Question about KitchenAid K45SS Classic Stand Mixer
The main drive plastic drive gear group has cracked and will not drive the betters. Do you have a replace for this gear?
    President:
  • 1,194 Answers
I am not able to get what exactly you want to buy. So, I advice you to visit this link and buy whatever accessory of KitchenAid K45SS you want.
Thanks for using Fixya.
Good Luck and have a nice day
Posted on Jun 01, 2010
  • 1 more comment
  • georgerobi Jun 01, 2010
    Thanks for your help.I do have a dough hook attachment for this mixer which operates OK so I will continue to use this attachment and forget about repairing the mixer portion.I have already purchased another mixer so don't really need this one.
    Many Thanks Geo. R.
  • Ranglo
    Ranglo Jun 01, 2010
    Rating the solution is highly appreciated.
    Thanks for your help.I do have a dough hook attachment wkich works OK so will continue to use that.I have decided to abandon the mixer part asI have already purshased another mixer.
    Thanks Geo. R.
Kitchen aid model kg25. vibrates and beater hits bottom of bowl
Your worm gear is no longer seated and that is more than likely because the housing cover is probably the old style plastic and it has cracked which allows the worm gear to jump up during operation and turn out of sync. The worm gear turns the drive gear that works the planetary gears which in turn drives the beater. If the worm gear is not turning true then of course it is pushing the planetary out of true as it turns, which causes the beater to slam the sides of the bowl. The question is this...does the beater hit the bowl in the same place on the bowl every time? Or does the beater hit the bowl in different places every time? If it hits the same place then it is probably just a planetary gear of which there are four gears involved and it could be any one of them. It it hits a different place every time it is most likely the worm gear and cover. In either case parts will cost between 30 and 50 dollars. and it takes about an hour to fix.
Dec 30, 2014 | Food Mixers
Sunbeam 2352 gears
You will have to buy the original gears and than take them to a machine shop that can reproduce them out of steel or aluminum. You will also have to figure out a way to lubricate the new gears to keep them from getting damaged since metal will heat up where plastic will not. Due to the expense of this proposition it is probably better to just get a better mixer. This one was just designed to work for about a year and than get thrown away. Good quality cannot be purchased on the cheap...if you want something to last these days you have to put out the cash...try http://www.amazon.com/KitchenAid-KSM152PSNK-Metallic-5-Quart-Brushed/dp/B00007IT2S/ref=sr_1_17?s=home-garden&ie=UTF8&qid=1335045748&sr=1-17
Apr 21, 2012 | Sunbeam 2353 Stand Mixer
I have a KP26M1XPm pro series 6 qt 575 watt stand mixer bought in Feb 2006. For some time it made a "knocking" sound as it mixed large heavy jobs. It was not a grinding sound but a knock as the...
I would be inclined to replace the broken/worn gear and only any other bearings/bushes that show wear, which is probably none. I would remove any contaminated grease (it usually remains close to the failure point) and add more grease if necessary. The gear is a fuse gear and designed weaker to fail if the machine is overloaded so the gear that runs on it is unlikely to be damaged.
Mar 02, 2017 | KitchenAid ProLine 600 Stand Mixer
Whining noise in plenetary gear
Hi. Lubrication of the planetary is essential for your mixer. If you're still under warranty (1 year) call Kitchenaid for a replacement mixer but don't tell them that you disassembled anything.
If out of warranty, locate Chevron FM ALC EP-2 food grade grease for your mixer AND the planetary.
If you haven't already done so, go to kitchenaid.com, click on customer care, then click on manuals search. Enter your full model # in the search window and locate the parts list for you mixer. Download it, it will assist you with your servicing and will have all the part numbers for your mixer. If you need a new trans housing insist that it be METAL!
I would also remove the transmission cover, inspect it for cracks if it's one of the cheap plastic housings. If you find cracks, you have more problems with potential internal damage caused by these cracks as this housing supports two important gears and shafts. When it fails these gears skip and cause damage to the gear cogs and bearings. Kitchenaid's replacement housing is made of metal. Hopefully all you need is the planetary greased.
If this solution has assisted you, please rate it. Good luck! ricardok45
May 02, 2009 | Food Mixers
Thumping Noise Under Duress
Hi. Your problem probably lies in the plastic transmission housing. This cheap piece of plastic has no business in a high priced mixer, as it has two important shafts that depend on the integrity of this housing for their bearing seats
Remove the top cover from the mixer. At the front top of the mixer is the trans. housing. Examine this housing carefully for cracks. If you find cracks, then you have new damage inside the mixer. If, when you replaced the three gears, I suspect that you did not discover the cracks in the trans. housing and reinstalled it after you replaced the gears, or you may have missed internal damage from the first breakdown.
When this cheap plastic part fails, it can destroy the worm gear, it's bearings and the bearing seats and possibly more.
Kitchenaid's replacement housing is made of metal. Kitchenaid markets these mixers saying it can handle bread dough. The ugly truth is they cannot!
You must open the unit up, remove and save the grease if it's relatively new. You must check every moving part in the mixer's transmission. You have to remove grease from these parts in order to find the damage. When you have the unit repaired, sell it!
I had the same problem with my mixer. I replaced all of the broken parts, and sold it. Since then, I bought a used Hobart N50 ( 5 quart), and an A200 (20 quart) mixers, both of which are commercial mixers. Both of these can handle heavy dough and they do so with ease.
