Screen comes on for a second then goes black. It
Dell flat screen monitor comes on for a second then goes black. It says it is in power save mode, but when you hit a key or move mouse screen does not come back on
  • 128 Answers
Its just ur monitor setting or the setting in ur pc for stand by mode or power saver mode.
if u still could not figure it out pl say me which system u using(platform)
Posted on Jun 01, 2010
Hi ,My dell screen goes to sleep mode after a long wait of not being used, say an hour, ..............but the pc sleep is not set ? The message comes up to move mouse ,or press any key ,but this does not...
please check your monitor settings may be sleep time is defined there. secondly check your system sleep time again. and also check window power saving mode. may be your system goes to power saving mode.
If you like this rate me kindly
Oct 12, 2010 | Dell E153FP 15" LCD Monitor
The monitor comes on and then goes black.
Sounds like your LCD panel lamps are shutting down, this could be either due bad tubes, or more likely lamp driver power supply is faulty.
Jan 12, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
My LG flatiron W1943TB turns on, says analog power saving mode, goes black and then the power button flashes.. but the monitor is hooked up to my dell notebook bc my LCD died
Hi erin mckinle,
That is probably it's, uh, analog power saving mode. When the screen goes black and the power button flashes, make some mouse gestures or hit some keys that would not affect anything (try spacebar). That should bring up the screen. If you think it goes into power saving mode too fast, go to Control Panel --> Power Options, and change the values. Hope this helps.
Jan 02, 2010 | LG W1934S-BN 19" Monitor
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
My monitor screen goes black
The monitor is going bad. Either going to be a bad screen or a bad inverter. Also Since you tried it on another computer and its still giving you the same symptoms, you know the computers are fine. To be sure, try another monitor on your computer and if you get video on the new monitor then thats another way of verifying that the dell monitor is bad.
May 16, 2009 | Dell UltraSharp 2000FP 20.1" Flat Panel...
I only get power saving mode on my screen then screen goes black
inside the power pack is a pulse IC chip they fail and cause all kinds of havoc also caps can cause issues unaccounted for, I would start at replacement of the IC about 2 dollars on E bay, and replace any bad capacitors you can see, they look domed or are leaking color from the top creases. after that get back with me and we can either proceed or you can rate me fixya, have a great weekend
Mar 13, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell 17" flat screen monitor
When they stay in power save mode the logic board is usally the problem. Cneck out www.lcdrepair.us they sell all the parts for that unit.
Dec 10, 2007 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Computers & Internet Logo
477 people viewed this question
David Payne
David Payne
