Question about Mtd 22" Yard Machine Push Mower
Wont start put new spark plug in it and it start for a few seconds if we prime it a few times. so i think its not getting gas where it should
  • 177 Answers
Carby service
Posted on Jun 07, 2010
Pontiac 3400 misfire problem one new coil pack new plugs and wires on still running bad have too press gas too start now bad fuel mileage unburnt fuel smoke when engine starts for a few seconds then stops...
some of the cylinder wont get spark, faulty spark plug, wire or coil. To check pull all spark plugs out, plug them to the wires and put on the engine top and then cranck the engine to see which spark plug not giving a spark
Apr 16, 2014 | Cars & Trucks
Motor mower wont start
By tipping a 4 cycle motor on a lawn mower or any equipment, you have all the oil and gas running into the combustion chamber and sometimes the oil and WATER will get into the tank. It will need too have the spark plug removed, the engine turned over with the starter to blow the oill, gas, and water out of the cylinder(s), the plug should be either dried and gap reset, and the gas tank drained and FRESH gas put in it. Replace the spark plug prime with just a few drops of gasoline in the carburetor throat and restart and let run to dry evrything. NOTE: An oil change is recommended, too!!
Jan 14, 2014 | Garden
WE OWN 92 CAMARO RS 25TH EDITION IT WONT START ITS GOT FIRE POWER AND SPARK SO NOW WHAT ITS DRIVE ME CRAZY WHAT TO DO. WE CHECK THE SPARK PLUG AND BATTERY AND ITS GOT GAS BUT IT WONT START WHAT DO U THINK...
92 Camaro, V8 5.7 multi port, new pump, good preasure. runs when primed, wont start without prime. After sitting a few minutes, engine fires wont start. How to check EGR Valve and what does it do?
Feb 15, 2011 | 1992 Chevrolet Camaro
Snow blower 1 year old, was using it ran out of gas , put in new gas, went to start, it ran for few seconds then dies,, prime it it runs few seconds dies, has NEW gas ans new plug, only runs for seconds...
If it has a fuel filter on it change it and that should get you going again. If not the dirt that was in the tank is prob in the carb cleaning the fuel bowl and jets should get you up to par. Hope that helps
Feb 02, 2011 | Sport & Outdoor - Others
I have a craftsman push lawn mover it will run for a few moments and then it will cut off. It also used to start with just one pull of the cord and that is no longer the case. Why do you think it wont...
check to see if it has a fuel cut off switch if so turn it on but if not check to see if the cabuerator is getting fuel if it has a prime button on it push it a few time too put fuel into the cabuerator then strat it up if it start to go dead then work the chocke but do not countiue prime the cabuerator bcuz u will flood it out if u cant get it to work still check ur spark plug to see if it has filed out if so replace it.
Sep 12, 2010 | Parks Optical 13.5hp Briggs And Stratton...
No spark on yamaha dtr 125cc
Sounds like you are flooding the engine with gas. Put in a new spark plug then twist the throttle one time to prime the cylinder. Now get your hands off the throttle and give it a few kicks. Each time you twist the throttle the power valve gives a shot of gas. Too much can flood the engine quickly.
May 17, 2010 | 2000 Yamaha DT 125 R
Looking for owners manual for coleman powermate 4000
Hi
First you need to change the plug with a new one with the same heat range(too long time).Priming the engine few times(put some gas in the cilinder through the plug hole)and start the engine until it runs constantly.
bestregards savumihai71
Feb 06, 2009 | Coleman Powermate Premium Plus 6250W...
Wont start
Start with emptying the gas tank totally. Refill with fresh gas/oil mix. Todays gasoline ain't that great.
Also after putting in fresh gas and priming if it doesn't fire at all pull the spark plug and if it is dry, pour a about a tbsp. of mix gas in the plug hole. put the spark plug back in and see if it will fire.
Phil
Dec 07, 2008 | Garden
Mtd 22" Yard Machine Push Mower Logo
113 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
