Question about Maytag MZD2766GES Side by Side Refrigerator
Our ice-maker stopped working on the hottest day of the year!
It does not make the usual "noises" you hear all the time when the ice maker is working. There is no problem getting cold water; just ice. The water filter is fairly new and the "change filter" light is not lit up. Everything in the freezer remains frozen--it appears the temperature is fine. I cannot locate the manual, so I don't know what to check.
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
klhggkllkg
Posted on Sep 30, 2010
Kenmore refrigerator making high pitch noise top front
could be the ice maker or the evaporator fan motor.you can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
Aug 19, 2012 | Refrigerators
I have had the GE top frezer a little over 2 months...Afew weeks ago I noticed a noise starting , a kind of weird noise....(its not the ice maker....I turned that off a week ago and it still does it....the...
Sounds like the defrost timer doing its job but with loud efforts. GE is known for its different sounds some clanks to clicks to popping. Thank God for good hearing but curse GE for its poor noise reduction efforts. This is why GE is cheaper than its other competitors. They cut corners welcome to the world of GE. BB
Dec 15, 2009 | GE Refrigerators
Our fridge is a little over 6 years old and everything has worked fine until now. Earlier in the day I was able to fill up a glass of water no problem but now no water is coming out of the dispenser. The...
Usually that is from the water line freezing up. Behind your refrigerator drawers there is either a plastic tank or a coil of plastic tube........That is where the water runs so your dispenser puts out chilled water. If your fridge gets too cold that will form ice inside and stop the water from flowing. You can defrost it with a hair dryer or just let the fridge sit open for a few hours. Another thing could be the water valve. When you press the water lever on the dispenser do you hear a noise? Kind of a humming noise. Well, that is your water valve, so if you hear it then it is probably working.
Sep 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker Quit Working
Replace the whole i/m - it is bad. Takes 5 minutes to do. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | GE Monogram ZISS420DRSS Stainless Steel
Refrigerator is making a loid noise
** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
Mar 10, 2008 | Refrigerators
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag MZD2766GES Side by Side Refrigerator Logo
151 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
