Question about Roxio Easy Media Creator 7.5 for PC
Roxio Creator Classic 6.2.0.110; after dragging doc into data field and clicking the burn icon, message appears: "There are no supported recorders available. Make sure that your recorder is powered on and that all cables are properly connected. Also, make sure the latest version of the software is installed to ensure you have the latest drivers." I unloaded/reloaded from the Roxio disk, but same message appears; WHAT is it talking about? Thanks!
  • hikermann Jun 01, 2010
    Thanks ... but it seems @ roxio.com that Roxio Creator Classic 6.2.0.110 doesn't exist any longer when it comes to updating drivers .... unless I just don't know where to look.
    Sergeant:
  • 269 Answers
Well i would go out to the roxio web page and select either tech support or look for drivers and downloads, this is the only way you can be assured you have the most up to date drivers. sometimes the cd's are shipped with outdated drivers. follow the prompts it may delete the old drivers or just update them. then power your machine off wait 12 seconds and then reboot and try again. it is frustratring i know but you need to reboot to update your machine
Posted on Jun 01, 2010
In Roxio Creator 10, I attempt to burn a disk of a slide show. I receive an error message 8004520C When I check production it reports no problem. This is repeatable.
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
May 25, 2010 | Roxio Easy Media Creator 10 Suite
Not detecting a recorder in Roxio Creator 6 when I tried to burn a cd
Roxio 6 is fairly old software. What OS are you using it with? Do you have a new CD / DVD recorder? If so, there is a good chance it is not supported by the software. If you have a new drive, try getting the latest updates from Roxio. They are very hard to find so I include a link here
Mar 12, 2010 | Roxio Easy CD & DVD Creator 6...
ROXIO CREATOR LE DELL EDITION CAME WITH MY COMPUTER AND WORKED PERFECTLY UNTIL SEVERAL MONTHS AGO. I CAN BURN DVD'S, AND I CAN ADD PICTURES TO A DISC WITH PICTURES IF IT SAYS APPENDABLE. WHEN I PUT IN A...
there are alot of kind of cd brand, like, maxwell. princo, ech.... use the common cds or dvd brand. may this cause of cd only. not good quality..otherwise chech your cd room drive. maybe the lins can recognise try to change another cd or dvd room for testing only.. befor you buy or changing totally..
thank you
May 29, 2009 | Roxio Easy Media Creator 8 Deluxe Suite...
After successful download of creator 2009, cannot open to homepag
mine did the same thing, i called dell , they could not fix 7 techs tried and failed. so i went to http://support.roxio.com and download creator 2009 service pack 4 (52.5mb) u have to register it first, then download . follow the instructions . mine works now.
Mar 29, 2009 | Roxio Creator 2009 for PC
Error when attempting to write disk
Sometimes the driver that is used to burn CD's gets corrupted, you should try removing and re-installing roxio. The only other possibility is a bad CD burner drive, but these are dirt cheap to replace these days, you should easily be able to find one under 40$.
Jan 20, 2009 | Roxio Easy CD & DVD Creator 6...
Easy Audio Capture (Roxio Easy Media Creator 10 Suite)
I am a Roxio support agent.
Here is an article on troubleshooting audio:
http://kb.roxio.com/content/kb/MyDVD/000138CR
If you continue to have trouble, please contact support:
selfserve.roxio.com
Regards
David
Roxio support
Sep 20, 2008 | Roxio Easy Media Creator 10 Suite
Roxio creator 10
Roxio has included help files and tutorials that include step-by-step instructions.
a. Double-click on the "Roxio Easy Media Creator Home" icon on your Desktop.
b. Under the "Tools" section, click on "Help Center & Tutorials".
c. The links on the right side of the help frame will launch the appropriate tutorial or
manual.
Also, Roxio has posted flash tutorials on our support website. The website address
for online tutorials click here or go to:
http://www.roxio.com/en/support/emc/tutorials.jhtml
Thanks Roxio
Aug 27, 2008 | Roxio Easy Media Creator 10 Suite
Ok - the link I found for a fix for the error messages also seems to have fixed the problem with disks not being recognized! Apparently it is all linked to WMP 11. So....here's the link to the fix:
http://kb.roxio.com/content/kb/Creator/000058MD
Jun 25, 2008 | Computers & Internet
EZCD 5.0 and EZCD 6.0
I don't think that 6 and 5 are compatible 6 is an upgrade from 5. I have just 5 on one of my old XP computers and it works fine, but that's all I have. I went to the website and they are not giving any support for Roxio 6 anymore.
