Question about Dell 3010cn Laser Printer
Used drum brush on DELL 3010cn but still leaving stripe on paper
  • 128 Answers
You need to change the drum
Posted on Jun 01, 2010
Why is there a black line on my Dell 3010cn printouts
You need to stop the print before it is finished to determine the source of the issue. Most likely sources are the black drum or fuser. Please note: as I hope you will stop the passage of paper before it passes the fuser assembly, the toner will not be fixed to the paper and can/will be smeared. Also, visually inspect both drum and fuser for the line. If you do see the line replace that assembly.
Oct 16, 2014 | Dell 3010cn Laser Printer
Brownish stripe (vertically) down the middle of the page
Replace the drum. the toner is in tubes, and uses a common drum. the drum is replaceable. Go to your local refiller, and get it done quickly.
Jan 27, 2011 | Dell 3010cn Laser Printer
How do i replace drum cartridge?
pull open the front cover lift up the top cover lift up the blue handle on the right pull the blue handle in the middle up that is the drum unit steven 818-888-0006
Apr 26, 2010 | Dell 3010cn Laser Printer
White stripe on right as if black toner needs
You probably got a piece of paper or something in the image path or the paper path. If it is a nice clean line it is more likely to be in the image path, if it is smudgy line it something may be scraping the toner off the paper before it gets to the fuser. Check the paper path.
Dec 26, 2009 | Dell 3010cn Laser Printer
Dell 3010cn white stripe
on the 3010cn open from cover, follow instruction for pulling up the lever and sliding the bar out of the side repeat the slide motion 15 to 20 time. this action cleans the printing plate and will elimiate the strip. the strip is caused be toner leaking on to the plate it the strip returns repeat the steps.
Nov 17, 2009 | Dell 3010cn Laser Printer
THERE IS A BLACK LINE THAT RUNS DOWN THE PAPER ON THE LEFT SIDE. COULD IT BE THE DRUM? I HAVE A CHANGE DRUM SOON MESSAGE SHOW UP.
If you look at the old drum, open the shutter, if you see that line on the drum, then it's a bad drum. The line could also come from the fuser roller...
Jul 21, 2009 | Dell 3010cn Laser Printer
Dell Print Quality Problems: Horizontal lines On One Side
Try running a cleaning sheet through the printer. Remove the drum and check you waste toner (if that is built-in to your drum then skip this). If that gets full, then some of the bad toner can spill out creating lines/smuges. I would also use compressed air to blow out the inside of the printer where the toner/drum goes. That will help remove anything that is left behind after a replacement.
Also, check the settings in the print server for anything that will clean the printer/correct horizontal lines.
Mar 16, 2009 | Dell 3010cn Laser Printer
Problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Feb 10, 2009 | Dell 3110cn Laser Printer
Dell 3010cn DRUM
The information I have on that error is as follows:
From the Dell TS Guide:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&cs=04&journalid=4D4C014288160766E040A68F5A283437&l=en&s=bsd&treeid=DCD92482F5548BF9E030A68F27281FC1&Query=ZHJ1bStlcnJvcg==&SystemID=PRN_LSR_3010CN&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true&dl=
1. Replace the cartridge with a new Dell Branded one
2. If cartridge doesnt resolve, replace the left Intermediate Belt Transfer (IBT) guide assembly.
3. If that doesn't fix, replace the Machine Control Unit (MCU)
May 15, 2008 | Dell 3010cn Laser Printer
Dell 3010cn Laser Printer Logo
122 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
