Question about Amcor PCMB-12000E Portable Air Conditioner
My Amcor CPLMB12000E started making a very loud rumbling noise when I turn it on. What might cause this?
2 Suggested Answers
  • 5 Answers
SOURCE: AMCOR
motor completely froze up now! My unit just has a very loud humm when turned on. Getting Amcor to send me another one. Really sucks I have to pay $100 for shipping for something that is under warranty and is only 6 months old. Customer service at Amcor confirmed the motor is bad when I told them about the noise. Makes me think this is a very common problem and a common complaint on these units. Anyone know how to get the $100 back? Class action lawsuit? Do enough other people have this problem?
Posted on Aug 02, 2008
What is wrong with my Amcor KF9000E Portable Air Conditioner?
Do not post the asked for info as a new problem, use the link sent you to answer at the original post.
Jun 01, 2012 | Heating & Cooling
I just got an amcor CPLMB12000E fom a friend, it worked great for about 15 min. then the fridge turned on an blew a cecit breaker in the box. I reset itand all it does is blow harm air. I pluged it into a...
Check compressor and fan only things it can be disconnect one at a time until fault goes away and there is your prob hope this helps
Aircon chilling for a living....................
Sep 01, 2011 | Heating & Cooling
Noise in operation. A loud rumbling noise when
Any noise must be identified with a good observation of the point of noise source.
This can be done with a good view with all safety precaution while the unit moves. Use good lighting and make sure that you are not putting your hands into any moving parts while the set works.
Now disconnect after observation and manually turn the drum, the motor and the rotor to fix the point of noise. this can be a faulty bearing assembly or a faulty suspension all of which will require a resetting/reassembly.
Feb 17, 2011 | Whirlpool LER4634J Electric Dryer
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
Loud rumble sound, Vent hose vibration
That model of neptune dryer had a problem with the blower housings cracking. When the housing cracks, it binds forward into the blower wheel making a loud "rumble" noise and vibration. If you open the door and manually turn the drum and you hear a rubbing noise and feel alot of resistance, then you have a cracked blower housing and need to replace it. It is not an easy job to replace, so if your not familiar with dryers, you should have a technician replace it. Let me know if you have any further questions. shane
Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
Loud rumbling noise in mastercool a/c
could be the fan is full off dust or something causing it to be out of balance
May 19, 2009 | Mastercool 67471 Evaporative Cooler Air...
Kenmore elite3 dryer rumbling noise
there are two rollers that hold up the drum...they go bad...and are ez to replace! they are sold in sets of two for about $30.00
Mar 15, 2009 | Kenmore Elite HE4 Electric Dryer
Haier Model No. HSA04WNC WW/BPG fridgefreezer loud rumbling noise
Rumbling sound is not good. Check to see if it is making the noise with the door open. If so - it probably is a fan blade scraping. If it keeps making the noise - it is likely the compressor - either a faulty relay or capacitor. Or maybe the compressor is faulty. You'll need to be handy with a multimeter to check these out though.
May 30, 2017 | Haier HSA04WNC Compact Refrigerator
Amcor PCMB-12000E Portable Air Conditioner Logo
49 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
