Question about Norcent Technologies PT-4291HD 42 in. Plasma Television
No images. when press the start button, sound goes out but no image.
    President:
  • 1,099 Answers
you really need to do some testing here to see what happened. this is odd. something might be loose in the tv. you need someone to look at it in this case. do you have a friend or someone with electronics knowledge??
Good luck
Posted on Jun 01, 2010
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
I need discovery kids tm daisy clock manual
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between month/day/year/hour/minute. If it goes to the alarm setting instead of time setting, try again.
2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial near the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time)
Good Luck!
Jun 22, 2013 | Toys
Discovery kids rocket clock - no manual
I can't upload a manual but I can give you instructions:
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between m/d/y/hour/minute. If it goes to the alarm setting instead of time setting, try again.
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial under the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time) to change from 12 to 24 hr or vise-versa
Good Luck!
Dec 03, 2012 | Discovery Channel Discovery Kids - Rocket...
What do the top row of buttons on keyboard meanAZ56001 E5400
Hi! you may be talking about the function keys on your keyboard. Each button has its unique functions that may help you while using your computer. kindly check the images on the button, for example if the image on the button looks like a moon it means that button will make your computer go to sleep mode. all you need to do is to press FN+ the button with the moon image and that will do the job. You may also see sun image for backlight adjustment, speaker image for sound settings a square image for an external monitor that can toggle display from 1 monitor to another. Also, pressing F1 button while computer is booting up may take you to BIOS (basic input output screen) . Don't forget to press FN button together with the function buttons.
Jun 03, 2010 | Acer Aspire 5610-4648 Notebook
I have just purchases a 8018. It is default set at 3 mp. I have downloaded the manual and followed the instructions to change mp to 8. However, when the camera is turned off it goes back to 3. Is this...
15
Image Size
The image size and quality setting determines the number of photos that can be saved and the amount of
memory required for each photo. The higher the photo quality the more memory it will use up. The image size
and quality will also affect the maximum size you can print your photo effectively. To set the Image size:
1. Press the Menu button.
2. Press Right/Left button to select the Image Size mode.
3. Press the Up/Down button to select the desired image size.
4. Press the Menu button to confirm, save and exit to standby mode.
If this still doesn't work, press the menu button twice.
Jan 29, 2010 | Vivitar ViviCam 8018 Digital Camera
Samsung D900i Screen image sometimes reversed. Screen goes blank and image moves randomly
Hi
I can tell you how to solve the reversed image. With the camera running look on the side of phone where the up/down volume keys are. If you press up button you will notice image on screen change. I think the down button inverts the image? Up or down this should correct your inverted image problem.
With regards to people experiencing lines and blacked out screens this appears to be a phone fault.
Jul 15, 2008 | Cell Phones
Uploading computer screen to camera
Attaching Sound Memos to images In replay mode (including single replay, index replay and magnifying replay) you can attach sound memos (up to 60 seconds) to an image. The sound data is saved in WAVE format. 1. Select [sound_memo_icon_a70.gif (Sound Memo)] in the [play_icon_small_a70.gif (Replay)] menu.
sound_memo_menu_1_a70.gif sound_memo_icon_a70.gifappears
2. Select the image to which you wish to add a sound memo using the left_arrow.gif or right_arrow.gif button, then press the <SET> button.
sound_memo_menu_2_a70.gif The A/V panel appears.
3. Select [rec_button_a70.gif (Record)] using the left_arrow.gif or right_arrow.gif button, then press the <SET> button.
  • The recording starts and the elapsed time is displayed. Speak towards the microphone of the camera.
  • To stop recording, press the <SET> button. To restart recording press the <SET> button again.
  • You can add as many sound memos as you like until their total time reaches 60 seconds.
Feb 06, 2008 | Canon PowerShot A520 Digital Camera
Sanyo digital camera model- vpc5500
Playing Back Movie Clips
You can play back the recorded movie clips on the LCD monitor screen. However, the
sound recorded with movie clips can only be played back on a computer.
1. Press the button.
2. Use the four-way controller (����) to go
through the images until the movie clip you
want to play back is displayed.
�� To view the previous image, press the
four-way controller (��).
�� To view the next image, press the
3. Press the button to start playing back
the movie clips.
�� To pause or resume movie playback, press the button again.
Dec 25, 2007 | Cameras
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Norcent Technologies PT-4291HD 42 in. Plasma Television Logo
118 people viewed this question
Top Norcent Technologies Televison & Video Experts
Jaime Hernandez
Mat Taylor
Level 1 Expert
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
