Question about Vizio L32 32 in. LCD HDTV
Tv will not come on and the vizio that is usually displays a orange light does not work either. no sound is made when you try to turn on the t.v. either
    President:
  • 1,099 Answers
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Jun 01, 2010
I plug in my Vizio TV and it will not power on however the orange light in the front is flashing.
Sounds like mine I replaced the Bridge Inverters ( easy job ) , and worked great after that. I got mine from Shop Jimmy dot com paid $85 cheap fix not like $300 - 500 ! you may pay for repair man.
Jul 23, 2014 | Vizio VO420E 42 in. LCD TV
I have a vizio vx37l was working just fine, went to turn it on and will not come on now. The vizio is orange touch the power button it turns white then back to orange .
That sounds like one of the shutdown circuits of the tv is activating. Most likely would need a tech to repair for you. You could try to power cycle the tv to see if that helps, just unplug the power cord of the tv, wait a few seconds then plug it back in and try to turn the tv on. Would be similar to rebooting a computer.
Mar 16, 2014 | V, Inc. VIZIO RP56 Rear Projection...
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
When I turn our tv off the vizio emplem stays orange
According to the manual. It says The Vizio lights white when powered on and orange when powered off.
Mar 03, 2010 | Vizio VW42LF 42 in. LCD HDTV
The LCD screen is dark with no sound or picture when turned on.
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Oct 17, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
I had some water from my plant dripped in my 32 inch Vizio LCD tv. Th e tv was off when this happened, so I try to turn it on and nothing happened. I try to dry it out with a blow dryer on warm heat. It...
You should let it sits for at least 72 hours. does the TV have a orange Vizio logo light when you plug in the power? what about when you turn it on, does the Vizio logo light turns white? if yes to these two questions and you still does not have picture or sound, it could be your main board or inverter that got fried.
Jun 22, 2009 | Vizio L37 Television
Vizio screen went off but power light is still on
may be a mainboard problem. If you can see the orange light it usualy means that there is power running through the TV... usually inverter boards are a problem when you do not see any backlight at all.
May 06, 2009 | Vizio VW37L 37 in. LCD HDTV
No picture but sound
do any lights come on with the TV?, like white vizio or orange vizio light. sounds like a problem with the power board. some vizio parts have lifetime warranties so contact vizio support and report your problem. if it is covered the service call is free. there is a green led light on the power board that should come on, if it is not on, you may have a bad power board. to see this light on the power board, turn off the lights in the room and view the tv from the back cover, power board is 3/4 way toward top in the middle of the tv
Mar 26, 2009 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
163 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
