Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave is not turning
I just bought a GE microwave in January. In Febuary, my microwave turner plate was not turning.What is the problem?
  • GE Master
  • 9,174 Answers
Probably the turntable motor has failed.
Has anything ever spilled down in the the floor of the oven?
As long as it's not due to an external cause, it has a one year warranty.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
SOURCE:
Hi I have a siemens inno-wave HF17055GB Microwave and the plate turner is not turning, otherwise it seems to be working? help please
Replace the motor. The teeth in its gearbox have probably been damaged when trying to turn the plate by hand.
Aug 25, 2014 | Siemens HF17055GB Microwave Oven
There is sparking in the rotating plate area when my Lg Microwave Appliance 192 A is turned on.................What causes that to happen?
remove all the interior items and see if this happens. usually due to something metallic inside the microwave. if there is still the problem then there is probably some shielding damaged i would not use the microwave as it could catch fire in the worst case. if it is under warranty, return it. if the problem goes away when they contents are removed then there will be a problem with one of the plates or stands. replacements can be bought
Apr 05, 2012 | GE Microwave Ovens
Microwave plate turner keeps spinning even with door closed and microwave turned off
My microwave is doing this as well; It's a frigidaire model #FGMV154CLFA.
After using the microwave part (it is also convection), the light stays on in the microwave and the turner keeps turning.
And I've only used the convection part of my microwave a couple times and I'm not sure if I was successful. While trying to cook something in convection mode, I pressed convection, then pressed the temp i wanted, then convection, then keyed in the time I wanted the item to cook. The microwave started and the timer started counting down but the countdown stopped with 8 minutes left? I left it alone to see what would happen and it never finished so I restarted the process again.
PS..I've never gotten an error code
Apr 23, 2011 | Microwave Ovens
The microwave just stopped working in the middle of heating
Always have something in the microwave before turning on. A glass of water is OK. It's needed to absorbed the energy.
All microwaves will stop if the door is opened. This a safety feature. Never operate with the door opened.
The button below the plug outlet is a test button for the GFI (Ground Fault Interrupter). This is a safety feature of the electrical wiring for your home. Make sure it's turned on.
Since this is a new unit, you may want to take it back to the store you bought from for an exchange/refund.
WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance Warranty Notes For models produced on or after January 1, 2006
See written warranty for full details
Mar 30, 2009 | General Electric JES0736SMSS 700 Watts...
Need a glass tray for sylvania
http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY THIS IS THE ONLY PLACE I COULD FIND THE PART YOU ASKED FOR ,JUST COPY & PASTE THIS INTO YOUR BROWSER & YOUR THERE.YOUR MODEL # DOES'NT SEEM TO BE COMPLETE,THERE ARE LIKE 2 OR 3 DIFFERANT PREFIXES FOR YOUR MODEL.SURF THE SITE,ITS PRETTY SIMPLE.ITS A LITTLE PRICY,(62$)BUT I DID MY BEST,HOPE THIS HELPS!!!
Nov 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Russell Hobbs HOB CTS34 - Faulty glass plate
Door glass broken on russel hobbs 28lt micro wave. Any idea where I can have this replaced. thank you
Mar 15, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
60 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
