Question about Car Audio & Video
Me da error 13 en el display del car stereo Pagoda pgd 800 y no me lee en USB
  • 109 Answers
SOURCE: Error code 13 on my car stereo
I visited VR-3.com and found the following in the manual: Problem: MP3/WMA Files on the USB/SD flash memory do
not play.
Answer: Flash memory is formatted as NTSC.
Format the flash memory as FAT or FAT32.
The files have Digital Rights Management(DRM).
If the files you are attempting to play were
purchased online, they may have Digital Rights
Management, this unit is not DRM compatible.
You may want to call VR3 at (800) 445-1797 and inquire about that specific code just in case though the answer above was not given as "error 13" I just made an educated guess based on the problem given.
Posted on Aug 19, 2008
SOURCE: Error al instalar driver de scanner HP Deskjet F380
hi dear
i need ho deskjet f380 All in one
thanks
Posted on Sep 23, 2008
mrgreenz
  • 962 Answers
SOURCE: Mazda 626 a?o 2001, no enciende el motor.
Que code le dieron quando probaron la computadora ? PO..? mire aver si tiene lumbre en las plugas de sparke. Quite una de las plogas y pongala contra un ground de metal. lleve a alguien que le de vuelta a engenio. debe de tener una lumbre fuerte. Si no, puede ser que algo que ver con el coil o algun sensor. .
Posted on Nov 26, 2008
SOURCE: amplificador panasonic modelo sa-he7, se pone en error f70
rafatecnico amigo mio el error esta en la placa de coneccion de dispositivos auxiliares por favor revisa soldaduras de los dos transistores de potencia que se encuentran juntos y de los dos transistores de acople de los de potencia, si se encuentran bien entonces alguno de ellos esta averiado en cortocircuito o abierto
Posted on Aug 04, 2010
muntejaya
  • 10421 Answers
SOURCE: se me puso el sistema pal en la pantalla i cuando
Hi, Please get the code here:
http://carsoundsystem.org/car-music-system-unlock-code/
www.solware.co.uk/download-products/unlock-car-radio.shtml
Regards, Jay__OlpmrfH
Posted on Feb 24, 2011
Que significa el codigo de error EE? en el display .
posible termistor en cortocircuito en el evaporador refrigerador o el cableado del termistor. el corto es m?s que probable que en el conector del termistor. el trabajo debe ser realizado por un profesional capacitado.
Feb 28, 2015 | Sub-Zero 632 / S
HOLA TENGO UNA MOTO PULSAR 180 Y DE REPENTE DEJO DE FUNCIONAR EL ENCENDIDO PROBE CON EL MAND CON EL RELYE DE ARRANQUE CON EL AUTOMATICO CAMBIE LA BATERIA CAMBIE LAS BOBINAS DEL MANGETO EL CDI EL REGULADOR...
Hola, Ulisespiango el siguiente se aplica a los modelos de combustible inyectado con carburador tambi?n, y los sospechosos habituales son: 1. severamente descargada o una bater?a da?ada, 9 voltios o m?s bajas. 2. defectuoso alternador / generador y regulador de voltaje o. 3. Los terminales de revisi?n de la bater?a en busca de da?os o corrosi?n, comprobar los cables de la bater?a en "ambos" extremos de conectores sueltos, corro?dos o rotos, "dentro" y fuera del haz de cables, realizar prueba de movimiento conector y comprobar los cables con un ?hmetro si es necesario. 4. Interruptor disyuntor o ignici?n principal defectuoso, compruebe si hay conexiones sueltas y continuidad. 5. base es defectuosa y o rel? de encendido, verifique la continuidad. 6. bobina de encendido defectuosa, el encendido / m?dulo electr?nico. 7. defectuoso CKP, CPS, CMP, MAP, TPS, O2, o sensores BAS, corro?do, pines del conector de alambre sueltas o rotas / z?calos. 8. Agua o suciedad en el sistema de combustible, carburador o filtro. 9.. Restringido, bloqueado o doblado la l?nea de combustible. 10. Dep?sito de combustible vac?o. 11. La tapa de la gasolina no est? ventilando correctamente o tanque de combustible sistema de ventilaci?n bloqueados. 12. Una bomba de combustible defectuosa, regulador de presi?n y el o los inyectores de combustible. 13. La l?nea de vac?o del colector de admisi?n al grifo roto, agrietado, o no conectado, l?nea de ventilaci?n del carburador enchufado. 14. Aguja y asiento pegado cerrado en el flotador. Para obtener m?s informaci?n acerca de su problema, por favor visite los siguientes sitios web. Buena suerte y buen d?a. DOWNLOAD Bajaj Pulsar 180
May 31, 2011 | Bajaj Pulsar 180 Motorcycles
2002 Honda CBR 600 F (4) me falla
Hola, Elfuetero y los sospechosos habituales son:
1. Una bater?a severamente descargada o da?ada debe tener 12.5 voltios o m?s y puede pasar una prueba apropiada de "CARGA" si es necesario, puede tener una lectura superficial de 12.5 voltios o m?s pero poco o cero amperaje la bater?a est? defectuosa y debe ser reemplazado, las bater?as AGM fallan en este escenario m?s que las bater?as de plomo-?cido.
