Please service the printer
Posted on Jun 01, 2010
Also, the printer isn't printing as well a message comes up saying load paper and the tray is full. Thanks please help
Check that paper tray is fully open.
Check microswitch for paper tray.
Remove 1/2 of the paper - I ran into a similar issue with other brands before.
Nov 24, 2014 | Canon 2409B014AA LBP5050 LASER PRINTER...
I cannot figure out where to load legal sized paper into our Dell 3130cn printer? Can anyone assist me?
The handfeed tray normally opens from the front by pulling down on it. You can load any type of paper in this tray. Good luck.
Dec 12, 2012 | Dell 3100cn Laser Printer
How to Print Legal size paper in Canon IR2420L
I purchase the cannon IR2420L machine, But I cannot the legal size paper print. please load correct paper message display.Please help me. Thanking you.
Nov 30, 2012 | Canon Office Equipment & Supplies
41.3 unexpected size in tray 2.my printer is hp laserjet 4200.can you solve this
Thank you for contacting FixYa with your printer Inquiry.
41.3 Unexpected Paper Size Explanation
  • The printer detected a paper size different than what it was expecting.
  • This is typically caused if two or more sheets stick together in the printer, or if the paper tray is not properly adjusted.
Recommended action
  1. Reload the tray with the correct paper size.
  2. Ensure that paper in the tray is loaded under the front and back tabs.
  3. When printing from tray 1, verify that the correct paper size is selected in the control panel (see the Paper Handling Menu section in the User Guide ).
  4. When printing from tray 2, 3, or 4, verify that the three paper size adjustments on the paper tray have been made correctly (see the description of adjustments in the section on Loading Trays 2, 3, and 4 in the User Guide ).
  5. After performing the actions above, press GO. The page containing the error will automatically be reprinted if jam recovery is enabled. Or, press CANCEL JOB to clear the print job from the printer's memory.
    Hope this helps. Please keep us updated and remember to rate this answer.
Feb 07, 2011 | HP LaserJet 2420 Printer
When i replace with new original 818 color and black/white ink cartaiges the ink status show as b/w full and color iswith"x" mark(no ink) and printer can"t take paper i also re load the driver software
If there is an "X" on the color cartridge indicator then there is a problem with it. If you have removed the plastic tape that covers the part that connects to the computer and you still have this problem then the cartridge is defective and needs to be returned to the store and exchanged for another that is good. Exchange the cartridge and install the replacement. This should solve the problem with the printer not recognizing a full color ink cartridge.
You mentioned that the printer cannot take paper. Please clarify what happens when you load the paper tray and try to print? Are you loading paper one page at a time using the external feeder or are you loading the paper tray full with paper before trying to print? If your loading page by page or filling the tray with only a few sheets of paper then try loading a bigger amount of approx 1/2" of paper. It is easier for the printer to grab paper when the try has a good amount in it. If it still will not load the paper when the tray is full and inserted correctly, please advise what happens when you try and print - exactly? Does the printer respond to the print command sent from the computer? Does it make attempts to load the paper and then fail and stop? Does it pick up paper and then show a paper jam? Does the printer do anything when trying to print from your computer? Answer these questions and I will help you solve this problem right now.
Sep 27, 2010 | HP Deskjet 3420 InkJet Printer
Hi I have a Brother NFC-88404 Printer/fax and went to print off some address labels but it will not do so and yellow light flashing and says "check paper mp and insert paper". there is paper in the tray...
which tray is paper in? the MP tray is the manual bypass tray in front of machine. sounds like your software is setup to utilize the MP tray for the labels, which is the best thing to do.
hth
razors
Jun 22, 2010 | Brother MFC-8840D All-In-One Laser Printer
Paper tray?
Two possible solutions;
1) Check the settings in the printer driver for the default tray. The other user could very well have changed them and set tray 1 as the default tray.
2) Check the paper size settings in the paper tray. Pull tray 2 out and check the paper guides. Make sure the paper guide in the front and left of the paper tray are set for the correct media type (letter, legal, etc.)
The printer reads the tabs in the back of the papertray to identify the paper size. If someone moved it while loading paper the printer identifies another paper size and defaults into the tray that has the size of paper required to print.
Hope this solves your problem.
Nov 19, 2008 | HP LaserJet 4100n Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Canon MX300 Office All-In-One Printer Logo
97 people viewed this question
old marine
old marine
