Grinding Noise Hi I have a samsung HLS5687w DLP TV When I turn on TV it has like a grinding noise the picture Flickers light and then it goes dim it only makes a noise when picture goes dim. I've changed the lamp & ballast & gets no joy. HELP I'm lost. Dee
  • 8,617 Answers
Sounds like the light engine there are alot of problems with the light engines and quite a few have had a grinding noise. The only other possibility would be the color wheel. But I would lean heavier toward the light engine being the fault.
Posted on Apr 09, 2008
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
When the tv is turned on I hear a loud grinding like noise
May I know if the unit won't power up, has a three blinking led light at the front panel? Also, please check if the grinding noise is near the lamp assembly.
Mjsazon
Dec 01, 2011 | Samsung DLP HL-P5663W 56" TV
Loud grinding noise when the lightbulb is on
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming ,grinding,buzzing noises.
Apr 06, 2010 | Philips Magnavox 9P6034C 60" Rear...
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Tv went pop
All you can do is get it repaired or replace. Take the receipt (if you still have it) to the retailer you bought it from and ask about it. Alternative, phone Samsung (number is probably in the instruction manual that came with the TV, or look on their website) and ask if they can do anything about it.
Jun 10, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
TV grinding noise
A grinding noise in that model usaully means the light engine is defective or it could be the color wheel. But light engine is most suspect as there have been some issues with the light engine assemblies
May 11, 2008 | Televison & Video
Samsung DLP HDTV wide screen
Sounds like the colorwheel (used in DLP projection sets with a single DLP panel) is going bad, either the wheel itself or the bearings on the motor driving the wheel are starting to fail. I would recommend getting a professional to service the TV set.
Jan 11, 2008 | Televison & Video
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Televison & Video Logo
228 people viewed this question
Top Televison & Video Experts
