Question about Sony FD Trinitron WEGA KV-34XBR800 34" TV
T.v goes on no screen just blinking stand by light red
  • rcgish Apr 21, 2008
    I tried to turn my TV on this morning and it wouldn't come on, the stand by light blinks six times in a row then pauses for about 4 seconds. I have unplugged it and let it sit for while then plugged it back in and no change, It was working fine last night.
    Problem Solver:
  • 9 Answers
Go here http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=4
for my post #108 for a step-by-step solution with pictures. $21.83 is all it cost me. I fixed my own TV as many others on that forum have. Feel free to contact me at eclipsedave@yahoo.com if you run into difficulties.
-Dave
Posted on May 12, 2008
    Scholar:
  • 77 Answers
How many blinks between pauses?
Posted on Apr 09, 2008
    Problem Solver:
  • 15 Answers
The STANDBY light is flashing on the television and there is no picture or sound. Solution
t.v - sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Posted on Jan 16, 2009
Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
Dec 30, 2014 | Sony Televison & Video
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Sony KDL-40Z4100 standby light solid red, orange blinks every 4 sec, What part may have gone bad?
The red stand by indicates the set is in PC stand by the blinking orange timer is indicating the timer has been set or has an issue
Mar 13, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
My sony tv automatically goes into stand by mode and we have already changed the power supply as solution given by fixya .com
If the unit is playing normally then goes to stand-by, it could be also caused by the main board and or the ballast boards. If it is caused by the ballast boards, it should give you error code with the red stand-by light blinking 11 or 13 times. If the stand-by light does not blink a code, it is probly the main board.
I hope this helps,
Skyassoc
Dec 08, 2010 | Sony KLV32S400A 32 in. LCD TV
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Nov 19, 2010 | Televison & Video
Cannot get tv out of stand by mode..
upon hitting the power button, the red light showing on the front of the tv should flash a couple of times, the screen should come on and the light goes off..the red "stand by " light stays on and we cannot get the screen to come up..needless to say, cannot get to the menu to change any display options...any suggestions?
Apr 10, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV Goes to Stand-by mode
I don't have a solution, but I have the exact same problem
Mar 05, 2009 | Sony BRAVIA KDL-46W3000 Television
Sony FD Trinitron WEGA KV-34XBR800 34" TV Logo
237 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
