Question about Samsung SyncMaster T200 LCD Monitor
The monintor will not display, the red on off button keeps fading in and out and will not turn green
    President:
  • 1,138 Answers
Hi!
there are different possible reasons why the display on your monitor went out ..and there's different ways for you to find out what causes this..
1. First, check if the vga cable connected on your monitor is secure and the end cable is properly fix at the video card of your computer.. shutdown your computer, fix and secure the vga cable and turn on your computer..
2. Check if your video card is working and if its properly seated on the motherboard...shutdown your computer replace video card and turn on computer, or shutdown your computer disconnect and reseat properly the video card on the motherboard.. turn on the computer..
3. If you have the skills and the right tools... open the backcover of your monitor...on the power supply section, check and replace blown capacitor, replace bulge capacitors with same value.. inspect and resolder loose terminal connections.. that should fix it and the button of your monitor will turn green again.
4. If the display didn't come out when button is green.. better check the inverter board... check and replace burnt high voltage transformer that is overheating and causing instability on the supply current. check also the backlight inverter and replace the busted, the backlight is responsible for the display in your lcd monitor.
The last two steps is very risky to do by yourself if you don't have the knowledge on it.. better bring it to a credible technician to do the repair and avail of the warranty if there is.
I hope I gave you the right information you need..
If you find this information very helpful, would you be kind to rate this solution and vote on this help below...thanks
Posted on Jun 01, 2010
  • 11,361 Answers
Check the pwer supply section first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
My tv will only display color screens when on
tried with re seat the LVDS cable at the t-com board, it was attached covered with metal shield which transfer signal to the panel display.
Sep 02, 2012 | Toshiba 15LV505 LCD TV
The on button keeps flashing and the red light stays on
Try resetting your Canon PIXMA. Here's how:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Have a good evening!
Jan 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
KP-65WV700 Red and Green Lamps fade out after about 15 seconds
If you know how to adjust G2 (screen) volt adjustment then increase a little bit screen volts of red and green lamp.
Mar 15, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Faded color display
replace the colorwheel.
Jan 27, 2009 | Eiki EIP-3500 DLP Projector
Red light on display not green as usual no power
Hold down the "input" button and "volume -" button while the MAIN POWER BUTTON IS OFF. Then turn on the main power button while those are held down, the light on the tv & avc box will turn green. When it turns green, immediately let off the 2 buttons and press "volume +" button, then press the "Main Power" button. Next step is to repeat the process about 20-40 times & the TV WILL WORK!. I have read that this may have something to do with the energy star compliant commands that can changed through the serial port.
The above is from psxpirate25. Thanks!
I had to repeat the whole process a couple of times to get rid of the factory setup firmware mode. Do it 40 times, I would mess up the sequence a couple of times. Keep trying, it does work.
May 30, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Blank Screen - Panasonic PT-50LC13-K
Hey Ben, The TV is alerting you it is about time to change your light bulb, it will keep on doing this until the light bulb just dies.
Order your Bulb via On Line at any of the places, there are different prices, but average for the authentic one with the chasis included is @ 260.oo and only takes @ 5 days to get delivered. You can save up to 140.oo if you just order the pure light bulb, and go the extra mile changing it, I just explain someone how to about it, only takes you 30 mins. Good look, I hope I get help for my problem too.
Mar 16, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Samsung SyncMaster T200 LCD Monitor Logo
268 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
