Question about Jwin JX-M20 AM/FM Radio
There is a key on the screen and dont know who to un lock it?
04 Toyota Sienna my locks will not unlock manually with my key but did when I bought it what could be wrong with it
if you dont use them and use the remote to lock and un lock they will seizes up. takes a bit more efford to turn the the lock.
Jan 21, 2014 | Cars & Trucks
Key wont dis engage anti theft and dont have electric un lock car wont start cause of fuel cutoff
Most auto parts stores have a device on the counter to check the actual key assembly to make sure it is transmitting. Some have batteries. Start there.
Nov 28, 2013 | Volkswagen Cars & Trucks
How to Un-lock a Evorea Tab
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 04, 2012 | Cell Phones
How to lift the seat
Dont know which model suzuki you have, but if its a GSXR with a split seat, I believe the lock for the seat is on the left side just under the passanger seat. Insert key and turn it to un-lock. While holding the key in the un-lock position, lift up the drivers seat where it splits from the passanger seat. from there, you can remove the passanger seat. Most other models you turn and hold the key in the un-lock position and lift up the back of the seat. On older modles, you turn the key and lift the seat from the side.
I hope this helps..
Jan 05, 2011 | Suzuki RV 125 VanVan Motorcycles
Keyless Entry and Remote
I have had this problem take you drivers door put your key and un-lock from the out side with key (NO) then open the door push un-lock from the inside button and then set from you remote and it should set if not push un-lock then lock and then do the un-lock with the key. Let me know if that works. what my car did was locked from the inside and I had the problem were it would not work till I un-locked from the out side plus I had to go to radio shack and change the battery from the control.
Hope good happens.
Nikki2913
Oct 22, 2008 | 1996 Ford Explorer
Key board
Press and hold the blue fn (function) key then press the nmlck(numbers lock) key. This enables or disables the numeric key feature.
Jul 23, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Locked tv
What is the make and model number of your flat screen tv.
Mar 11, 2008 | Televison & Video
MY LG DVD/VHS DC593W SHOWS A RED KEY I CANT PRESS ANY OTHER BUTTONS ON IT BESIDES USING THE REMOTE,,,PLEASE HELP
Simple solution.
Press the C.Lock key on the remote.
This key tunrs on and off the child lock feature.
cheers.
Jan 08, 2008 | Televison & Video
Jwin JX-M20 AM/FM Radio Logo
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
