Question about Onkyo HTR500 Receiver
When i turn hit the Standby/on button it goes from the standby with red light to nothing. could you help?
    President:
  • Onkyo Master
  • 1,114 Answers
The most common problem found on FixYa for Audio Videowhen i turn hit the Standby/on button it goes from - 2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
Only red standby light comes on,Hit power button on remote, light goes out,unit turns off and have to replug into wall to get red light on.
There would be some problem in the output amplifier stage. Thats why its going to protection mode.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 18, 2016 | Audio Players & Recorders
Samsung TV not turning ON. My email address is prk Please help... Much appreciated.
Its power supply I will tell you how to fix you need to get few things first
Jan 29, 2016 | Samsung Televison & Video
I got a used LCD1932 Lloyd's TV/Monitor. The top has a standby button, turns it on, but u hit same button to turn it off, it has red standby light that stays on, does that mean it's always on standby
It's normal; if the set do not show a screen at this time. The red light indicates that the set is in standby mode, and it will off, when you hit the standby button again, and the scree will get live.
Oct 15, 2014 | Televison & Video
Vivid mini hi fi wont turn on
when you plug it in it goes into stand by mode automatically, the LCD display will be lit and you can set the time but nothing else will function. you have to hit the on/standby button to turn it on.
Feb 04, 2012 | Audio Players & Recorders
My power light turns yellow instead of red i have to hold thepower botten to make it red
With the Wii system, when you hit the power button, it goes into Standby mode. That is the yellow light. In standby mode, the system draws a little bit of power, and it will go into a ready to play state faster than when Off. Holding the power button FULLY powers off the Wii system, and that will give you the red light. Hope this helps!
Feb 27, 2011 | Video Game Consoles & Games
Hi- we are having a problem with our ps3....it just started overheating....we forgot to open the door...I heard the fan kick in...so we turned off the ps3 to let it cool down....now the ps3 is running...we...
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
My ps3 stopped showing picture ,it was working i turned it on i saw user screen then nothing,already replaced video cord
try video reset
TV will not turn on
Hey guys this one is a no brainer when you push power button AND STANDBY LIGHT COMES ON NEXT PUSH THE BUTTON ON THE LEFT NEXT TO POWER BUTTON AND WALLA IT TURNS ON
Nov 11, 2008 | Televison & Video
Wii standby light
To be precise, you can turn this option off from the Wii System settings -> Wii Connect 24 -> standby connection -> off
When this setting is swiched to off, your console shuts down entirely and there is a RED light on the power button. There will be no need to turn off the console pressing the power button.
Jun 10, 2008 | Nintendo Wii Console
Onkyo HTR500 Receiver Logo
131 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
