Question about Apple iPod nano
Ipod how come i put muisc on my ipod but when i take it out it does'int show up on my ipod
First I would suggest you make sure the iPod is connected correctly, and that you wait until the iPod has finished updating.
If you are sure of that, you can always restore the iPod to it's original settings.
(I would also suggest that you are using the most updated version of iTunes)
But before you restore your iPod, there are a few steps you can take to try and fix this problem.
If you can’t download a song or other item to iPod nano
The song might have been encoded in a format that iPod nano doesn’t support. The
following audio file formats are supported by iPod nano. These include formats for
audiobooks and podcasting:
 AAC (M4A, M4B, M4P) (up to 320 Kbps)
 Apple Lossless (a high-quality compressed format)
 MP3 (up to 320 Kbps)
 MP3 Variable Bit Rate (VBR)
 WAV
The most common is to reset the iPod. To do this:
  •  toggle the Hold switch on and off ( Set it to hold then turn it off again)
  • Then press and hold the Center and Menu buttons for at least 6 seconds untill the Apple logo appears.
If this does not work I would consider restoring. This means you will loose all your music,pictures, videos..ect. But from it sounds, you don't have anything on your iPod to loose.
update or restore iPod nano with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software installation file and follow the onscreen instructions to install
the iPod update.
3 Connect iPod nano to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod software.
If you use the iPod Updater application and it doesn’t recognize that iPod nano is
connected to your computer, reset iPod nano (see page 45).
If you want to restore iPod software and you don’t have an Internet connection, you
can use the iPod Updater application that was installed on your computer when you
installed the software from the iPod CD.
Posted on Apr 09, 2008
SOURCE:
When I try to restore my Ipod Nano Itunes wont let me.it says on the Ipod corrupted restore via Itunes I follow the instuctions but it wont restore.
If itunes is prompting you to restore the ipod but it will not there might be something blocking it on your Computer
The best test is to try to restore from another cpu with itunes
- if it restores then you can take it back to your cpu and re-sync the muisc
- if you get the same error or issue with another cpu
Then is is probably an issue with the hard ware of your ipod
You might want to take it to the apple store or best buy to test
Good luck
Jun 14, 2010 | Apple iPod nano
All of a sudden after 2 years annot get my iPod to appear on computer. A sign comes up that says "The iPod "Lois' iPod" is synced with another iTunes Library. Do you want to erase this iPod and sync with...
This happens some times the computer has lost the record that the ipod was synced with this computer.
Because the ipod can only be synced with one computer at a time your are getting this message.
if you look in your itunes music library and all the muisc is still there then choose the "erase and sync option" this will erase the ipod and re- sync with this computer -
if your muisc is gone you have a much larger problem you need to search your computer for your missing music then add it back to itune when you find it by :
In itunes you go to the upper left to : File > add Folder to Library > and choose the folder the music is in this will re- add your music to the libray then you can " "erase and sync"
If all you music is gone off your computer a only on your ipod your going to have to download a free ipod rip program to remove all you muisc and put it back into your library. there are free ones you can downalod but they are hard to find I have used www.ipodrescue.com and it worked for me
good luck !
May 05, 2010 | Apple iPod shuffle MP3 Player
I have music that plays in itunes,loads to my iPod but will not play The file shows up in the library ,but when I try to play it ,it shows a time bar then goes back to song list
If this problem is on the ipod unfortunatley the way you can try is plugging it in to itunes and click restore which will reflash you ipod to it's original firmware and then update it to the new one and also you song can be deleted int his process so be warned!
Nov 12, 2009 | Apple iPod MA446LL/A MP3 Player
How do i transfer muisc saved on my computer to my ipod nano
open up itunes and the music library tab then drag and drop your saved music into itunes the music will take a little while to load but after it does you will be able to sync it to the ipod
Sep 30, 2009 | Apple iPod nano
Can 't put muisc on the cdr
You prolly got a bad batch return them and choose another brand and yes there refundable or exchangeable... Try a diffrent brand disk ask I had troubles with Memorex and now i use lightscribe and i am glad I did and so would you.. Thanks Rulds2008
___________________________________________
Asker only rate please all other please hold your 2 cents your being logged by fixya.com for unwanted TFT's
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 15, 2009 | Memorex 5PK CDR 700MB 80MIN CD-R80DA...
Problems downloading and syncing ipod to pc after syncing to a mac
No.
Your songs are still on your computer, just sync it to your iPod.
Tips: You can check the "manually manage iPod music and video" to prevent ipod from erasing your iPod muisc,
May 01, 2009 | Apple iPod nano
My Ipod touch screen is black and will turn on, I can here it make a connections to the computer but that is it i cannot do anything else. I was listening to muisc and it just quit.
put it in DFU mode while connected to the computer. to do this, hold the home and power buttons for 10 seconds and then let go of the power but keep on holding the home for 10 secs. the screen will be black and nothing will show up. go to itunes and click on your ipod on the left. then click restore. this should work.
Feb 28, 2009 | Apple iPod touch
Downloading Muisc
i need to put some songs for my ipod
Dec 12, 2007 | SanDisk Sansa m240 MP3 Player
Showing no music
The songs are in the wrong format
Dec 08, 2007 | iLO (2 GB) MP3 Player
Apple iPod nano Logo
120 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
