Question about U-Line Icemaker
I have a marine U-Line ice maker that had the condenser fan replaced at the end of the 2009 boating season - the unit worked at that time. The boat was put up for the winter and the ice maker does not work now that it's out of storage. The condenser fins are clean. It starts and runs for 1 - 2 minutes and then shuts down. After it's been off for about 10 minutes, I try it again with the same results. Any ideas? Thanks in advance.
4 Suggested Answers
  • 286 Answers
SOURCE: u line ice maker on boat
If this is a stand alone icemaker. Is the unit running? If not check the icemaker ejector blades to make sure that its pointing at 12 oclock. If not then you need to take the cover off the icemaker and turn the smaller gear counter clockwise.(remove cover by gently prying on the inside corners and pull at the same time) Turning it counter clockwise will turn the ejector blade. Once you get it to 12 the plug the unit in and turn on. Compressor and fan should come on. If the unit is running then make sure the fan is operating. Yes then is the compressor on? Yes > then you have a sealed system problem. Let me know if you need further assistance.
Posted on Jun 18, 2009
  • 286 Answers
SOURCE: ICE MAKER GETS COLD-DOES NOT PRODUCE ICE
Hi
Try turning the thermostat to a lower setting. (warmer) It might be set too cold and the thermostat isnt being satisfied. Usually this is all thats wrong with it. Temperature in bucket between 10-15 degrees.
Posted on Jun 19, 2009
heatman101
  • 43501 Answers
SOURCE: Ice Maker not making ice
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jun 09, 2010
How to winterize 175 mariner outboard motor
Take a look at these instruction videos.
How to Winterize an Outboard boat, step by step guide in ...
9k=? 11:25 https://www.youtube.com/watch?v=x217iM77Qjc Oct 30, 2012 - Uploaded by Warren Hardy A detailed step by step guide to winterizing your outboard boat motor for ... most 2-stroke outboards ...
Winterizing Your Boat: Step 2 The Engine & Lower Unit ...
9k=? 10:01 https://www.youtube.com/watch?v=5kiOms2f4gg Oct 6, 2009 - Uploaded by West Marine How to Prepare Your Boat for Winter - Step 2 in the five step process on How to Winterize Your Boat: The ...
How to Winterize a Four Stroke Outboard Motor - YouTube
9k=? 2:44 https://www.youtube.com/watch?v=PRBnwYk8_Yk Nov 7, 2012 - Uploaded by boats.com Four stroke outboard motors are by far the most popular on the market. But there's a lot of confusion about ...
How to winterize your outboard
www.classicglastron.com/gl-outboard-winterizing.htm For smaller outboards, the simplest way to flush your outboard is by using a large ... water or purchase a set of "ear muffs" (available at your local marine dealer).
How to Winterize an Outboard Motor - Adventure
adventure.howstuffworks.com/outdoor.../how-to-maintain-a-boat4.htm ... the winter and prolong its. Learn how to properly winterize an outboard motor. ... Buy lubricant, oil, and fuel conditioner at a marine store. Time: about 2 hours.
Jan 09, 2016 | Boating
HELLO I HAVE A ULINE WH95TP IN A BOAT WE HAVE IN FOR REPAIR AND THE ICEMAKER WONT GET COLD WAS WORKING BEFORE ANY THOUGHTS ON WHAT TO CHECK THERE ARE NO SCHAMADICS ON IT THANKS JOHN
Ice makers need refrigerant just like freezers and if it get too low it will quit working and probably burn itself out .call a refrigeration repair person and ask them to check it out .
Jul 30, 2015 | ULINE U Line Marine/rv Ice Makers Wh95tp...
Jabsco toilet fails to fill
Was the toilet "Winterized" last fall? If so, have you assured that any plug in the clean water intake has been removed? If NOT -- are you sure the pump has not been frozen and internally damaged by ice? The pump is a simple device which rarely fail unless its inlet is blocked, or the pump seals or body are damaged - usually by freezing.
May 10, 2014 | Jabsco 29120 2000 Marine Manual Marine...
We have a Jensen marine system that came installed in our Tahoe boat. Shortly after we got the boat, the left speaker stopped working. A few months later, the speaker came back. Then just before the end of...
This really sounds like a wiring problem. I would start from scratch, seeing as how it will be difficult to find the issue you describe. Also, if you can, solder your connections to the radio. If you used crimp butts they may not have been tight enough and vibrated loose with use of the boat. Hope this helps
Sep 04, 2011 | Jensen Car Audio & Video
Unit runs but no ice.in searay boat fan does not want to come on. Unit runs. .Live in chatham ont. canada. what to do. dave @beams56@yahoo.com
My unit turns on works for a while then shuts down, fan would not re-start every cycle, causing over heating and shut down, cleaned the fan, oiled the bearings, cleaned all the elec. connections, seems to work now.
Jul 15, 2010 | Raritan Icer-ette Ice Cube Maker
I have a 1990 Carver Santego boat and it has it's original u-line ice maker on board. This year I noticed that the ice maker was still staying very cold but stopped making ice. My husband checked to make...
as the fridge gets older the gas gets less efficient so regasing the unit may work, but, due to its age, you may find replacement more cost effective...and more efficient.
Jun 17, 2010 | U-Line Icemaker
Deflates..need glue
Try West Marine. They have lots of boat parts. I found one link for sealant:
http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/39520/377%20710%20888/0/Inflatable%20Boat%20Accessories/Primary%20Search/mode%20matchallpartial/0/0?N=377 710 888&Ne=0&Ntt=Inflatable Boat Accessories&Ntx=mode matchallpartial&page=CategoryDisplayLevel1&isLTokenURL=true&storeNum=5005&subdeptNum=10&classNum=133
If this isn't what you're looking for, search from their home page.
You can also look up you boat maker's website and get their recommendations.
Best regards, --W/D--
Aug 21, 2009 | Navigator RST Marine II 500 Heavy Duty...
U line ice maker on boat
Jun 17, 2009 | U-Line Icemaker
Hi
Jun 08, 2009 | U-Line Icemaker
Repeated transponder issues with the lowrance 320c fishfinder
Reading the manual it does say that there is a temperature range for these. I"m not sure where you live but it might be cold enough that it is damaging the transducer in the off winter months.
Jun 01, 2009 | Eagle Fisheasy 320c Fishfinder
U-Line Icemaker Logo
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
