Question about Dishwashers
My Diplomat Dishwasher has had the "In Progress" light on for about a week and as a result it will not let me put a load of dishes on to wash. Turning it off at the wall does not help.
  • ellybendi Jun 01, 2010
    This is a fitted Diplomat and there is no side panel
  • 12,061 Answers
Http://www.haier.com/admin/en/product/upload/ADP8352-UM.pdf
Dishwasher Repair Guide: How To Fix a Dishwasher - ACME HOW TO.com
http://www.servicematters.com/maytag_library/docs/16010622.pdf
Hi, well i have found you a manual, a service manual and a self help troubleshooting website. Please perform the troubleshooting procedures, and you should be able to isolate and hopefully remedy your issue.
Posted on Jun 02, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. There is a reset button on the bottom left hand side of your Dishwasher. You’ll need to unplug the unit and then under the door on the bottom left hand side, when you take the panel off, you’ll see a timer button which you should rotate manually clockwise so that the unit works. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 01, 2010
  • Rylee Smith
    Rylee Smith Jun 01, 2010
    I never said side panel, I said its the bottom left hand side which means you need to check at the bottom.
  • ellybendi Jun 05, 2010
    I unscrewed the panel and turned the orange knob which requires a 6-pointed star-shaped key. The machine made some noise and stopped again. I cannot get it to do a full cycle however. It still has the "In Progress" light on.
We have a Bosch SHU3307UC dishwasher. Two friends swear by theirs, saying they put everything in dirty and the load always comes out clean. That does not at all work for us. My wife has to just about wash...
Put dirty stuff in will eventually keep a tech like me very busy. We love to come and charge you alot for cleaning your dishwasher. Remember the Maytag commercials where they put a cake in it? Still got the dishes clean but before long it will cost you big time. Just run everything under the tap. Pot and pans should be lightly washed also. Watch how you place the dishes. Most dishwashers spray up from the bottom. Block it, and the spray will not reach the top.
Nov 28, 2010 | Bosch 23 in. SHU3307UC Built-in Dishwasher
When we open dishwasher theres standing water in the drain area and it smells bad this is after washing aload dishs look clean but inside stinks
After you run a load of dishes put 1cup of CLR or vinegar (white) and run a quick wash.no dishes,after running dishes clean out spray arm and clean strainer,use a rinse agent like finish, and spray off dishes before loading.About 35yrs. ago I use to be a dishwasher as one of my first job's and if you did'nt spray the dishes and scrap them off before loading,the dishes would not come out clean,And after each shift the dish washer would be cleaned out.
Aug 04, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Frigidaire Dishwasher problem
The problem is hard water. There is a new product out called the dishwasher2_bing.gif filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jun 13, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Film on all surfaces after wash.
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info. You will love the results!
May 06, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
My Diplomat built in Dishwasher fills with water and heats it and empties, however the water does not get sprayed thru the arms and the dishes remain dirty. Any suggestions on what the fault is and what...
The most common cause for no washing is a failed wash pump motor. Which is probably the single most expensive part to have replaced on a dishwasher.
Aug 11, 2009 | Dishwashers
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
DIPLOMAT DISHWASHER FILLS AND EMPTIES WITH NO PROBLEM BUT.... THE WASHER ARMS WILL NOT TURN AS NO WATER IS GETTING TO THE ARMS TO WASH THE DISHES ANDBODY GIVE ME ANY HELP PLEASE
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Check the manifold as well for clogs.
Another spot will be a malfunctioning wash impeller. i would inspect the wash impeller as well. it is responsible for the flow or water during the wash.
Jun 17, 2009 | Dishwashers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
Owen Barnes