2. Revise los terminales de la bater?a por da?os o corrosi?n, revise los cables de la bater?a en "AMBOS" extremos por conectores flojos, corro?dos o rotos, "DENTRO" y por fuera del arn?s de cables, realice la prueba de ondulaci?n del conector y revise los cables con un ohm?metro si es necesario.
3. Buj?as en malas condiciones o parcialmente sucias.
4. Los cables de la buj?a en mal estado y las fugas comprueban si hay fugas de chispa en la oscuridad
5. Espacio de la buj?a demasiado cerca o demasiado ancho.
6. Bobina, m?dulo y / o sensor de encendido defectuosos.
7. Conector del m?dulo de encendido flojo, sucio o corro?do en el c?rter.
8. Sensor CKP o CMP, MAP, ETS, ATS, TPS, O2 defectuoso.
9. Filtro de aire sucio.
10. fuga de aire de admisi?n.
11. Agua, suciedad u ?xido en el sistema de combustible.
12. Carburador contaminado, flotador pegajoso, jets enchufados.
13. Diafragma de vac?o del carburador roto, agrietado, no asentado o instalado incorrectamente.
14. Carburadores m?ltiples fuera de sincronizaci?n.
15. Filtro de combustible obstruido.
16. Combustible viejo o contaminado.
17. El sistema de ventilaci?n del tanque de combustible est? obstruido o la l?nea de ventilaci?n del carburador est? cerrada.
18. V?lvula de diafragma de la tapa del gas defectuosa.
19. La l?nea de vac?o desde el colector de admisi?n hasta la v?lvula de combustible est? rota, agrietada, pellizcada o falta.
20. Controles del carburador desajustados.
21. Tiempo de v?lvula incorrecto.
22. Resortes de v?lvula flotantes, d?biles o rotos.
23. Entrada da?ada o v?lvula de escape.
24. Piezas de rendimiento incompatibles.
25. El m?dulo de control puede estar en modo "LIMP"
26. Verifique los c?digos de problemas del motor.
Para obtener m?s informaci?n acerca de su problema y las valiosas descargas "GRATUITAS" que necesitar? para ver o imprimir, haga clic en los enlaces azules a continuaci?n. Buena suerte y que tengas un d?a maravilloso.
Misfire 2002 F4i CBR Forum Enthusiast forums for Honda CBR Owners
Spark Plug Misfire
Honda CBR600F4I 2001 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CBR600F4i Owner Manual
May 24, 2011 | 2002 Honda CBR 600 F(4)i
LA MÁQUINA INDICA ERROR E000805-001
1) Desconecta el poder de la impresora. 2) Quita el ladrillo/bloque negro del poder por detr?s de la m?quina. (Puede ser un malvado peque?o de sacarlo la primera vez usted lo quita.
3) Abre la cima de la impresora/multi unidad de funci?n.
4) tira Suavemente la cinta para centrar el portador de cartucho de impresora.
5) Abre o el lado de izquierda o derecha y quita el cartucho. (Depende de cu?l lado el error ocurre en, negro a la izquierda, el color a la derecha)
6) Verifica que toda la tira pl?stica que cubri? los nuevos contactos en el cartucho tiene de hecho fue quitada.
7) Toallita tanto los contactos de cartucho como impresora con una seco, hilas libertan tela.
8) Enjuga el fondo del cartucho con una h?medo, hilas libertan tela para verificar que la tinta fluye y los vistazos corrigen.
9) se Asegura de que no hay agua que queda en el cartucho.
10) Reinserta el cartucho en el portador y se asegura de que es profundizado y es insertado completamente al trasero de la ranura de portador.
11) Reinserta el ladrillo/bloque del poder.
12) Conecta de nuevo el cable de energ?a el?ctrica de impresora.
13) el Poder en la impresora y el error debe ser resuelto.
14) Corre la alineaci?n de impresi?n e impresi?n o copia varias p?ginas para asegurar el problema ha sido resuelto.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Dec 19, 2010 | Office Equipment & Supplies
Al iniciar mi cpu me da este mensaje --- smart hard drive detects imminent failure error 05,--- prersiono f1 y carga programa bien , este mensaje sala solo al iniciar el cpu el modelo de disco es...
