Question about Polaroid TBX-2000AF 20 in. TV/VCR/DVD Combo
The tv keeps losing color
The color comes and goes (yellow) without color
    President:
  • 1,099 Answers
The remaining red retrace are the giveaway that this is most likely not a CRT problem.
(If there were no red lines, it could be the filament for the red gun of the CRT going on and off due to a bad connection inside the CRT - bad news.)
How is a black and white picture? (Turn down the color control).
If B/W picture is good, then the problem is somewhere back in the chroma decoder circuitry.
Check the video input to the CRT video driver board and signals on that board. If B/W picture is also bad, then you can compare red and green signals to determine where they are becoming different. The red lines in your description sounds like the red video output circuit is drifting and messing up the background level, blanking, screen, or other setting. Could be a capacitor or other component.
Hope this will help...
Posted on Jun 02, 2010
  • Polaroid Master
  • 17,129 Answers
If this is erractic and occurs when the tube heats up you must check on the CRT base for any dry connections, open resistor to the gun drives. If soldering the base does not resolve the issue, then you have a possible serious tube damage, the guns are shorting. Check also for a dry solder on the Y/C processor and drive.
Posted on Jun 30, 2010
My 50hm67 turns on for a bit then turns off or lose screen for a bit then turns back on
Some simple things to be aware of: A lamp (generic cheap) or one reaching the end of its life can cause this issue, what is age and brand of lamp in the set?
Nov 02, 2012 | Toshiba 50HM67 50" HDTV
Trying to hook up panasonic veira flat screen tv without a manual. Not sure where to put the red, yellow and white cord.
These cable is to connect your tv to other hardware like a dvd player. Just plug the yellow cord on the yellow input in the TV and in the yellow output of the DVD, and the same thing for the other two colors. The yellow it's for the image, and the white/red are for the stereo sound (right and left channels).
If you don't have extra hardware you wont need to connect that cable.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I keep losing th red color on my screen, what is going on
Y sus problem with your TV. You need a basic tv knowledges to repair it yourselves. Regards
Feb 26, 2011 | Sansui 32" TV
I have a lg 20 inch tv and all it does is change colors the whole screen goes green, then red, then yellow then blue..what do you think cna be the problem?
That colors are a self test to check the pixels on the screen surface. If after the colors the TV works fine is OK. Go in the TV options and disable Self Test or LCD test.
If the TV keeps switching colors you should take it to service because is asking for service.
Nov 02, 2010 | Televison & Video
Yellow color
Ur tv is missig the red color,when it turn into yellow color.Take ur tv to another location,put it into another coalax incomming signal cable use it for awhile see,if have the same problems?Not,than it ur coalax incomming signal cable is defective.Yes,take ur tv aparts the video board that connected to the CRT socket holes are cold solders,resolders those CRT socket holes to have good conductivity.Will not lose red agian.Or take it to the shop,they will resolders it for you.Ask they'll charge u maybe $40-50 get it service,more than that don't they're cheating u.
May 08, 2010 | Insignia NS-24 TV TV
I have sound but no picture on the screen.. What did i do wrong
Hello sir, hi, please check the video cable. If you are using the three color audio/video cable, the yellow one goes to the yellow input of the TV to the yellow output of the DVD recorder. Then check the TVs audio video settings, the TV should be in the video channel, if there are several video channel, check where the video is coming in. Make sure that the yellow cable is good. you can swap several cables to check.
If your TV is component input, put the red green and blue wires to their respective color port, one end is on the DVD recorder, and the other on the TV. make sure your cables are good. Do the same thing with the S-video and HDMI cable. if your TV has this.
Nov 21, 2009 | Daewoo DVRS05 DVD Recorder/VCR
Keeps losing picture,Still have sound
Call him back and tell him that your tv has bad connections. He will check for bad connection on main board in horizontal..........
Sep 13, 2009 | Hitachi 46F500 46" Rear Projection...
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
Polaroid TBX-2000AF 20 in. TV/VCR/DVD Combo Logo
366 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
