Question about Maytag Refrigerators
The ice-maker in our side-by-side stopped working. the water filter is fine and everything in the freezer is still frozen. What could be causing this?
    President:
  • 1,218 Answers
Good day,
Many reasons for the failure. Follow this guideline. It will get you there.
The freezer must be at it's normal temperature before you follow these steps. The reason is there is a thermostat imbedded in the ice maker that shuts it down once the freezer rises above approx. 12 degrees.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on Jun 01, 2010
Replaced the water filter 3 days ago, no water now. Took filter off and it had so much pressure it almost blew out of my hand. Put old filter back on and same problem. Ice maker works fine.
the frig uses a dual valve and the foutain water is filter water the water line is frozen ( i think ) and if you warm up the freezer it will flow . try it and we'll go from there .. freezer tempt should be around 0 to 5 deg . also ck the water blater behind the crisper and see if its frozen and veg will also freeze . this may be caused by a bad dampner control between the freezer and the fresh food side. mm hope this helps . feed backk pls ..
Nov 08, 2010 | Hotpoint HSS25GFP Side by Side...
The water line was frozen (no ice being made and no water available in the door), so I took everything out of the fridge and freezer, let it all defrost, plugged it back in, now I have water in the door,...
Grab a blow dryer and aim it at the water tube that supplies water to your ice maker. More then likely it is frozen with ice and will need further melting to clear it out so that your ice maker will work again
Sep 14, 2010 | GE Profile PSW26P Stainless Steel Side by...
It's leaking
Mine was leaking from the front left freezer side. I removed the tray at the bottom and saw that there is a drain hole in the back. I removed the sheet of ice that was covering the drain hole and poured vinegar and hot water to unclog it. That was the problem all along! The drain hole was clogged causing the water to drip out of the front. Whew!
Jul 02, 2010 | Hotpoint HSS25GFP Side by Side...
Our ice-maker stopped working on the hottest day of the year!
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
klhggkllkg
Jun 01, 2010 | Maytag MZD2766GES Side by Side...
Ice maker working very slowly; as else working fine
Change the water filter if it is 4 to 6 months old.
Jul 29, 2009 | Frigidaire FRS23R4A Side by Side...
Ice maker not making ice
Sounds likw the water fill tubs is frozen shut, look where the tube comes into the freezer compartment and take a hair drier and thaw it out. Good Luck
Jan 07, 2009 | Kenmore 53642 / 53644 Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Whirlpool gold ice maker problem
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kitchen aid superba fridge - ice maker not working .. water dispencer is
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer Problem
The only thing I can think of is your icemaker heater is staying on. When your icemaker goes into a harvest mode, (dumping ice and then re-filling with water) there is a "U" shaped heater (located on the under side of the icemaker) that comes on to release the frozen cubes from the icemaker mold. If this heater is continuously hot, it will cause temperatures in the freezer to rise.
Oct 04, 2007 | Whirlpool GS6SHEXMB / GS6SHEXMQ /...
Refrigerators Logo
63 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