Kitchenaid, to this date, have refused to recall these trans. housings, even though thousands of these cheap plastic housings have failed. Good luck with this saga!
If this solution has assisted you, please rate it. ricardok45
Mar 31, 2009 | KitchenAid KP2671 Professional 6 Series...
One of the main plastic gear teeth are stripped
Hi. According to West Bend there are no parts available for your 41016 mixer. Your model is considered obsolete. Sorry!
Mar 17, 2009 | Food Mixers
Trying to replace the gear worm on a kitchenaid mixer ksm5ps
Hi. Go to the kitchenaid website, search for the parts catalog for your model of mixer. Download the file and use these expolded diagrams to get to the worm gear shaft. You'll have to remove and save the grease when you remove worm gear. This is a messy, but necessary job.
You don't say what caused the worm gear failure in the first place. If you were making a heavy bread dough when it failed, you need to look further than the worm gear.
Once you have removed the top cover of the mixer, look at the now exposed transmission housing at the top front of the mixer. If this is a plastic housing, check it carefully for cracks. If you find cracks anywhere on this housing, you have discovered Kitchenaid's cheap plastic housing. If your warranty has expired, remove this trans. housing. If you've never done this type of work before, I recommend that you take a digital photo at every stage of part removal, as these photos will help you when you re-assemble the mixer.
If you find that the trans. housing has cracks, this is the direct cause of your worm gear failure. You must check for further damage to the worm gear bearings and their seats. Look for cracks and/or pieces broken off of these bearings. Re-assemble in the reverse order using the photos and the drawings to guide you.
Be prepared to wait for a month for your parts to arrive. Insist on a new METAL housing for the under engineered trans. housing. Kitchenaid is now owned by Whirlpool Corp. The product is but a shadow of the way Hobart used to manufacture these mixers. If this solution has assisted you. please rate it. Good luck! ricardok45
Mar 11, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Stopped Mixing While Kneading Bread
Hi again Libby. You're right to be scared about further damage. If you want to fix this machine yourself, stop using the mixer. Go to the Kitchenaid website and download the drawings that match your mixer model Unplug the mixer! Take a screwdriver and remove the silver band from around the head of the unit ( 1 screw). Next remove the four screws that hold the top part of the mixer. Remove that cover, and look for a 'humpy" looking cover at the front of the machine. Examine this transmission cover carefully. If the cover is made of plastic, look for cracks. If you don't find cracks, you'be better off taking it to a repair shop. If you do find cracks in the plastic cover, remove the four screws that secure it. Remove the trans. cover.
You will now see a lot of grease in this exposed transmission. Put on some latex gloves, get a bunch of paper towels and move some of this grease aside so you can lift the worm gear assembly free of the mixer ( see Kitchenaid drawing). Wipe it off and look for damage to the worm (spiral) gear. Look for damage on the other gear of this assembly, inspect the 2 bronze bearings at either end of the shaft. You're looking for cracks in, or pieces missing from the bearings, look for damaged teeth on the gear. Should you find damage at any stage, that part must be replaced. These parts can be ordered from the Kitchenaid website, and will take about a month for them to arrive.
When you order the required parts, insist that the replacement trans. cover be made of metal. When my mixer "blew up", my replacement was a metal one. If your problem dosen't fit the above solution. I can't help you further. If it does, please rate my solution.
Depending how much grease you had to take out to do the inspection, you might have to order a container of grease to replace it. Good luck! ricardok45.
Jan 23, 2009 | KitchenAid KP26M1X Stand Mixer
KitchenAid KSM90 gear stripped?
I just ran into this problem when the PLASTIC worm gear broke and then the mixer would not power on after I replaced the gear. The problem was due to the was I tried to dissasemble the mixer. I removed the two plastic screws near the top center of the mixer when attempting to disassemble. These do not have anything to do with the assembly it turns out the attached square pieces (attached to these screws by springs) must be in the proper orientation to run. I put them in the way it showed in a diagram but it did not work until I tried all four different combinations that they could be rotated. Two of the rotations on the square could be eliminated by closely looking at the end where it contacts the shaft. The round shaft marking will be evident on the square inserts. I'mnotsure how to better describe them, but the are attached by springs to the plastic screws on both sides of the top of the mixer.
May 31, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
I have a Kitchenaid Professional 6 Stand- up mixer. I'm attempting to replace the Worm follower gear that drives the main planetary drive shaft, but cannot figure out how to remove the original. Please...
hi
there is a ring clamp on top of the main worm follower gear on the drive shaft. you might not see it due to the grease.
you need to get one of those weird little pliers with points on them to spread the ring clamp to remove it. Then the gear is just friction fit on the shaft...it's pretty tight. I carefully used a screwdriver to slowly separate the main follower gear from the lower gear and it goes up the shaft....
after a bit you can wiggle the follower gear by hand and it will come up. Then you can see there is a pin holding the drive gear underneath it in place. The pin in my mixer was actually bent (must have been some tough dough).
then you reverse the process to put the gear back on -- except that the top follower gear has to go on the pin in the right orientation or the ring clamp won't fit.
buy your parts from mendingshed.com
hope it helps.
May 07, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid K45SS Classic Stand Mixer Logo
41 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
