Question about Refrigerators
Hi! I have a Kenmore refrigerator with freezer on top and while the freezer works great, the fridge is not too cold, not even on the highest setting. It is cold but not cold enough. Can you advise what to check for? Thank you! Karoly kbozan@gmail.com
  • 360 Answers
There are many people that have this problem and are searching for answers as to what to do and what could be causing this problem. It seems to be weird that the freezer is working fine and the fridge side is not. Why would the coldest side be good and the warmer side not?
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it’s own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Take care.
Posted on Jun 01, 2010
Freezer side working fine - fridge side simply not cold enough even at highest setting
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 17, 2010 | Frigidaire FRS3R5EMB Side by Side...
My refrigerator and freezer aren't working!
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 19, 2010 | Kenmore 64802 Top Freezer Refrigerator
Fridge/freezer not getting cold
heatman101
Apr 04, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer freezing up in the bottom vents, the fridge is not cold enough. the freezer works great. there is no drainage in the drain pan in the bottom. it is a frost free refrigerator.
The heater for the frost-free isn't functioning. Have a technician check the circuitry on the heater for breaks, or even a defective heater!
Feb 12, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore refrigerator top freezer
sounds like the freezer is frozen solid and not lettting the cold air down to the fridge. Make sure the freezer is going through the auto defrost cycle.
Jan 01, 2010 | Kenmore Refrigerators
So my split fridge and freezer broke. the freezer works fine but the fridge doesnt get cold enough, even if i turn the knob to 7 (the highest).
first clean and remove dust and debris from under unit and make sure fan is working properly--next check the fan in freezer section for icing ,damage ,blockage ,or failure repair or replace as necessary the fan supplies the fridge with cold air from freezer
Nov 26, 2009 | Kenmore Refrigerators
Both firdge and freezer on level 5 and still not very cold
It may just need more freon. A service call won't cost the landlord too much, and then he will have a report from a qualified third party, if the fridge needs to be replaced.
Apr 22, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
The refrigerator section is not cold enough but the freezer is fine on my Whirlpool top freezer unit. my refridgerator isn't cold even with it turned all the way up but the freezer is working fine. I own...
Hi thanks for the question check to see if the freezer fan is working if not replace. check to see if you have frost build up in freezer if you do you then have a no defrost problem. pull fridge away from the wall, remove the back panel, clean all lint. thanks the appliance doc
Oct 03, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
