Question about Refrigerators
Water dispenser not working
Hi
I have a kenmore refrigerator thats a couple years old and now the water dispenser isn't working. I just replaced filter but to no avail. The model number is 106-74969400, serial number ER1616388. If anyone can offer any assistance I'd appreciate it!
Zena
  • mschaefe Dec 30, 2008
    I have very low /slow flow and I have checke the line and replaced the filter to no avail.
    Genius:
  • 1,073 Answers
Check the water valve on the ref it is in the back on the right side behind the cardboard cover
Posted on Apr 10, 2008
Hi, I have a Kenmore Elite Refrigerator model #596.76253702 that leaks water from the bottom every time the ice maker refills. The problem keeps getting worse since I purchased this product 2 years ago.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Ice maker water not stopping
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Aug 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Side by side kenmore refrigerator 14 years old leaks water under left front
That coulds be a defrost drain blockage or the coupling to the water dispenser is loose. Remove the kick plate to see if the water is dripping from water line or look into freezer to see if water is draining from rear panel in freezer. Let me know what you see and I will be able to tell you what you need to. Sea Breeze
May 20, 2010 | Kenmore 57029 Side by Side Refrigerator
DOES THE THIS FRIDGE MODEL #106.74912401 REQUIRE TO REPLACE WATER FILTER FOR FRONT DOOR WATER DISPENSE?? ITS A KENMORE ELITE
HI. When a filter has reached its filtering limit, it must be replaced. Once the filter has reached its filtering limits, it will not allow for proper water flow. This will affect the operating status of the dispenser. With that being said, there are other issues that will affect the dispensers abilities as well. These issues are a faulty water inlet valve assembly, and frozen inlet lines. If you are having issues with the dispenser, make sure you inspect these areas as well. Your filter should have an installation date on the label. check to see that it is not over a year old. if so, it should be replaced.
The filter is located behind the front lower grille work. The grille should have a cut out space for it to slide into.
Nov 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore side by side refrigerator water dirty
You may need to replace the water reservoir located behind the crisper. They are known to flake and cause the problem you describe. They are usually replaced with a coil of water line instead of one larger reservoir to stop the problem.
Oct 11, 2009 | Refrigerators
Kenmore refrigerator Model No. 106.56839600 water dispenser
Hi
The water is kept cool in reservoir in the fridg. Remove the inlet tube push for water check pressure better worse? Work your way back to valve
good luck
Apr 12, 2017 | Kenmore 21.7 cu. ft. Side-by-Side...
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore refrigerator water dispenser problem
SORRY TO SAY THIS BUT IT SOUND LIKE YOU HAVE BLACK ALGEA IN YOU WATER SYS WHICH IS GOING TO REQUIRE A TECH TO REPLACE ALL THE TUBING IN YOUR WATER INLET SYS TO GET RID OF IT. GOOD LUCK AND CONTACT APPLIANCE SERVICE CO. P.S. DON'T DRINK THE WATER OR USE THE ICE IT WILL CAUSE MEDICAL COMPLICATIONS
May 30, 2008 | KitchenAid KSRS25IL Side by Side...
Kenmore frigde not dispensing water
Replace the water valve.On the back at the bottom you replace the part the water line is attached to.In the pix i'll show you what a typical valve looks like.754d79f.jpg
May 29, 2008 | Kenmore 53092 / 53094 Side by Side...
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