Posiblemente se este da?ando el disco, s?a por medio de un virus o problema f?sico. Es importante que haga una copia de todo documento, foto, musica, y demas archivos que le sean importantes. Despues sirvase formatear el disco de nuevo, volver a instalar el s?stema operativo y los programas que use. Y no olvide descargar sus "drivers" del sitio del web de su s?stema. Despues vuelva a instalar la copia de sus archivos. Deje que pase un tiempito y si el error sigue o vuelve entonces seria mejor que remplazara su disco duro. Suerte y avizeme si le puedo ayudar en algo mas.
Oct 21, 2010 | Computers & Internet
Donde esta el numero del motor del kia espectra
en fima da la blocke en una pequina TAB abaco el cuolata parte derecho
Jul 22, 2009 | 2002 Kia Spectra
Que significa el error 0X4001100200001005 en una restauracion de
Acabo de recibir el mismo mensaje de error en mitad de una restauracion de pc. La solucion en mi caso:
1) Desonectar el cable de alimentacion y encender el pc para que se descargue de toda corriente, volver a conectar la alimentacion.
2) Limpiar el CD de restauracion (con el CD sucio no lee y da error) e introducirlo en la bandeja CD/DVD
3) Encender el pc y enseguida oprimir F12 para que arranque con CD/DVD
4) Esperar que eso lo solucione
Jul 06, 2009 | E-Machines (T2958) PC Desktop
2008 KTM 530 EXC-R deja de funcionar cuando est? caliente
Hola, Bichotupan y los sospechosos habituales son:
1. Bater?a severamente descargada o da?ada debe tener 12.5 voltios o m?s y ser capaz de pasar una prueba de "CARGA" apropiada si es necesario, puede tener una lectura preliminar de 12.5 voltios o m?s pero poco o cero amperaje la bater?a es defectuosa y debe las bater?as AGM fallan en este escenario m?s que las bater?as de plomo-?cido.
2. Alternador / generador y / o regulador de voltaje fallidos.
3. Los terminales sueltos o corro?dos de la bater?a y / o cables, especialmente el cable "NEGATIVO", busquen conectores sueltos, corro?dos o rotos dentro del arn?s de cables en los extremos "BOTH".
4. Disyuntor principal o interruptor de encendido fallado, compruebe si hay conexiones sueltas y la continuidad.
5. Fallo en el sistema y / o el rel? de encendido, comprobar la continuidad.
6. Fallo en la bobina de encendido, estator, magneto, encendido / m?dulo electr?nico.
7. Sensores CKP, CPS, CMP, MAP, TPS o BAS fallidos, conectores / conectores de cable corro?dos, sueltos o rotos.
8. Los cables del acelerador y la velocidad de ralent? o la velocidad de ralent? incorrectamente ajustada deben ser de 950 RPM a 1000 RPM.
9. Interruptor de seguridad de la palanca del embrague, del reposapi?s lateral o del interruptor de seguridad defectuoso.
10. El tornillo de mezcla de aire / combustible no est? ajustado correctamente.
11. La bomba del acelerador est? da?ada o no funciona.
12. Agua o suciedad en el sistema de combustible, en el carburador o en el filtro.
13. L?nea de combustible restringida, bloqueada o doblada.
14. Dep?sito de combustible vac?o.
15. La tapa del gas no se ventila correctamente o el sistema de ventilaci?n del tanque de combustible est? bloqueado.
16. Una bomba de combustible fallida, regulador de presi?n y / o inyectores de combustible.
17. L?nea de vac?o desde el colector de admisi?n hasta el grifo roto, agrietado o no conectado, l?nea de ventilaci?n del carburador taponada.
18. Aguja y asiento atascados cerrados en el recipiente de flotaci?n.
19. El interruptor del ?ngulo de inclinaci?n es defectuoso o necesita ajuste.
Para obtener m?s informaci?n acerca de su problema y las valiosas descargas "GRATIS" que necesitar? para ver o imprimir, haga clic en los enlaces azules a continuaci?n. Buena suerte y tener un d?a maravilloso. http://www.dualsportbc.com/forums/showthread.php?3521-Problems-with-my-new-08-530-exc-r
Bike probs 2008 KTM 530 EXC
KTM 450 EXC EU Repair Manual
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 450 EXC EU Owner Manual
Sep 15, 2017 | 2008 KTM 530 EXC-R
Problemade no prende no jala gasolina
en el baul de carro por el area del shockabsorber del lado pasajero hay un cable que le da correinte and la bomba de gasolina chq ese cable que este bien puesto ....si no es eso quisas la bomba de gasolina se daño para cambiarla tienes que levantar el asiento de atras ..
Oct 08, 2008 | 1991 Honda Accord
Car Audio & Video Logo
98 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
