RCA HD50LPW165 50" Rear Projection HDTV Logo
Posted on Jun 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is my rca HD50LPW165 projection bulb replacement a "diy" job? I am aware my projection bulb failed. I priced out the bulb but times being what they are economically, I was wondering the difficulty (and instructions) of replacing the bulb myself.
Anonymous
Level 3:
  • RCA Master 5,138 Answers
  • Posted on Jun 01, 2010
Anonymous
RCA Master
Level 3:
Answers
5138
Questions
5
Helped
1003860
Points
13534
Replaceing Lamp is a easy job,just make sure you wear rubber gloves so you do not leave your fringer prints on it, Mats has Lamps for $99.00
1-800-628-1118 Go to Encompass Parts Distribution and look up your Model Number they might have free service manual you can print out online.1-800-638-3328
1helpful
What's your problem?DIY Rca HD50LPW165 50in 720p DLP HDTV Color Wheel
thats the 267888 color wheel which has been discontinued for several years now. However you can get your color wheel rebuilt by contacting the guys at www.tvrepairworld.com
1helpful
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
The t.v. makes a buzzing noise while running and 30 seconds or so after shutting down.Is this a problem with the color wheel?if so what is a color wheel,what is the price of this part.How much should the...
First ascertain that televsiion least is functional making possible reacquirng an alternate
Second, requiring an alternate television altogether least requuires repairs or malfunctions at prior date
Circumpsectively, ascertain that the televison least is within restorabilitiy make way to purchase new devices.
RCA scenium model hd50lpw165. lamp went out- replaced it but tried so many times to turn it on before realizing the bulb needed to be replaced that it locked up. what to do?
http://www.tvtechcenter.com/board/links/rca/ATC311%20Training%20Manual.pdf
OK above is a service and training manual this is what engineers use to teach engineers how to fix sets like yours Use this an you may be able to repair READ THE SAFETY INSTRUCTION FIRST.
1helpful
Need a color wheel for RCA Scenium HD50LPW165 50 in Rear-
that color wheel has been discontinued by RCA. Its the 267888 color wheel. You can get your color wheel rebuilt at the following link under color wheels.
http://servicemanuals.vstore.ca/
I have a 52 inch RCA DLP t.v. I have replaced the bulb but the picture is very dark. Has the light engine failed?
Chances are YES! Call Encompass Electronics for Price and if they have any in stock or visit on their website 1-800-638-3328 You can call UED is another outlet 1-800-648-6657
1helpful
Tv has sound but no picture
my rca hd model hd50lpw164 has no picture. some sound and a electrical popping noise.
supect the lamp is out.
where can i obtain new lamp and whats the cost.?
david
RCA HD50LPW165--No Picture or Sound
That chassis has had some issues with faulty capacitors on the power board which will cause the set not to complete the boot sequence. If you need additional info please let me know.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
