Question about Bose PMCII 035323 LCD Remote Control
Pmc settings are locked. there is a pad lock icon on but nothing in the manuel on it.
How do i unlock my Panasonic NN-SD787ST? All features work but want start and displays locked?
Press function pad then for child lock push pad 5, 1 in on and 2 is off this is from the manuel I have for A NN-S787BAS 787WA, 878WAS, 878LA, 787BA ETC. HOPEFULLY THAT HELPS
Jul 02, 2017 | Panasonic Microwave Ovens
How do I remove volume icon from the middle of my iPad screen?
You might try this...you can set your side button on upper left corner edge of ipad to either mute volume or lock screen (stop it from rotating). Check how yours is set...Go into settings>general>Use side switch to:
see if it is set on mute. If it is switch it to Lock Rotation. Now that side switch will lock or unlock screen rotation.
See if that might stop your volume icon from popping up. Good luck!
Apr 30, 2014 | Apple iPad 64 GB 3G Tablet PC
How do i unlock my videocon AC remote???i see a key symbol on the top right corner of the remote screen.
When not in a setting mode, pressing and holding UP & DOWN keys for 3 seconds,
the key pad is locked. After setting it, the LOCK icon will be displayed on LCD to
indicate that key pad has been locked and all the keys are disabled. At that case,
the remote won't send out any codes. The LOCK icon on the LCD flash 3 times,
0.5 seconds for ON, 0.5 seconds for OFF, and press & hold UP & DOWN keys for
3 seconds, the remote is un-locked.
Jun 26, 2011 | Heating & Cooling
How do I unlock the key pad? The display shows locked and I don't know how it locked.
Here you go.
The Child Lock shuts down the control panel pads to prevent
unintended use of the microwave oven.
When the control is locked, only the Vent Fan and Light pads will
function.
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound
and a lock icon appears on the display. Repeat to unlock and
remove the lock icon from display.
May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Weird display light above the power button
those are status indicator lights with the following info:
Indicator Icon Description Modular drive modular.gif The computer is accessing the modular drive. Hard drive hdd.gif The computer is accessing a hard drive. Caps Lock statusd.jpg Caps Lock is turned on. Pad Lock statuse.jpg Pad Lock is turned on. Scroll Lock statusf.jpg Scroll Lock is turned on.
Apr 16, 2010 | Gateway 450SX4 Notebook
KEY PAD LOCKED ON SO LETTERS COME UP WITH NUMBERS UNLESS YOU HOLD FN BUTTON DOWN CAT WALKED ACROSS COMPUTER WHAT DO I DO
It seems the cat activated the Num Lock key.
To deactivate it press simultaneously Fn +
Num Lock key.
The num lock key will be marked with 'Num Lk 'or with a a key pad icon the same colour of you Fn key.
Sep 06, 2009 | Computers & Internet
Ice and water won't come out dispenser
here is link to your owners manual subzero.com
and here are instructions for using the lock feature..
LOCK For Models 685 and 695, the lock feature is used to prevent unintended ice and water dispensing. When the dispenser is locked, all key pads on the glasswell are deactivated to allow cleaning or to prevent small children from using the dispenser. To activate the lock feature, hold down the LIGHT key pad on the glasswell until the key pad lights flash once and the red LOCK icon is illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was activated. To deactivate the lock feature, hold down the LIGHT key pad until the key pad lights flash once and the red LOCK icon is no longer illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was deactivated.
Thanks Peyton
Mar 02, 2009 | Sub-Zero 695/S Side by Side Refrigerator
DELL D600NFULLY CHARGED WHEN ON BUTTEN PRESSED NO ACTIVITY
The Caps Lock LED flashing indicates a Motherboard failure on the system
Jun 17, 2008 | Dell Latitude D600 Notebook
Bose PMCII 035323 LCD Remote Control Logo
53 people viewed this question
Top Bose Televison & Video Experts
George Scott
George Scott
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
