Question about Roper RS22AQXKQ Side by Side Refrigerator
Model RS22AQXMQ00 not cooling properly.freezer side frosting up
  • csmith427 Jun 02, 2010
    problem did seem to be dirty condenser coils also did a complete defrost by leaving power disconnected and doors open approx 4 hours wiil see what hpppens overnight
    President:
  • 1,561 Answers
Clean the condenser coils on the back of the freezer to see if that will fix the problem. Dirty coils will cause a freezer to run but not cool properly. Pull the unit away from the wall, unplug it and remove the panel that covers the coils. Use a handheld vacuum with a narrow extension to vacuum out the debris. Replace the cover and allow the unit time to properly cool before checking it.
Listen for vibrating noises that are normally caused by loose parts or feet that are sitting unevenly on the floor. Inspect the freezer for loose parts, removing the bottom trim piece and checking the feet of the unit. Turn the adjustable feet if necessary to stabilize the freezer.
Check for any leaking from the freezer. If you notice water puddles around the freezer, look at the condensation tube to make sure it is draining into the pan and that it is not clogged.
Try turning the cooling controls both up and down to determine a potential fix. This should cause cooling to occur or ice to thaw. If neither happens when the temperature is changed, it could be the controls, in which case you will need to contact a repair person.
Take care.
Posted on Jun 01, 2010
Back of freezer has frost and freezer wont cool to proper temp. icemaker etc also not working
Did you leave the freezer door open for a period of time while the refrigerator was running? Unplug and defrost the freezer manually with a hair dryer until all frost is removed inside and in back of the freezer. Reapply power and see if it will then cool/freeze properly. Let me know the results
APPLIANCE 911
Jan 10, 2016 | Samsung RH29H9000SR RH29H9000SR 36"...
I have a Whirlpool Refrig. model GX5FHDXVY04. The freezer is working properly but the refrigerator is not cooling. I noticed frost on the inside back panel of the freezer. I turned the temp down in the...
Many of frost-free fridges use fans to move a controlled amount of air into the upper or side cooling chamber, check for non-working fan or a stuck or malfunctioning damper control. Keith L.
Mar 02, 2012 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
I have a GE profile that is 3 years old ,side by side model # is PSC25MSWASS ,the problem about this frig is that frost build up in the refrigerator side the freezer is good,so the refrigerator is not...
If frost is building up on the REFRIGERATOR side and NOT the freezer side, then the cooling tubes could become blocked. I would first check if the cooling fan http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-PSC25MSWASS/0432/0165000/G0902008/00010?blt=06&prst=&shdMod= Item 922 is operating, if it is then I would check to make sure the the damper is opening or not it is Item 923 on the diagram. If both of them are function properly, then I would check the sensor http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-PSC25MSWASS/0432/0165000/G0902008/00008 Item 236.
Jun 14, 2011 | Refrigerators
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
Neither freezer or frig is cooling properly. The
yes you have a defrost problem.. whirlpoolpartssurplus.com free tech advice i can simply walk you threw the process i recommend you do not defrost intill you find the problem
Jun 24, 2009 | Jenn-Air JCD2389G Side by Side...
Refrig not cooling Freezer has frost build up on coils
Frost on the coils won't allow air to pass to the fresh food section, thus resulting in insufficient cooling. To eliminate this problem, you will have to get a new adaptive defrost timer ( small board ), and a defrost heater assembly.
Apr 26, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
FRESH FOOD SIDE OF FRIG NOT COOLING
i would take the back freezer panel off and see what kind of frost pattern your coils have.they may be frosted over and the begining of a defrost problem.
Mar 11, 2009 | GE GSH22KGM Side by Side Refrigerator
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Fridgedair side by side
what to you mean by defrosted fridg. was frost built up in freezer>? check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, OR you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Roper RS22AQXKQ Side by Side Refrigerator Logo
107 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
