Question about Frigidaire FGQ332ES Gas Dryer
Sometimes it light but most times it does not
    President:
  • 1,430 Answers
The problem is the dryer coils have failed. They tend to fail as they heat up.These are inexpensive and easy to replace. The following video will show you how to troubleshoot. There are also other videos on disassembling.
http://appliancehelponline.com/gdryertroublevideo.html
Posted on Jun 01, 2010
Replacing the coils was a simple $20 solutions.
Thanks!
Posted on Aug 11, 2010
I have a Pride Sundancer that will usually go forward but not reverse. Green light flashed 3 then 5 blinks. What is the problem
Hi charge batteries & get them load tested ..U can buy a BATTERY LOAD TESTER of E/BAY cost aprox $36 this will give U an accurate reading on there condition,.3 flashe's unplug charger & turn key of & back on ..5 flashe's remove key push freewheel lever into freewheel & back into drive put key back & try it . Cheers
Nov 30, 2016 | Pride Health & Beauty
Inside dryer light sometimes works sometimes it doesn't
Sounds like the switch for the door is sticking. You should see a switch on the dryer that is activated when the door is opened.
Dec 18, 2015 | Kenmore Dryers
Dash lights and radio lights sometimes work or flicker when hit a bump. Any ideas?
Might be a loose battery cable. Just a thought. did see other post where you stated that you've disconnected battery several times. Hope you find/found a solution.
Mar 13, 2013 | 1998 Jeep Grand Cherokee
2001 Dodge Ram 1500 2WD truck. From time to time the turn signals won't blink. They light up but do not flash. They will sometimes begin to blink and then stop blinking. Sometimes they blink,...
check the earths on the lights and the bulb wattage ,it should be 21watt ,but if its the weird funny system on a american car then who knows ,where the stop light is the indicator and it flashes red and cuts out ??
May 25, 2011 | 2001 Dodge Ram 1500 Truck 2WD
2003 ford ranger extended cab 4 door the door
you have a door switch going bad. next time the lights dont go out unplug them one by one until the lights go out this is the one that is bad
Dec 30, 2009 | Ford Ranger Cars & Trucks
I have a Dell Inspiron E1705 that seizes up.
sounds like your hard drive is about to take a dump or cpu is not cooling good and she is over heating mite get a can of air and blow your fan area out mite be stopped up by some dust try this and see if it helps....
Dec 10, 2009 | Dell Inspiron E1705 Notebook
My right indicator on my 1.2 T reg renault clio
hi, this sounds like you have a bad earth at the rear lights, remove both rear light clusters and check for any signs of corrosion, give all connections a clean and a little tweek, this should cure your problem
Oct 20, 2009 | 2000 Renault 181
Turn on of unit sometimes does not light lamp. Red/Green flashing light, then turns on the next time. (Using button on unit) When using remote, can sometimes get it to turn on the first time (without going...
I'm having the same issue now. Did you ever figure out what was wrong with your unit? Was it a bad lamp? Mine is only 9 months old, low hours, but perhaps a bad one? Can't understand why it would light sometimes but not others.
Jul 01, 2009 | Mitsubishi HC5000 LCD Projector
Frigidaire FGQ332ES Gas Dryer Logo
200 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
