Question about Hitachi 53FDX20B 53" Rear Projection Television
My tv shows double picture any letters on screen at bottom show twice in red and in white the red lettering is arced above the white
  • Hitachi Master
  • 5,138 Answers
Replace both of your STK ICs STK392-110s Mats has them 1-800-628-1118 They are big blk IC with part number on them.
Posted on Jun 01, 2010
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Zenith R57W46 bottom bowing and color off and double lettering
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Mar 28, 2009 | Zenith R57W46 57" Rear Projection...
Color alignment kpwt500 tv
i would have a shop reconverge it.thats going to be the easiest way to get the picture back the way it should be.
Jan 13, 2009 | Sony KP-46WT500 46" Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
DOUBLE LETTERING/RED
Good Day, TYREKCURRY;
Your TV is ONLY 7 years old, it's only half way through it's life. It will cost about $550.00 depending area. Repair Convergence Circuit FOR .5k or buy new TV for 1.2 k? I would get TV fixed. The HIT is a great TV. Get an estimate from a Factory Authorized Service Center B-4 repair> Good Luck, big IRISH.
Sep 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Seeing alot or green lines, test somewhat double vision
there is a screen the light shows through to project to the screen when this starts to fail the screen will have lines. it sits at the end of the light chamber. these are expensive to replace on some models.
May 30, 2017 | Mitsubishi WS48511 48" Rear Projection...
Picture is yellow and green
Your missing the red drive on the set. Its most likly the picture tube. Its a possibility that the red drive circuit could be not working so the best thing to do is take off the gree picture tube socket and put the green board on the red tube. Of course do all this when the set is unplugged. if you have no tv experience. its not a good idea to be messing around inside of these sets.
Sep 02, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53FDX20B 53" Rear Projection Television Logo
201 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
