Question about Clairion SF-1624R Stand (Pedestal) Fan
Broken part AD-40SRM this is the model of my fan,the round thing which holds the two nets together(around the fan) has been broken,I am wondering if I can get one
I broke a shade on my harbor breeze lighthouse II ceiling fan, will you find the model number so I can order one?
Wrong way round, YOU tell us the model number and type and we tell you where to get the shade. You can see the fan in your house, but we can't. That makes it really difficult for us. Some shades are plain, some are fluted, some have patterns.
All is not lost though. Go here and take your pick. They all sell them including Harbour Breeze themselves..
  1. The Home Depot® - homedepot.ca‎
    Adwww.homedepot.ca/fans This ad is based on your:
    • current search terms
    • recent searches on Google
    Visit Google's Why This Ad page to learn more or opt out.
    Discover Canada's Online Source for Ceiling Fans & Lights. Shop Today!
.spell{font-size:18px}.spell_orig{font-size:15px}#mss p{margin:0;padding-top:5px}
Search Results
    Shop Ceiling Fan Parts & Accessories at Lowes.com
    www.lowes.com/Lighting-Ceiling-Fans/Ceiling-Fan-Parts.../_/N.../pl Harbor Breeze 2-Light Bronze Ceiling Fan Light Kit with Frosted ... Harbor Breeze Opal Round Frosted Glass ShadeHarbor Breeze Opal Round Frosted Glass ... Missing: lighthouse
    Shop Ceiling Fan Light Kits at Lowes.com
    www.lowes.com/...Ceiling-Fans/Ceiling-Fan.../Ceiling-Fan-Light.../pl Harbor Breeze 2-Light Bronze Ceiling Fan Light Kit with Frosted .... Harbor Breeze 4-Light Antique Brass Ceiling Fan Light Kit with Shade Not Included Glass or ... Missing: lighthouse
    Shop Ceiling Fan Globes & Shades at Lowes.com
    www.lowes.com/...Ceiling-Fans/Ceiling-Fan.../Ceiling-Fan-Globes-Shade... Shop a variety of quality Ceiling Fan Globes & Shades and Ceiling Fan Globes & Shades that are available for ... Sea Gull Lighting (2) ... Harbor Breeze Opal Round Frosted Glass ShadeHarbor Breeze Opal Round Frosted Glass Shade. Missing: lighthouse
    Amazon.com: Harbor Breeze - Ceiling Fan Light Kits ...
    www.amazon.com > ... > Ceiling Fan Light Kits Lighting & Ceiling Fans All Home Improvement Best Sellers Lamps & Shades Ceiling Lights ... Harbor Breeze Springfield II 52-in Antique Bronze Downrod or Flush Mount Ceiling ... Harbor Breeze 52-in Springfield Brushed Nickel Ceiling Fan with Light Kit ... Harbor Breeze Outdoor/indoor Lighthouse Kit Weathered Copper.
    harbor breeze light kit parts - Harbor Breeze Shop
    harborbreezeshop.com/tag/harbor-breeze-light-kit-parts/ Jul 25, 2012 - You can also have the option of choosing different lamp shades, or if in case ... The 52? Harbor Breeze Avian ceiling fan with a built-in light kit from .... has a style inspired by the clean, strong lines of a welcoming lighthouse.
Feb 01, 2016 | Dryers
I have an old Vornado floor fan (sits on pole which curls around to form base) and cannot figure out how to open it to clean. I've read through all the other questions, which indicate clips or screws....
Hello Johnsbrandt - I had the exact problem. As you note, the four slits are they key. They are tabs that hold the outer ring in place. Press them so that they no longer catch on the back ring, and you should be able to slide the outer ring right off. The outer ring on mine was somehow catching on the blade, plus it was dirty, so it was good to get this off. Hope this helps! Lance
May 11, 2011 | Vornado Circulating Fan
I am trying to open the outer casing of the vacuum
There is a push in type flat plastic switch trim cover over the metal housing surrounding the switch.. You must unplug the cord, gently pry around the trim cover and you will find a screw, an irregular one underneath holding the switch in place. DO NOT OVERTIGHTEN when reinstalling this one or you will crack the switch.
Once removed the rear housing will come off. Then you will see several new philips round head screws holding the front housing onto the vac.With all screws removed the housing should open easily but there may be dirty film inside holding the halves together. The fan shaft will unscrew revealing the fan, a spacer behind and perhaps two different spacer washers. Install the new fan hand tight, washers and spacers in same order...
Good effort figuring this one out. Please post back with results.
Oct 29, 2009 | Vacuums
Broke the flimsy support plastic ring - Need to order new one
i would do a tack together job on it,,
get some thick fuse wire and tiy it round inside the grill holes on the out side edge tiy each one together at about every inch apart around the grill that will hold the two grill's tight, then if you still have the broken plastic bits glue them back on using supper glue its cheeper that trying to get part that you may never find?
Oct 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
Fan dont work
I found a picture of your fans here
So I assume they are electric and not belt driven.
I can thing of the following things that may be broken,
1) Blown Fuse
2) Relay Switch Broken
3) Thermostat switch Broken
4) The fan motor is burnt out.
If it is 1) then replace the fuse. If it blows again you probably have a short circuit somewhere. Check the wiring.
There is a description here about the relay(s) and where to find them in your vehicle
Disconnect the power plug to the fan and run a wire from the positive battery terminal. If it spins up ok then it isn't 4).
That leaves the thermostat switch. I'm not sure how you can test that one. I suppose you could join the two wires together as that is what happens inside the switch when the coolent tempreature gets to around 205F This should turn on the fan.
I have read that the relay is two stage so I'm not sure how the thermostat controls this. Perhaps one fan starts and then the other or the fans are dual speed.
You will have to investigate and follow the wires around to locate all these parts but at least it gives you some ideas and some places to start. It may also help you narrow the field. Post again here with the things you have found and we may be able to help you further. :)
Doug
Oct 04, 2009 | 1997 Ford Contour
I bought an older unit Viking Ultra line range hood. I'm cleaning it and wonder how I should go about cleaning the blades of the squirrel cage fans. Thanks. Karen
I took the motor out of the range hood. There is a set screw holding the squirrel cage fan in place which I unscrewed enough to slide the fan part off. I then boiled the part in a deep pan with lots of dish soap. I then brushed away the remaining debris. Avoid using dishwasher detergent which is effective but seems to erode the aluminum.
Jul 07, 2009 | Viking Kitchen Ranges
Broken threaded plastic part to hold blade tight.Aloha Breeze Vintage Stand Fan Model 46051
Have you tried using the Evostik Superglue for Hard Plastics
It is brilliant for putting broken palstics back together again
May 25, 2009 | Tower Aloha Breeze Fan
Thread getting caught underneath
you need to replace your shukle that holds the tread bobbing below.it is either slack or broken . if it is slack then you tighten the little screw that holds a cover that gives the thread tension .if its broken then replace it.once the thread is slack below it will cause your thread to bundle up.
Mar 10, 2007 | Euro-Pro Shark 80 - 7133
Clairion SF-1624R Stand (Pedestal) Fan Logo
65 people viewed this question
Top Clairion Dryers Experts
Are you a Clairion Dryer Expert? Answer questions, earn points and help others
