Question about Garden
How to take bottom reel off? Want to put on plastic blades.
They just unthread, counter clockwise.
Posted on Jun 01, 2010
Front Left Hand Cutting Reel does not turn under load.
Yes its essentially a vertical rod, belt/pulley on top, through a bearing in the deck to the bottom where the blade is attached. You need a new one. Check home depot for parts or call manufacturer.
Sep 16, 2014 | Garden
When i put in a tape, i get a squeeling sound, and the tape won't play.
The only way is to take the top off and watch what the tape is doing! You might even see some object inside which should not be there!
Jan 05, 2013 | Mitsubishi HS-U560 VHS VCR
HS-U510(c) Recently the tape is not rewinding. When ejecting, tape not rewound from heads and gets caught in mechanism. Defenitely seems to be some rewinding problem as noise of gears grinding and...
The problem is in the idler assembly that runs the tape and reels it in on eject, the drive belt will probably need replacing that is attached to the assembly.
Mar 27, 2011 | Mitsubishi HS-U510 VHS VCR
How do i sharpen cylinder mower blades
I believe you mean to say a 'reel' mower. Normally and old fashoined push (non-engine powered) mower.
Most consumer reel mowers do not need to be sharpened. They do however have a knife bed that occasionally needs to be adjusted. It should have the thickness of a regular piece of notebook paper between the blades and the knife bed. (that is really VERY close) You can buy 'lapping compound' from an automotive parts store, and apply that to the bed knife, and then rotate the blades to provide a precise fit for all blades.
Commercial reel mowers, such as those used on golf course equipment are however sharpened normally once or twice a year. It requireds dismantling, and many courses send their blades to a central location for golf equipment, where they are placed on a computer operated sharpener for precision grinding. This cost several hundreds of dollars just for the grinding.
Nov 12, 2009 | Garden
How to adjust blades to cut evenly?
should be a screw iether side above the blade turn clockwize to close the gap between  the blades both sides should touch the cutting blade on the bottom you have to turn the centre blades by hand to make sure both sides are even but be careful not to catch fingers on the blades while turning
Oct 04, 2009 | Great States Corp. 16 In. Scotts Elite...
Frayed power cord on electrolux canister vacuum
1 screw in the front, two in the blower port. take them out and the top bezel comes off. one screw in the bottom and two on the top. need a flat blade screw driver to pry out the cord reel. 4 screws holds the sheild of the reel. take them out and there is a snap ring that hold the reel on the shaft. the reel assembly and drum spring comes out at the same time. 3 screws on the bottom of the reel holding a metal plate and there is also snap ring hold the spring on the metal plate take that off and will expose the cord connection. unhook the the cord and untie the knot and replace the cord and reverse the process
Oct 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Blade is now loose, unconected to the rod or spindle.
I had this same problem. This is fixable if you are willing. I repaired mine because I am stubborn and I bought mine used and had no warranty. I found that if you pull out the bottom of the coffee grinder you can access the inside motor assembly. * Note, that the bottom is designed to pull out a couple inches and it acts as an electric cord caddy. You must carefully pry it all the way out. It is a good idea to put a pencil mark for reference on the bottom of the coffee grinder that lines up with the bottom lid piece you are removing because you must install the bottom lid in the same orientation in which you removed it. There is a slot where the electric cord sits in as well so pay attention as you pull it out. It is likely you will just have to yank the plastic bottom cover out. This will probably snap an internal lock tab off the bottom cover, as did happen with mine, but it still sat securely enough back inside after the repair was complete for my liking. After you fix your blade you can easily just glue the bottom cover on if you damage your lock tabs and then just do with out the cord caddy feature.(thats for little old ladies and neat freaks any way) Now that you have the bottom cover removed, Look at the motor spindle, it is in the center of the bottom of the motor. There is a slot in it. Use a screwdriver in this slot to keep it from spinning while you grab the hard plastic cone that sits on top of the grinder blade. Try putting your pliers down flush to the very bottom of the grinder before you grip the blade assembly, as it will minimize any gouging of the plastic cone on the top of the blade assembly. There are no flats on this cone so you cant use a socket or nut driver. Spin thescrew-driver counter- clockwise until the blade comes off. The blade assembly is threaded on to the motor spindle and it comes off easily. I had to lay my grinder on the floor and kneel on it to free my hands to remove the blade. So it can be done alone. Now that you have the blade off you will see that the blade has worked itself free and is just floating around in the threaded cone. Now you can either contact Bodum and demand a new blade assembly or you can repair the blade assembly as well. I cut off the plastic cone and was left with a threaded insert, I was able to configure nuts and washers and reattached the blade without the plastic cone material. It may not be as prettty but it will never break again! Like I said I am stubborn......
Oct 04, 2009 | Bodum C-Mill 5679 Electric Blades Grinder
Need to know were the long spring on my sons spider man rod and reel goes
The long spring (only one in the reel) goes under the bail arm plate. To get it back in, remove the plastic cover plate on the side that pickes up the line (has a line roller on that side). The spring will fit over a small metal or plastic post and rest in a cavity at the bottom.
Screw the cover back on and you're good to go!
Best of luck
Mike
Sep 26, 2009 | Shakespeare Surf Fishing Rod and Reel...
Reel mower isn't engaging -- blades aren't rotating and cutting
Remove the wheels and check the gears inside.
It sounds like they are worn or sheared and need
renewing
Jun 05, 2009 | Great States Corp. 16 In. Scotts Elite...
Scotts 20" reel mower. Drive wheels will not turn blades any more. Blades turn freely, but will not be driven by wheels.
This is almost certainly a problem with worn pinion gears, which are unfortunately made of plastic. Replacements are just a couple of dollars, but you'll probably want to buy a few for each side in the event this happens again. The Scotts 20" reel mower is manufactured by Great States 1-800-618-7474. You can also find more information at www.reelmowersetc.com and the user manual for this particular mower can be viewed at http://www.reelmowersetc.com/2000-20.pdf.
Feb 17, 2009 | Great States Corp. 18 In. Scotts Deluxe...
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
