Question about Kenwood VR-405 Receiver
How do i use the dolby digital
I just got the vr 405 from a freind and i cant use the dolby digital
  • Anonymous Apr 25, 2009
    I have the vr-405 system (since 2001) and after hooking up a play station 3 for the blue ray and my Samsung HD TV, I can not get the system to play the 5.1 Dolby signal. Any suggestions on how I can fix this?
  • 3 Answers
More specifically, you must use fiber optic (optical) cable. I've had this since 2000, believe me, I know.
Posted on Jul 22, 2008
You have to connect your dvd player to your kenwood receiver by using the digital port.
DVD ------------ Digital out
Receiver ------------- Digital input
Posted on Jun 09, 2008
Cant get sound from right and left rear speakers
Your source will determine the Dolby Digital capabilities. WHAT is on video 1 and is it Dolby Digital?
Jul 04, 2010 | Kenwood VR-407 Receiver
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
How do i get dolby digital to work on my kenwood vr0405 reciever?
Make sure your source is playing something that has been recorded in dolby digital, not all dvd's and tv boxes transmit dolby digital. what is your source?
Dan
Dec 27, 2009 | Kenwood VR-405 Receiver
Reear speakers not putting out sound
If the TV sound source is through stereo RCA cables you'll only get rear sound if you choose one of the DSP modes. A digital source might work as expected, IF you have things correctly set up for multi-channel.
Dec 26, 2009 | Kenwood VR-405 Receiver
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
I need the remote control code for a kenwood vr405
i need you 4 digits for the kenwood vr 405
Jul 11, 2009 | Kenwood VR-405 Receiver
Different Audio options from an older receiver
If your receiver has a multichannel input and the player has the multchannel output then that is the only way you can get surround sound from it with source inputs that it cannot decode, such as DTS. The player will then do it alone.
However, in the setup menu of the blu ray player you should be able to change the audio output to downmix to 2ch audio...at least you'll get to watch the movie.
Jun 14, 2009 | Kenwood VR-405 Receiver
Kenwood vr-405 receiver
I have the 405 as well. My TV has an optical out and I run that straight to the 405 optical input. I set the input selector to DVD/CD (not DVD)and presto! TV audio out my speakers. It all comes down to the audio connections on your TV.
Mar 23, 2009 | Kenwood VR-405 Receiver
I have a vr-405 5.1 channels reciever, I have it hooked to nanlog out on tv per tv manual,tv speaker r off,there is a dvd/vcr hooked into video 1 and it works on tv speaker, where do i hook into the...
try to be a little more clear on what you are trying to do.do you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Feb 21, 2009 | Kenwood VR-405 Receiver
Kenwood VR-405
more info would be nice. If you're using optical, make sure its securely in both the tv and your vr-405 receiver. I have owned the vr-405 since 2000 and i just purchased a sony 32xbr6. HDMI into the TV, optical out to the receiver, it sounds amazing!
Dec 01, 2007 | Kenwood VR-405 Receiver
Kenwood VR-405 Receiver Logo
215 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
