Emerson EWF2704. Plug it in and a high pitch squeal is coming from the board. Originally tv had no vertical now it won't come on at all. Thought there were bad solder joints and re heated them but still get the squeal.
  • 19,396 Answers
Hi.
The problem is likely the deflection yoke.
Try to understand if the noise is coming from the flyback transformer, from deflection yoke and ferrite beads in the horizontal deflection circuits or from one of the boards.
If the problem is one of the boards, then the noise may be produced by a melting capacitor.
If problem is the deflection yoke, then the most common fault is still a cold solder joint. Rather than randomly heating all joints you need to check continuity (read Ohms to verify circuit is closed) to ensure that the solder joints are fine.
Here a service manual
Posted on Jun 01, 2010
Tv dead. high-pitched whine when plugged-in.
Sounds like the back-light inverter board has damaged. Check it.
May 21, 2013 | Emerson LC391EM3 39 in. LCD HDTV
Emerson -modle ewf2704 . tv went out no picture no sound wont turn on but when pluged in you hear a buzzing sound
My 55" LG did the same thing. Had to have tech come to my house and replace board. It is a factory defect in alot of LG TV not sure about Emerson
Feb 12, 2012 | Televison & Video
I can't find a code for my rca universal remote model rcu600m to operate my emerson tv model ewf2704
alright, turns out there is no code for the emerson ewf2704 on this particular remote. i returned it and shelled out five bucks for a different rca universal remote. i ran an auto code search, found the code easily, and i am having no problems.
Aug 14, 2009 | Emerson EWF2704 TV
The picture is to bright
problem in high voltage area, consult an expert
Jun 02, 2009 | Emerson EWF2704 TV
NO PIC HIGH PITCH SQUEAL COMING FORM BACK BOTTEM PART OF TV?
Squealing sound means you have something shorted in high voltage area around FBT on Power/deflection board.UED has replacement boards & Misc Parts for these sets if in stock call them1- 800-648-6657
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Emerson EWF2702 TV Problem
Hello yyimerr1,
This is a vertical deflection problem, These are the possible causes:
1) bad vertical coupling capacitor
2) bad vertical output IC
3) bad vertical driver IC
4) bad CRT deflection yoke
Troubleshooting needed:
1) using the TVs schematic locate the driver IC the output IC and the CRT yoke transformer.
2) using an oscilloscope look at the vertical driver signal it should be a sawtooth signal from the driver to the yoke (increasing in amplitude for each section, i. e. driver and output).
3) if no sawtooth patter is seen that is your problem, look for the component in the section where signal is entering but nothing is coming out.
4) replace the components
Now let me tell you something, don't continue to play the TV with the line present with brightness applied, this will burn the image of the line into the phosphorous coating of the CRT.
I hope this helps
Thank you,
Shuttle83
Nov 01, 2008 | Emerson EWF2704 TV
TV Powered Off, won't come back on
mine did the same thing, I took it to a TV repair store and they said it was a power surge which damaged the power source board. (possibly caused by lightening)
total cost to repair was $70.00 well worth since was only couple years old.
TV is working well.------we'll see for how long????
Jan 06, 2008 | Emerson EWF2704 TV
Double picture
your problem is in vertical section. 1 any capacitor in vertical section is defective. 2 transistors in output ckt might be defective 3 loose contact in vertical section. 4 problem in feed back circuit(if you are a technical person )
Sep 14, 2007 | Emerson EWF2704 TV
Emerson EWF2704 problem
Look for vertical output LA7804 7-PIN IC near right rear of set on heatsink. Look for bad solder joints in that area also.
May 25, 2007 | Emerson EWF2704 TV
Sound but no picture.
The problem with your television appears to be in the high voltage power supply .  This power supply supports the high voltage on the anode of the picture tube, and the voltages for the picture tube, and other parts of the TV. If you do not have a background in electronics, might I suggest that you have a TV technician to come to your location and work on the TV.
I hope this provides some help
Thank you
Shuttle83
May 24, 2007 | Emerson EWF2704 TV
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
