Question about Acer Aspire 5600 Series 5630-6951 Laptop
Aser 5600 horizontal line problem
Hi there thanks for your response. Is this board on the motherboard or on or in the lcd.
  • ldnleaf
    ldnleaf Apr 09, 2008
    Turns out the problem was just a screw on the heatsink that needed snugging up.
    Genius:
  • 1,226 Answers
Hello again,
since that the Laptop LCD is directly connected to the BOard. you have to check the board in lcd and connecting to the board of the motherboard. verify also the video card. of the laptop.
mlenavz
Posted on Apr 09, 2008
  • Anonymous Apr 10, 2008
    hello again,
    please rate me a good rating. thank you.
SOURCE:
How do I fix my Sharp tv model LC-42D62U? On the tv screen now shows horizontal lines with repeating ghost images.
Hi Paul,
The horizontal lines on the screen are virtually NEVER caused by a bad T-con board. These horizontal lines indicate a defective LCD panel (screen). The Screen has small ICs that become defective overtime and that it isn't fixable unless replacing the entire screen.
Sep 13, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hey I got an IBM T42. It boots fine when its clear but after that it horizontal lines being to appear througout the scree.
Either you can hook up an external monitor or access BIOS setup (Basic Input/Output System) to replicate if the horizontal line appears. This step will check if the problem is with the video card or the LCD.
If you get the horizontal line on the BIOS or never get it on the external monitor, then surely the LCD screen is beginning to fail. You need to reinsert and/or replace the LCD inverter or LCD itself.
However, if you see the horizontal lines on the external monitor but not on the BIOS, try to update the video driver. If this will not resolve the issue, you need to replace the video card or the motherboard of your laptop.
Hope this helps.
Jun 06, 2011 | IBM ThinkPad T30 2366 Notebook
Screen is black, shows no image. Sometimes it flicks and sometimes presents a lot of horizontal colored lines. Once or twice the screen worked for a couple of seconds, saw the windows' logo and then it...
HI,
Do a power drain, this may cause by an electrical charge in the motherboard itself,Im Not really sure how it affects the display of the computer but this method usually fix such problem like that, First, removed the battery then unplugged the AC adapter the press and hold the power button or the ON/OFF button for at least 30 seconds then connect the power supply back to your computer then turn it back on, if nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
Hope this will help...Your response is very much appreciated...
Feb 08, 2011 | Toshiba Satellite L305-S5875 Notebook
Horizontal lines on ASUS laptop screen
HI friend
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is Motherboard problem Please contact Your nearest service centre for Service.
Jul 15, 2009 | ASUS VW222U Monitor
Horizontal screen lines on acer aspire 5600 (5602WLMi)
Hi Cola;
How long have you been using your acer? is that a laptop or a desktop? is its a desktop, are you using a video card? if you are, remove it and use the on board video instead,to check if you have the lines.
May 19, 2008 | Acer Computers & Internet
Aspire 5600 gets horizontal lines on lcd
The horizontal line means that there is a loss connection in the horizontal projection of the monitor. This can be resolved by fixing the horizontal panel board that gives error. this require quite expert in the LCD troubleshooting. However, if you believe that you can do it, ok you may proceed.
please donot rate me if this not solve the problem. because i need more higher rating. just notify if you need more solution am here to assist. melnavz
Apr 09, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
TV - Thin horizontal line picture on screen
Is this a LCD TV? IF it is it could be something on the video processing board. Let me know the model # and well will go from there. Thank you Jay
Jan 31, 2008 | Televison & Video
Philips 42PF7320 42 in
you have a bad display call a tech to conferm this it could also be y buffers
Dec 03, 2007 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Acer Aspire 5600 Series 5630-6951 Laptop Logo
66 people viewed this question
Ekse
Alun Cox
