Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water dripping all the time in refridgerator what could be causeing that?
    Novelist:
  • 77 Answers
You have a top mount refrigerator and this is a normal problem. What you have is a clogged up freezer drain, and instead of water going down the drain it goes down the air vents into the frig! Here is what you do.
The drain is behind the freezer wall. Unplug the refrigerator first. Then you need to empty out all the food in the freezer. The screws holding the back wall in are generally 1/4 inch nut driver and phillips head screws. Take out the screws and the ice maker if you need to.
The drain is in the back on the bottom, and probably under a bunch of frozen ice. Just be careful not to damage the freezer, but chip away with a flat blade screwdriver, or just use the hairdryer on it all. You will need to soak up the water with a tower, there will probably be a lot. Next, you need to thaw out the drain, this can be somewhat difficult. Simply blowing hot air doesn't do much good, because it's a small hole. I take some 1/4 inch plastic water line and **** the water out. Then I pour HOT water (from the microwave) down the drain. I let it sit a bit and then I **** it out and reapply.
This process should get it clean. Also, once it's free, I take the 1/4 inch plastic water line and stuff it down the vent a LONG way and make sure any obstruction is removed. Now just put it back together!
Posted on Jun 02, 2010
Water leaks
Need more information
Does the refridgerator have plumbing for water/ ice? Is the water connected? Check that fittings are tight and not leaking.
How old is your machine? Older refridgerator have a drip pan in order to be frost free. Drip pan could be not in correctly or the hose from compressor is not flowing to drip pan.
Is the refridge level?
Oct 15, 2015 | Whirlpool Refrigerators
Water is draiNung in the refridgerator
drain tube for freezer defrost plugged, you will have to remove of the inside trim but an easy fix
Sep 02, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping sound coming from new refridgerator
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan. This is the only source of water if nothing else is connected. Are you seeing and water anywhere.
Jan 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridgerator ice maker leaking water
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Aug 17, 2009 | Whirlpool ET4WSKXS Top Freezer...
Do I need to empty the water from my drip pan
the pan is there to catch condensation from the compressor during the refridgeration cycle. the water build up to me indicates one of two things. Either the refrigerant level is low and it is freezing up then thawing, or if you have ice or water dispencer it could have a leak in the line. the only thing other than that is a leak in the magnetic door seal or other insulation causing condensation. hope this helps
Jun 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Why does my maytag fridge drip water around the freezer door?
Freezer door frames have a small heating element in them to stop that happening. Your element is failed.
Torn gasket seals just cause frost inside, but also cause the compressor extra stress if the seal is bad. This causes the compressor to keep running as yours does. They are cheap to buy and easy to fit.
With a 12 year old one, it is probably time for a new one. The new ones are more energy efficient and are cheaper to run.
Mar 23, 2017 | Sub-Zero 650 / O Bottom Freezer...
WATER LEAKING FROM INSIDE BACK OF REFRIDGERATOR SAMSUNG 267LASH
The frigerator has a drip pan it may need to be empty. Check the water line for leaks going into freezer.
Apr 11, 2009 | Refrigerators
Ice maker leaks
soundslike the water valve is notcompletly shutting off, causing a slow drip try replacing the water inlet valve behind hte unit where the water installs to the refrig
Nov 20, 2008 | Amana ACD2232HR Side by Side Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
87 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
