Question about Ardisam Inc Earthquake Mini Cultivator
Viper engine on my earthquake tiller starts fine cold then dies after fifteen minutes and wont restart
  • 59 Answers
You probably need a new coil, if it is a 2 stroke then it will almost certainly be the coil. The defect is very typical and recognizable.
Posted on Jun 03, 2010
    New Friend:
  • 3 Answers
Low oil cut off switch could be acting up. Disconnect and see ifi ti runs. If not replace the carb and fuel filter. The viper engine is a clone of a Honda. http://www.ebay.com/itm/NEW-GX160-5-5HP-HONDA-ADJUSTABLE-CARBURETOR-WITH-FREE-GASKETS/121225345625?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D30002%26meid%3Df495007fc18649159ceb1009031e4fad%26pid%3D100011%26rk%3D2%26rkt%3D10%26mehot%3Dpp%26sd%3D261393057447
Posted on Apr 30, 2015
My carburator is getting gas but doesn't flow to bowl. Not starting, not getting gas
Go here and download the Instruction Manual for the tiller:
http://www.getearthquake.com/foundations/DownloadCenter/downloadpopup.asp?file=OM31320E.pdf
Looking closely at the carb, I see it is a very basic bowl and float type.
1) Turn off the gas vavle, so gas won't start leaking all over everything.
Simply remove the nut at the bottom of the carb, and remove the bowl by turning it ever so slightly as you pull down gently on it. Clean the crud out of the bowl, and then remove the pin (it just pushes through) that the float hangs from, and remove the little needle valve and wire holder that keeps it in place.
(study it very, very closely before you do this so you can reassemble everything back properly!)
Jam the end of the spray tube of a can of carb cleaner up into the seat of the valve and back-flush it. You may have to open the gas-supply valve to do this.
When the gas starts flowing, you've successfully cleaned the clog.
Turn off the gas-valve again, reassemble everything, do not over-tighten the nut on the bottom of the bowl, turn the gas back on, check for leaks, start the tiller and you should run just fine!
Aug 27, 2014 | Earthquake Rear Tine Rototiller with 196cc...
Today tilling with my new viper MC43 tiller, suddenly it just stopped! Unable to restart due to the starter rope, cannot get it to pull out. How do I fix? thanks
it looks like the engine has seized.try turning shaft at bottom of enginei if this is free .engine is ok. remove housing where rope is mounted and free it up....let me know how u get on.....john.
Jul 12, 2014 | Ardisam Inc Earthquake Mini Cultivator
My Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle just makes a squeeling noise and tines won't rotate.
Sounds like the belt is slipping. Have you removed the belt cover and inspected the belt and the tensioner pulley ? If your model is like mine the tension can be adjusted just below the handles by looseneing the nut where the cable goes into the cable sheath and moving the cable cover further away from the handle. That takes up some slack and will make the tensioner pulley tighter on the belt. If the belt is shot tension isn't going to help.
Try "google" with "earthquake 5070 manual" first option should be a PDF copy of a model 5070 manual. Will have diagrams on how to adjust the cables.
May 08, 2014 | Earthquake 6015V Rear Tine Rototiller
Problem with a tiller Earthquake viper engine either the carburator or carburator gaskets LBLSNMC43
The Viper Engine is a Honda clone. Try a new carb for $15 0n ebay. http://www.ebay.com/itm/NEW-GX160-5-5HP-HONDA-ADJUSTABLE-CARBURETOR-WITH-FREE-GASKETS/121225345625?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D30002%26meid%3Df495007fc18649159ceb1009031e4fad%26pid%3D100011%26rk%3D2%26rkt%3D10%26mehot%3Dpp%26sd%3D261393057447
Mar 04, 2013 | Ardisam Inc Earthquake Mini Cultivator
Earthquake tiller viper 43cc engine will not start
I have the same issue, I thought it was the carburetor so I cleaned it and put it back together, same issue, I put a new carburetor on it same issue, has great spark, if I spray carb cleaner into it, it will start and run for a few seconds even throttle up, but then it dies, and will not start again without carb cleaner spray, and fuel is fresh and properly mixed, very confusing indeed.
Apr 17, 2012 | Ardisam Earthquake Mini Cultivator 43cc...
I have a new Rear Tine Earthquake 6065 electric start 196cc rotor tiller. It runs 5 mins. then stalls and dont start. The first time i thought i was short on clean feul so i filled it. it ran about same...
see if it keeps running with the fuel cap a little bit loose. if so the vent hole in the cap is plugged up and not venting. this causes vacuum in the fuel system and starves the engine of fuel. good luck
May 25, 2017 | Ardisam 5.5 Hp Rear Tine Rototiller
Earthquake Viper 43C engines revs up and then quits
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Ardisam Inc Earthquake Mini Cultivator
Jeep liberty 2002 3.7when starting cold starts-stalls unitl hot
Check the temperature sensor feeding the ECU and O2 sensor.
Apr 12, 2010 | 2002 Jeep Liberty
Ardisam Inc Earthquake Mini Cultivator Logo
1,451 people viewed this question
Top Ardisam Garden Experts
Jay Finke
Jay Finke
lnbn1975
Wade Mobley
Wade Mobley
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
