Question about Royal VF1000MX Shredder
Ran something with stickers through my shredder, now it won't run
Shredder won't work - think I ran something with stickers through it and now it won't shred at all. Help
    Genius:
  • 1,218 Answers
Check and see if the cutting blades are turning when the shredder is running...if the cutting blades are not turning then you probably have stripped a gear inside...you will have to open it to check.
Posted on Aug 26, 2010
Emerson cross Cut Shredder X822 how to check Steel Interlock switch at bottom of unit?
Brian, a lot of shredders have a microswitch in the bottom of the unit that has to be activated by a tab on the basket. One possibility is that the tab has broken off, which means that you would need a new basket, or there is a possibility that the shredder head is on the basket backwards and is not connecting with the tab. Hope this helps.
May 22, 2014 | Shredder Office Equipment & Supplies
What kind of lubrication oil for paper shredders
Mineral oil is probably the best choice. You can also use "Paper Shredder Oil" which is probably the same thing but for more $$. Vegitable oil generally works well for lubing things, but have never tried it on a shredder.
Jan 08, 2014 | OfficeMax 0M96431 Shredder
Shredder Green light won't come on and won't shredd. won't go in reverse either.
I had the same problem with the same shredder. The unit uses mains voltage which is rectified to DC and eventually feeds two 12V zener diodes wired in series for a 24Vdc supply. These are 1N4742A (Radio Shack 276-0563), 1W parts. They overheat and will short, which you can verify with a VOM. I reassembled the unit, but recall they are away from the relays at the tail end of the large white colored power resistors, side by side in the same direction. I think Z1 and Z5. After replacing these parts, green LED and reverse, etc. will work.
Apr 14, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
Shredder won't shred. can't hear motor in the forward setting only in reverse
Silverfox007:
There is a paper sensor at the throat of the machine that turns the machine on when it is activated by the paper when the paper is inserted. Something has happened to that sensor. Unplug the machine and remove the shredder head from the basket. Use a screwdriver to remove the screws at the bottom of the shredder head and open the shredder head. Look where the paper is fed into the machine and you will see the sensor. It may be unplugged/wire broken/sensor flag broken off... You'll know what to do when you identify the problem.
Sep 06, 2012 | Office Depot ATIVA DX120P Shredder
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
VF1000MX Shredder: Shredder works briefly in reverse, but won't run f...
Try cleaning the "eyes"....if they get dirty they can act erraticaly...if that dosn't fix it you may have a pcb prob....you can give Royal a call at 1-800-524-0799 for parts information and advice.
May 16, 2010 | Royal VF1000MX Shredder
Shredder won't accept paper on left side
If you think you have taken all the screws you may not know that most often there will be a hidden screw ot two under a sticker or a plug.It may be that your unit has tabs that simply need to be pulled apart. Unfortunately I only know Fellowes products but maybe this will help. Good Luck.
Feb 22, 2008 | Royal VF1000MX Shredder
Won't shut off after shredding.
I FIXED MINE!!! Hey folks same problem AS1018CD would not shut off. CURE: Take apart and clean electronic eye. PROCEDURE: 1. Unplug. 2.  Remove shredder and turn upside down. 3. Remove 6 phillips head screws on back of unit ( 1 is under sticker in middle peel back sticker to access screw. 4. Carefully separate unit. 5. Pull off shredder piece. It is a snug rubber grommet fit and just lifts off( gears everything comes off as one piece. 6. Electric Eye is exposed remove screw holding in and gently slide out and wipe clean. Do both sides. While apart clear all debris and wipe entire unit as clean as you can. Put gear assembly back on grommets. Put top and bottom back together. Replace screws. Plug in. FIXED :-)
Sep 14, 2007 | Aurora Electronics AS1018CD Shredder
Royal VF1000MX Shredder Logo
81 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
