Question about Linksys Wireless-G WRT54G Router
Setting up security WPA - Linksys Wireless-G WRT54G Router
    Novelist:
  • 177 Answers
Hi Friend,
In order to resolve the issue please follow the steps:
1.Connect the router to the computer and turn it on.
2.Type 192.168.1.1 in the address bar of the Internet explorer and hot enter.
3.Enter the Username and Password (default password is admin and leave blank the username section)
4.Click Wireless tab and fill the sections as mentioned:
Wireless Network Mode-Mixed
Wireless Network name-As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID-Enable and click Save settings
5.Now click Wireless Security tab.
6.Select the Security Mode as WPA Personal
7.WPA Algorithm-TKIP
8.WPA shared key- Enter a key/password of 8 to63 digit length
9.Group Key Renewal-3600 and click Save settings
Turn off the router for 30 seconds and turn it on after that.
Now your network is secured with WPA Personal key.
I hope this will resolve the issue.
Regards
Chiranjeet
Posted on Jun 05, 2010
Belkin model no.f5D8236-4v2 need security key
  • Open a web browser on the computer. In the address bar of the web browser, type http://192.168.2.1 and hit "Enter."
  • login using login details..
  1. Click on "Security" in the left-hand column under the "Wireless" heading.
  • Use the drop-down menu and select "WPA/WPA2-Personal (PSK)."
Select either "WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2" as your Authentication; doing this will set the Encryption Technique automatically.
  • Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
  • Click the "Apply Changes" button to save the settings.
  • You've now set up WPA/WPA2 security on your network.
For reference,follow this blog-----Belkin N F5D8236-4 Wireless Router
Sep 03, 2012 | Belkin Wireless Surf Router (F7D2301)
Cannot connect wireless on laptop
change the settings of your router if your laptop is using wpa change the security setting wireless connection of your router to wpa... their are many categories of security settings ex. wpa, wpa2, radius, wep, etch.... first configure thE WPA OF YOUR LOPTOP.. HERE IS THE LINK THAT WILL HELP YOU TO CONFIGURE THE WPA http://compnetworking.about.com/cs/winxpnetworking/ht/wpainwindowsxp.htm SECOND IS TO SETUP YOUR ROUTER CHOOSE WPA, OR WPA2
May 01, 2011 | NetGear DG834G Router
Cannot connect wireless works fine wired
change the settings of your router if your laptop is using wpa change the security setting wireless connection of your router to wpa... their are many categories of security settings ex. wpa, wpa2, radius, wep, etch.... first configure thE WPA OF YOUR LOPTOP.. HERE IS THE LINK THAT WILL HELP YOU TO CONFIGURE THE WPAhttp://compnetworking.about.com/cs/winxpnetworking/ht/wpainwindowsxp.htm SECOND IS TO SETUP YOUR ROUTER CHOOSE WPA, OR WPA2
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 20, 2011 | Buffalo Technology AirStation Nfiniti...
How do i connect to internet with ps3, wireless, what is a wpa key?
WPA stands for Wi-Fi protected access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over WEP (Wired Equivalent Privacy) standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
You can correct this problem by entering the WPA Key into your PSP's Network Settings. But before you do that you need to know what your WPA Key is...
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
For minimal security, you can choose 8 characters key, like "iN/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBDm+oMp$nrXj5XPVRTvVA5fpwGSGIRVz4RdQ7V3yl$P1NrT9Be".
Jan 02, 2011 | Video Game Consoles & Games
When i connect i get this message' your wpa key you entered may not be correct"
Jan 01, 2011 | Sony PlayStation Portable (PSP) Console
What does wpa key stand for when setting up for the x box live
Hi ,
I got your issue , WPA Security it denotes that , the network to which you are trying to connect has been protected with WPA security mode, inorder to prevent other people to connect to your internet.
Usually the router can be secured with 2 different security mode, They are
1. WEP(64 bit and 128 bit)
2. WPA
So your router is secured with WPA security
Oct 11, 2010 | Computers & Internet
I have a apple. i want to put a password.. wpa security. how do i do this?? i have searched all over. the set up cd is only for pcs..
you want to put a password on wpa security...
here's what you do, actually you are going to open the firmware of your Wireless Router.
Open Internet Explorer, at the "search engine" just type the Gateway Address (192.168.x.x) then ENTER. After that will asking for Login: admin Password: admin __ this time your on the firmware of the Router. This time will appear and select for putting a password on wpa security. Hope this might you the steps. Good luck!
Aug 05, 2009 | Trendware TEW-432BRP Wireless Router...
How to make a secure connection.So far i have an open connection. My router is Belkin_G_Plus Mimo
Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
1. the Home Page is displayed. Click Wireless from the left menu
8. Changing the Wireless Security Settings
Your Router is equipped with the latest security standard called Wi-Fi Protected Access 2 (WPA2). It also supports the legacy security standard called Wired Equivalent Privacy (WEP). By default, wireless security is disabled. To enable security, you will need to determine which standard you want to use.
To access the security settings, click Security.
The Router features WPA2, which is the second generation of the WPA-based 802.11i standard. It offers a higher level of wireless security by combining advanced network authentication and stronger Advanced Encryption Standard (AES) encryption methods.
2. You can configure wireless security/encrytion settings here. Select WPA-PSK (no server) from Security Mode drop-down menu. The new page will display on next screen
3.Setting WPA Security
Note: To use WPA security, your wireless network cards must be equipped with software that supports WPA. At the time this User Manual was published, a security patch from Microsoft is available for free download. This patch works only with Windows XP.
Your Router supports WPA-PSK (no server). WPA-PSK uses what is known as a pre-shared key as the security key. A pre-shared key is basically a password that is between eight and 39 characters long. It can be a combination of letters, numbers, or characters. Each client uses the same key to access the network. Typically this is the mode that will be used in a home environment.
Setting WPA-PSK
1. From the Security Mode drop-down menu, select WPA-PSK (no server).
2. For Encryption Technique, select TKIP or AES. This setting will have to be identical on the clients that you set up.
3. Enter your pre-shared key. This can be from eight to 39 characters and can be letters, numbers, or symbols. This same key must be used on all of the clients that you set up.
Jun 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Security connectivity issues
is the PC connection you're able to maintain once upgraded to WPA a PC that is physically connected to the router? if so, that would make sense because WPA (and WEP for that matter) are only wireless security protocols and have no protections for hard-wired connections.
In order to convert your system to WPA security, you must first make sure all of your hardware is WPA compatible (that isWPA Drivers are available for it).
For your PC wireless connection, if you're running Windows XP you can go to the microsoft website and download the WPA client. It is available in the Microsoft Knowledge Base Article 815485. install the update and reboot. you will then be able to enable WPA security on your client.
Then you'll possibly need to update the drivers for your hardware for WPA support (router, wireless NIC, etc) if they did not already come enabled.
next you get to configure the router for WPA. you'll want to make sure you're set to WPA with preshared keys (no authentication server required), use TKIP as the algorhythm, and leave group key renewal at it's default value. and of course Select a key that is not likely to be guessed. write the key down as you'll need to configure your NIC using it.
to configure your NIC, once you're in the configuration menu select WPA-PSK for your authentication, TKIP for the encryption mode, in data encryption set it to TKIP, and in the network key put the key you selected earlier.
At this point you should be able to access your wireless router (or other access point). These instructions were kind of generic since i do not have the specific router you're using available to me, but the settings i discussed should be pretty universal when it comes to WPA security.
Jul 01, 2008 | D-Link DI 514 Wireless Router (DI-514)
Linksys Wireless-G WRT54G Router Logo
171 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