I will tell you that Roxio Easy Media Creator is fantastic. The things you can do with that are unbelieveable. I got it at Sam's Club for about $70. But I know that does not solve your problem.
Roxio 5
To burn data files, Open project selector, make a data cd, click data cd project. WhenEasy CD Creator 5 opens and you choose your files to burn, try this: Select Disc at Once Radio button, click okay and click burn.
ID Number: 000008GN Products: General Information
OS: Issue When burning a CD or DVD, you receive an error, burning does not complete, or your media is rejected. Resolution Burning errors can happen for a variety of reasons. Roxio has found that doing the following steps resolves about 80% of all burning issues. Please give all these steps a try and see if it fixes your writing problems.
  1. Update your drive's firmware/drivers. Most companies regularly update their firmware and drivers. If you are unsure what model your burner is and its firmware, click here to find out.
  2. Enable DMA. Direct Memory Access enables better efficiency of data. For more info, check how to enable DMA.
  3. The media. Check the following:
    • The disc is clean and unused.
    • The media is recommended by your burner's manufacturer or try a different brand, preferably a name brand, if you continue to have problems.
    • Make sure that media (-R/+R, -/+RW, dual-layer compatibility) is supported by the burner by checking burner's manual or manufacturer's website. This is especially true for some Blu-Ray burners which do not support CD-R/RW media.
  4. If your burner is external, make sure it is connected directly to the computer via USB/Firewire and not a hub or other other device like a sound card.
  5. Update to the latest PX Engine. The PX Engine improves compatibility with newer burners on the market.
  6. A reinstall of the burner's drivers may also help.
    • Windows XP: Go to My Computer and choose Properties.
    • Windows Vista: Go to Start --> Control Panel --> System and Maintenance --> Device Manager.
    • Click on the Hardware tab.
    • Select Device Manager
    • Expand DVD/CD-ROM Drives, then select your burner and uninstall it by right -licking on it.
    • Reboot.
Roxio 6
OrangefoodJSLib.events().registerNativeEvent("mousemove",document.getElementById("rating_img"),highlightRating); OrangefoodJSLib.events().registerNativeEvent("mouseout",document.getElementById("rating_img"),ratingExit); OrangefoodJSLib.events().registerNativeEvent("click",document.getElementById("rating_img"),ratingVote); Article Details ID Number: EE6000132 Products: Easy CD Creator 6.x Platinum Suite
OS: Windows 98 Second Edition
Windows ME
Windows 2000 Professional
Windows XP Home Edition
Windows XP Professional Edition
Issue Roxio does not recognize the blank CD/DVD media in the recorder drive.
Resolution Follow the listed procedure to ensure that the CD/DVD media you are using is supported by your CD/DVD Recorder.
On Easy CD and DVD Creator:
  1. Open Creator Classic.
    1. Launch Roxio Easy CD & DVD Creator 6.
    2. Click on the Creator Classic icon.
  2. Check the supported media types.
    1. Click on Tools on the top left hand corner of the window, then select Drive Properties.
    2. Under the Devices section, click on your CD/DVD Recorder drive.
    3. Under Supported Media, click on down arrow to see a list of supported media your CD/DVD Recorder supports.
    4. Ensure that media type that you are using is listed here. If it is not listed then your CD/DVD Recorder does not support that type of media.
On Easy Media Creator:
  1. Launch Disc Information.
    1. Launch Roxio Creator Home menu.
    2. Click on the Tools tab, then select Disc Information.
    1. Under Supported Media, ensure the media type is listed.
    • Reboot.
I do know if you have Roxio5 you cannot installed Nero 6 InCD, not compatible. Other than all of the above, I have no more suggestions. I am really sorry, wish I could work on your computer to figure out the problem. This is my specialty. Reloading computer and figuring out problems. It is so much easier hands on.
Good Luck
Mar 30, 2008 | Roxio Easy CD & DVD Creator 6...
Cannot Initialize API
1. Try to launch Creator Classic to see if it can repair the engine files. a. Double click on the "Roxio Easy Media Creator Home" icon. b. Click "Creator Classic" under the "Applications" section. c. The Windows installer should launch and ask you to insert your installation disc
Try this and see how it works, if it does not, contact me and give me more details
Mar 25, 2008 | Roxio Easy CD & DVD Creator 6...
Open Questions:
Roxio Easy Media Creator 7.5 for PC Logo
88 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
