Question about Epson Stylus CX7800 All-In-One InkJet Printer
When I try to print from my PC the printer doesn't respond at all even though the cable is connected on both ends and the printer is turned on. Worked fine the day before.
  • grant
    grant Jun 01, 2010
    Any error messages on teh PC or printer dispaly- Possibly the default printer in the printer control has gotten changed by accident and you didn't notice- the computer would try and send the print job to the wrong printer, and the CX7800 wouldn't even know there was a job for it.
  • jbckkhamm Jun 01, 2010
    I checked that - the CX7800 is the default printer. The printer is acting as if there was a was a command sent to it previously that it can't ignore. I wondered if there was a way to reset the printer somehow. I unplugged it but that didn't help.
    Scholar:
  • 117 Answers
I assume you are using a PC- All printers have a list of pending jobs refered to as the print "queue"- it should open if you double click on the default ptinter icon in the printer list- it sounds to me like your print Queue has been paused somehow and all the print jobs are being "held" until you tell the queue to restart printing
Posted on Jun 01, 2010
Printer not responding
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 27, 2012 | Lexmark X3650 Printer
Power but not printing
Hi Linda,
Did you check if the printer is able to scan or does it makes photocopy? if the printer doesn't respond to any input follow below steps.
  • Power Drain:
  1. Turn the printer OFF using the power button.
  2. Disconnect the power and USB cable from the back side of the printer.
  3. Press and hold the Power button for 30 seconds and release the button.
  4. Connect the power cable and try printing.
  5. If the above steps didn't work try below.
  • Partial Reset: Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button. If you still see the issue try next level of reset.
  • Semi Full Reset:- Remove the ink cartridges; Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
Feb 07, 2012 | HP PSC Photosmart 2355 All-in-One Printer
Lexmark X4550 Scanner not working
  4. Reboot computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Printer not responding to print message order
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Sep 12, 2011 | Lexmark X2600 InkJet Printer
Hi, i have some problems with my ML-2010R, it doesn't respond to anything from the computer. when i press ON it makes the usual noises,eating and preparing for printing , but when i try to send a file...
try to use a new USB cable maybe the problem is on the cable this transfers the data from your PC to the Printer this is a common issue for printers. Or update your printer driver.
Sep 02, 2011 | Samsung ML 2010 Laser Printer
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
Printer error says no connection to computer, even though computer is connected and cables. connected. I have tried all the typical choices.
try this: 1) unplug the printed cable off the pc 2) uninstall fully the printer driver 3) get the latest version of driver ( make sure it is compatible with your win version) 4) install the driver w/o connecting the printer 5) restart pc 6) connect printer 7) follow instructions of "found new hard ware" ----- GOOD LUCK----
Jul 02, 2011 | HP Officejet J5780 All-In-One InkJet...
The printer is not printing any document
Hi
Please check
1. Do you have a printer cable failure?
The printer will not be printing if its not connected to the computer. Check that the printer cable connecting your printer to the computer is firmly attached at both ends. Apart from this cable, there should be one more cable which is the one connecting to the wall outlet.
2. In case it still not work after checking try resetting and printing.
3. Else please change the Data Cable if it is very old one.
Jul 22, 2010 | HP LaserJet 1300 Printer
When printing from the computer a piece of paper became jammed inside the printer; this has been removed but the printer still won't print even though the USB cable is securely in place.
the printer maybe still jammed. try to turn off the printer and disconnect it from the pc.
then turn on and connect it again.
if this not work, you can reset the printer somewhere.
CS.
May 18, 2008 | Computers & Internet
Not responding to print job
Connect what two. Computer and printer. Try reinstalling the printer. The cable could be defaulty and If reinstalling the printer does not work, I'll put my money on the cable being defaulty, happens all the time. Exchange it for a working cable. Let me know how it goes.
Cynthia
Dec 17, 2007 | Lexmark X1150 All-In-One InkJet Printer
Epson Stylus CX7800 All-In-One InkJet Printer Logo
105 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
